 Air cleaner removal question
2 posters
Air cleaner removal question Empty
PostSubject: Air cleaner removal question   Air cleaner removal question Icon_minitimeFri Mar 25, 2011 7:31 am
Want to get the air cleaner off so I can inspect my plugs. Owners manual instructions seem ok but I don't know which tool to use to 'loosen the clamp bolt' - it looks like an allen key job but it's a long way in. The pic in the handbook shows a socket wrench. Air cleaner removal question 143088812 please.
PostSubject: Re: Air cleaner removal question   Air cleaner removal question Icon_minitimeFri Mar 25, 2011 2:58 pm
Got to be honest I am not 100% sure off of the top of my head and I am not with my bike so I can’t look.
The best that I remember to get the air cleaner off was the following I think
Undo 2 bolts above the box, both allen Key
Then pull it out slightly from the bottom which will release it from a rubber type gromit
Uncouple a small electrical sensor connector
Disconnect the small pipe
Then I think it was a cross screw to be undone on the bracket
All from memory so apologies if wrong, will check tonight tho
PostSubject: Re: Air cleaner removal question   Air cleaner removal question Icon_minitimeFri Mar 25, 2011 7:08 pm
Ah now if you can do it that way round it will be a lot easier as the clamp screw will be much easier to access when the cleaner cover is off. I tried just removing the two screws but could not pull it off which mad me think the clamp screw has to come off first. Air cleaner removal question 433968 anyway
PostSubject: Re: Air cleaner removal question   Air cleaner removal question Icon_minitimeFri Mar 25, 2011 7:18 pm
Always glad to help Blues Air cleaner removal question 3005623951
» Help! Water pump removal question 1997 VS800
» Cleaner back end.
» All round lubricant,cleaner,water repellant
» Bar end removal help please!
» Baffle Removal
Air cleaner removal question Icon_minitimeby alongfortheride Tue Mar 26, 2024 9:41 pm
Air cleaner removal question Icon_minitimeby SAM11206 Wed Mar 20, 2024 6:34 pm
Air cleaner removal question Icon_minitimeby Onigatudor Wed Mar 20, 2024 2:39 pm
Air cleaner removal question Icon_minitimeby flying1 Wed Mar 13, 2024 4:43 pm
Air cleaner removal question Icon_minitimeby nano Tue Mar 05, 2024 2:19 pm
Air cleaner removal question Icon_minitimeby Brianhuck Sat Mar 02, 2024 7:30 pm
Air cleaner removal question Icon_minitimeby Billybop90 Fri Mar 01, 2024 12:44 am
Air cleaner removal question Icon_minitimeby Aikido789 Sat Feb 24, 2024 10:11 am
Air cleaner removal question Icon_minitimeby bernard chaddock Wed Feb 21, 2024 5:06 pm
Air cleaner removal question Icon_minitimeby bernard chaddock Wed Feb 21, 2024 4:58 pm
Air cleaner removal question Icon_minitimeby fabio almeida Tue Feb 20, 2024 9:28 am
Air cleaner removal question Icon_minitimeby icoolwecool99@gmail.com Mon Feb 19, 2024 9:47 pm
Air cleaner removal question Icon_minitimeby Billybop90 Fri Feb 16, 2024 7:16 pm
Air cleaner removal question Icon_minitimeby SWEET Fri Feb 16, 2024 6:25 pm
Air cleaner removal question Icon_minitimeby VAI777 Tue Feb 13, 2024 3:32 pm
Air cleaner removal question Icon_minitimeby redevil Tue Feb 13, 2024 10:59 am
Air cleaner removal question Icon_minitimeby Urko Sun Feb 11, 2024 11:12 am
Air cleaner removal question Icon_minitimeby CS_0427 Tue Feb 06, 2024 2:28 am
Air cleaner removal question Icon_minitimeby Badger Mon Feb 05, 2024 11:27 am
Air cleaner removal question Icon_minitimeby John Silver Sun Feb 04, 2024 7:05 pm
