 License Plate Side Mount for Suzuki M800 / M50
PostSubject: License Plate Side Mount for Suzuki M800 / M50   Sat May 26, 2012 9:36 pm
Hi made this bracket and placed the number plate to the side,not to impressed,seems to big.Will more than likely put it back before the weekend is over.
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Sat May 26, 2012 9:47 pm
I like it, great job with the bracket by the way but I would reduce to a 7" plate.
A 7" plate with clear letters will not get noticed like the small plates some riders have but stops it looking like a sail & I like seeing the rear wheel
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Sat May 26, 2012 9:52 pm
Cheers Dave will look at the 7" plate,its always nice to have a spare anyway.
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Sat May 26, 2012 9:58 pm
Alfie I don't know if you have a plate supplier or not but just in case you don't, I get mine from here LINK They are good quality and a fast service.
I am sure there are cheaper ones out there on the net though but I have used them for years so can't be arsed to look around and then find I am not happy. What you see with these guys is exactly what you will get so make sure if you use them that you are happy with the font style and letter size on the plate, some fonts are bigger on the plate than others.
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Sat May 26, 2012 10:20 pm
alfie92 what are you useing to light the plate the light that was lighting it is now in the wrong place not a critasisum but more an idear (wich you probaly know about allready)you can by little leds that are biult in to a bolt so you just use them as you would to hold number plate on and they will light it aswell there are a few different kinds just in case you hadent seen them . looks good by the way go with a smaller plate (just my opinion)
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Sat May 26, 2012 10:46 pm
custom dynamics.com think its spelt like that has em led tag bolts also pritty much anything with led lights for your bike they sell it duno about price
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Sun May 27, 2012 7:46 pm
Good job Alfie, wish I had your skills
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Mon May 28, 2012 10:07 pm
Cheers for the input,Morgan have seen those led lights you mentioned,they are around £10 a pair,should be able to knock something up.Dave checked your number plate site out looks good,will certainly bear it in mind.I like to look at things that have been done and then try and do the same only cheaper,sometimes works ,but the fun is in the trying.That's what I like about the site you always get good feedback of other members.
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Tue May 29, 2012 5:14 pm
alfie92 wrote:
I like to look at things that have been done and then try and do the same only cheaper.
We must have been dealt from the same pack of cards, I just wish I had a little more time
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Sat Aug 11, 2012 8:49 pm
Alfie did you stay with the side mounted plate & did you add lights to the plate?
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Sun Aug 12, 2012 1:31 pm
No Dave placed it back on the back,it was to restictive getting the bike in and out of tight spaces.I am still working on the idea but making it a little smaller.The lighting of it is easy with a couple of leds.
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Sun Aug 12, 2012 1:36 pm
I have been thinking of doing it myself but I like the curved ones that they do but cant see where you can get curved plates.
I may have a go at heating an old number plate to see if I can bend that and then make a forked bracket that just bolts on at the top and bottom of the number plate. I would much rather make one for a couple of bob than spend a load of hard earned cash anyway.
As always lots of idea's but no fekin time
This is kinda what I am thinking.
What the finished thing actually ends up looking like though, is anybodies guess
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Sun Aug 12, 2012 7:40 pm
Good idea Dave,and on the plus side it will make your number plate look smaller.
PostSubject: Bending a number plate   Mon Sep 10, 2012 1:33 pm
Decided to have a play with the idea of bending an old number plate today, that will attach to a home made bracket, as I would like to crack on with the side mounted plate soon.
The first thing to consider is how the plate is constructed. What you have is a thick sheet of plastic with the numbers & letters stuck onto it & then a thin piece of clear plastic stuck on that. So the heat must be applied to the underside of the plate, and allow the plastic to heat slowly. Otherwise the letters and clear plastic will just distort and melt. I used a halogen spot light to apply the heat that I have over my workbench. I layed the plate ove a cylinder and let the lamp slowly do the work for me.
For a first attempt I think the plate turned out rather well, so at least now I know I can bend a plate without it going all wonky.
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Mon Sep 10, 2012 2:23 pm
Excellant Dave will be nice to see it mounted,just to get the persective of what the plod can see,not being disrespectful,just the police around here and North Wales have a zero policy on bikes.On the plus side it looks like a plan come into fruition for you.
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Mon Sep 10, 2012 2:30 pm
Good point about the Dibble Alfie. I actually rounded the plate more than I will when I actually do the real one. Curiosity of pliability is what took it to that degree of curvature, as I wondered if there would be a problem due to layers.
