| | gear change pedal adjustment | |
| Author | Message |
coffeescoffer Member
 | Subject: gear change pedal adjustment Wed Nov 14, 2012 10:54 pm | |
| My M50(2012) seems to only have limited adjustment. I seem to be missing something, so does any one have any advice on this? I need a bit more toe room for some adventure boots, but don't want to have to lift my foot to change down. I cannot see any reference to this in either the service manual or owners manual. |
 | Subject: Re: gear change pedal adjustment Thu Nov 15, 2012 3:44 am | |
| You can easily move the gear shift to give you a larger area under it. However it is impossible gain area under it without having to lift your foot higher to change down through the gears. |
|  | | Bunso Steel Valued Member
 | Subject: Re: gear change pedal adjustment Thu Nov 15, 2012 11:04 am | |
| You won't get that much difference just using the adjuster, I moved mine by taking the whole lever off the cog and putting it back on at a different angle.
You may want to look into getting a heel-toe shifter, then you wouldn't have to worry about your new boots fitting under the lever. |
 | Subject: Re: gear change pedal adjustment Thu Nov 15, 2012 7:42 pm | |
| Thanks guys, yo have confirmed what i thought, so now I look for the heal toe changer. |
|  | | Sponsored content
 | Subject: Re: gear change pedal adjustment  | |
Similar topics |  |
Latest topics | » Bono Estente
by Skidalot Mon Feb 18, 2019 4:51 pm
» Hello to all
by Skidalot Fri Feb 15, 2019 9:25 am
» Greetings from Scandinavia
by OldManYam Mon Jan 21, 2019 11:00 pm
» CLUTCH SLIPPING STILL
by OldManYam Thu Jan 17, 2019 6:56 pm
» Engine swap
by Rayzrider Thu Jan 17, 2019 5:38 pm
» Hello from Hong Kong
by OldManYam Tue Jan 15, 2019 9:26 pm
» Re: My first project bike
by Rayzrider Mon Jan 14, 2019 11:42 am
by ASantos Sun Jan 13, 2019 1:13 am
by simbo Sat Jan 12, 2019 11:35 pm
by Andre van Rooyen Thu Jan 10, 2019 8:05 am
» Miss ing
by peardrop3 Sat Jan 05, 2019 4:30 pm
» new new new
by 2006JD.C50T Fri Jan 04, 2019 8:07 pm
by OldManYam Thu Jan 03, 2019 7:41 pm
by LazyBones Mon Dec 31, 2018 6:40 pm
» Newby from Norfolk
by ardie Thu Dec 27, 2018 4:42 pm
» con rod problem
by mo800 Tue Dec 25, 2018 8:38 pm
by stingray Sat Dec 22, 2018 7:08 pm
» Whats goin on everybody
by ardie Wed Dec 19, 2018 10:33 pm
» Hi fellow riders
by ardie Tue Dec 18, 2018 2:06 am
by abrown Mon Dec 17, 2018 10:52 pm
