 Total Available Electrical Power Draw
Total Available Electrical Power Draw Empty
PostSubject: Total Available Electrical Power Draw   Total Available Electrical Power Draw Icon_minitimeSat Aug 11, 2012 3:57 pm
On my bike I have an voltage meter on my handlebars and noticed lately that it wasn't showing the power that it used too, since adding my home made light-bar. I still need to do some checks but I thought you may be interested to know what I have found out so far.
We have approximately 350w of total power output generated by our Stator and the draw of the bike at bog standard (no accessories) is around 220w, so you only have approximately 130w available. My light-bar is running 2 x 55w bulbs = 110w. This leaves leaves only 40w for all accessories, including full beam, LED lights, satnav, heated gear, radio/mp3 player or whatever else you may wish to use. So be careful that you don't overload your system and find that your bike won't start one day because you have used all the electrical power that your bike has to offer. If you are running at or near peak power you really need to ensure that you have the ability to switch things off such as your light-bar when using things like heated vests or gloves that are running off the power from your bike. Also pop your bike on to a trickle charger whenever you can to keep your battery in tip top condition. I have a lead that is permanently attached to my battery and comes out from under my seat so that attaching the trickle charger is not an issue & because its so easy to plug in, I plug it in every time I park my bike up.
PostSubject: Re: Total Available Electrical Power Draw   Total Available Electrical Power Draw Icon_minitimeSat Aug 11, 2012 5:24 pm
Very good points made there Dave,cheers for the info,like you my ride can at times be lit up like Blackpool Lights,so always good to have info like this at hand.I also use an optimiser every time time I get off my bike at home.
PostSubject: Re: Total Available Electrical Power Draw   Total Available Electrical Power Draw Icon_minitimeSat Aug 11, 2012 7:44 pm
alfie92 wrote:
Very good points made there Dave,cheers.
Total Available Electrical Power Draw 428386
Info like that can be invaluable, good info Total Available Electrical Power Draw 881924
» Does Randy Orton draw as champion?
» 7.3 volt power source for an SD2200d.
» Power Mods ????
» 2008 Blessed Mother Teresa Invitational Dec. 4-6 - DRAW
» john deere stx38 help!!!
» First post from Arnold in Idaho
Total Available Electrical Power Draw Icon_minitimeby stingray Today at 7:06 pm
» register logon - C'mon in and say hello - I think
Total Available Electrical Power Draw Icon_minitimeby stingray Today at 7:03 pm
» SAYING HELLO FROM WINNIPEG, MANITOBA
Total Available Electrical Power Draw Icon_minitimeby Takkyu Fri Jun 21, 2019 5:33 pm
» Hello! This is Ed from Wash.,DC
Total Available Electrical Power Draw Icon_minitimeby Takkyu Fri Jun 21, 2019 5:32 pm
» Hiyas
Total Available Electrical Power Draw Icon_minitimeby Takkyu Fri Jun 21, 2019 5:31 pm
» Newbie
Total Available Electrical Power Draw Icon_minitimeby peardrop3 Fri Jun 21, 2019 5:30 pm
Total Available Electrical Power Draw Icon_minitimeby Takkyu Fri Jun 21, 2019 5:29 pm
» Ratchet noise from under tank.
Total Available Electrical Power Draw Icon_minitimeby goshhub Fri Jun 14, 2019 11:39 pm
» First Time Ever Saw Mr Green
Total Available Electrical Power Draw Icon_minitimeby ArnoldinIdaho Fri Jun 14, 2019 9:51 pm
» Hi new here...
Total Available Electrical Power Draw Icon_minitimeby OldManYam Tue Jun 04, 2019 10:10 pm
» Hello from Bulgaria
Total Available Electrical Power Draw Icon_minitimeby OldManYam Tue Jun 04, 2019 10:08 pm
» Hello from Ipswich
Total Available Electrical Power Draw Icon_minitimeby OldManYam Tue Jun 04, 2019 10:07 pm
» VZ800 Charging issue
Total Available Electrical Power Draw Icon_minitimeby peardrop3 Mon Jun 03, 2019 2:03 pm
» Hello from Calgary Alberta CANADA
Total Available Electrical Power Draw Icon_minitimeby peardrop3 Sun Jun 02, 2019 4:55 pm
» Hi from South Wales
Total Available Electrical Power Draw Icon_minitimeby Takkyu Mon May 27, 2019 3:35 pm
Total Available Electrical Power Draw Icon_minitimeby ardie Sun May 26, 2019 6:54 pm
» My 2013 M50
Total Available Electrical Power Draw Icon_minitimeby ardie Sun May 26, 2019 6:50 pm
» Brake lever!
Total Available Electrical Power Draw Icon_minitimeby Shrek Sun May 26, 2019 1:45 pm
» Brake lever!
Total Available Electrical Power Draw Icon_minitimeby Shrek Sun May 26, 2019 1:29 pm
» Hi from Calgary, Alberta, Canada! (2000 Maurader VZ800)
Total Available Electrical Power Draw Icon_minitimeby Takkyu Sat May 25, 2019 8:36 pm