PS, I think I need a bloody head Doctor, before I have even finished a current mod I am always thinking about cracking on with the next one
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Mon Sep 10, 2012 4:22 pm
Good thinking Dave, I will look forward to how you eventually do your side plate but with a curved plate you will need to light it from above and below
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Mon Sep 10, 2012 4:40 pm
Good point but not a problem Crash, a couple of tiny plate mounted LED's will sort that problem out. Another idea would be to have a single well placed small forward facing led somewhere that would illuminate that plate.
madfroger
madfroger
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Sat Mar 02, 2013 7:24 am
I know this is really old post now but just for any body else's reference you can buy flexible numberplates and they dont break which is the normal prob with banging the plate on a side mount against things.
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Sat Mar 02, 2013 7:38 am
Nice one, thanks for the info. I did wonder how they got the plates in those curved holders.
mare1411
mare1411
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Mon Aug 24, 2015 8:03 am
hi. im thinking of doing diy side plate holder myself..
How thick should the steel be?
is it better steel or aluminum?
where to fix it? the axle bolt or the one higher?
thanks
marko
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Mon Aug 24, 2015 3:39 pm
Can't help you with thickness of metal, but I don't suppose it'll make much difference, apart from weight.  As far as fixing goes, mine actually bolts through the redundant shock mount, but also fits over where the axle goes through to steady it - it also has a hook arrangement to secure it to the bottom of the swing-arm.  This means it's solid, with no up/down movement.
This was the one I bought SIde Mount & this is what it looks like fitted
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Mon Aug 24, 2015 8:09 pm
Really smart dave
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Mon Aug 24, 2015 8:12 pm
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Mon Aug 24, 2015 8:45 pm
thanks
marko
I'd say about 2mm thick and made of steel, make sure you brace it diagonally from the rear of the plate to the mount (like Dave's) as well, any bends in the metal will be under extreme pressure from the wind resistance otherwise.
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Tue Aug 25, 2015 2:49 am
bigmal wrote:
Really smart dave
Cheers Mal !!
I think mine's about 4 mm on the main section & 2 mm on the brace - I'll measure it later & post.  Just to stress, it really does need to be "locked" so that it won't rotate down.
mare1411
mare1411
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Tue Aug 25, 2015 5:58 am
thanks.. ill try to put something together..
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Tue Aug 25, 2015 1:05 pm
OK - I got the callipers out on mine this morning.  The main section is (approx) 4.5 mm, the brace section is 2.5 mm & the plate holder is 3.5 mm
Hope this gives you an idea of what you're aiming for - by the way - it's a heavy bugger  !!
hmac
hmac
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Tue Aug 25, 2015 7:17 pm
My side mount bracket is a 5mm thick piece of steel I cut from an old hanging basket bracket. I  drilled holes to fix it to the bottom shock mount and to take the plate holder.
The plate holder is a very nice piece of 1mm stainless steel that was salvaged from an old Nespresso coffee machine that was being scrapped.
At the time I didn't know what I would use this piece of stainless for, just knew it would come in handy one day. Lo and behold five years later inspiration struck and I now have a very nice side mount number plate on my VZ800 Marauder.
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Tue Aug 25, 2015 10:31 pm
It's great when you recycle stuff like that. Years ago when me and Mrs bigmal had just started going out, she had a mark one cortina. The plate that the bonnet latch locks into had rusted away, so me and my dad put in a section of an old stainless toaster that he had been holding onto... "Because one day that will come in handy". Happy memories.
hmac
hmac
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Tue Aug 25, 2015 11:13 pm
I love when I can reuse, upcycle or repurpose bits and pieces I have lying round. I was going to buy a number plate bracket from Germany for £70, so the money I saved by making my own got spent on new indicators, petrol and a bottle of 12 year old single malt.
mare1411
mare1411
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Thu Sep 10, 2015 11:44 am
should it be all in one piece? will weded together be enough? or should I pute some bolts through?
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Thu Sep 10, 2015 12:26 pm
Mine is all in pieces which are bolted together, but if you're confident in your welding, I'd say that'd be fine.  Sure a member has better welding skills than me (non-existent) & can advise
mare1411
mare1411
PostSubject: Re: License Plate Side Mount for Suzuki M800 / M50   Thu Sep 10, 2015 12:30 pm
I just tought because I think its easier to weld it rather that to nicely bend 3mm steel :)
» TOHVA Automobile License Plates now ready to pre-order!
» Deliberate mistake.
» Utility trailer registration
» Murray Monster Mudder
» Silver FJ w/ FL tag
Suzuki 800 Intruder Club & Forum :: The Garage :: Number Plates-
» Bono Estente
by Skidalot Yesterday at 4:51 pm
» Hello to all
» Greetings from Scandinavia
» CLUTCH SLIPPING STILL
» Engine swap
» Hello from Hong Kong
» Re: My first project bike
» Miss ing
» new new new
» Newby from Norfolk
» con rod problem
» Whats goin on everybody
» Hi fellow riders
