| | DIY TRE for M800 | |
Gad_ST Prospect
| Subject: DIY TRE for M800 Sun Dec 30, 2012 6:06 pm | |
| Hi
Surfing this forum I found this "Timing Retard Eliminator (TRE)" mod, since It was first time I've heard about this I've done some google-ing and I want to to this. Search on this forum did not give me any results.
So I have one question just for conformation. I need to trick ECU to think that is in 4th gear all the time except in neutral? Is this correct for M800 2005?
I will base my TRE on this one. (just find out that i cant post links for 7 days :() i will be posting link in 6 days :)
| Subject: Re: DIY TRE for M800 Sun Dec 30, 2012 6:35 pm | |
| Gad I have just been reading up on making a TRE and it seems to be easy for people that know what they are doing. The issue as I see it is knowing what the OHM value of the suzuki 800 is in the 4th gear position.
As you can see different suzuki's have different OHM values for 4th gear on different bikes
15k ohm resistor for 1000/ TLR. 6.8k ohm resistor for 600/750 & Busa's. 2.7k ohm resister for 1000 vstorm
Here is a link to a Vstorm page that shows how it is done LINK | |
| | | Gad_ST Prospect
| Subject: Re: DIY TRE for M800 Sun Dec 30, 2012 8:52 pm | |
| just came from garage. m800 in 4th gear is 2.7k. But as I see all schematics are missing blue wire witch is 12V. will post later when i see what I think is missing. | |
| Subject: Re: DIY TRE for M800 Sun Dec 30, 2012 9:23 pm | |
| This is very interesting, I would never have thought of making these but it would seem they are very easy to put together when you know what you need. Nice thread Gad. | |
| | | Gad_ST Prospect
| Subject: Re: DIY TRE for M800 Mon Dec 31, 2012 1:41 am | |
| This is original wiring and this is with TRE I allready made circuit just need some wires an will test it tomorow if I could stay sober :) | |
| Subject: Re: DIY TRE for M800 Mon Dec 31, 2012 8:47 am | |
| You are a very clever man Gad, this should be very interesting Good luck with staying sober mate | |
| Subject: Re: DIY TRE for M800 Mon Dec 31, 2012 3:37 pm | |
| | | Gad_ST Prospect
| Subject: Re: DIY TRE for M800 Wed Jan 02, 2013 11:21 am | |
| After sobering up :) I decided to put 4 pole DIP switch, so if something go wrong with transistor or resistor I could easy bypass circuit and connect pink wire directly like It was originaly connected | |
| | | Gad_ST Prospect
| Subject: Re: DIY TRE for M800 Wed Jan 02, 2013 12:22 pm | |
| that's it, now I can build it | |
| | | Gad_ST Prospect
| | | | simbo * Site Guru *
| Subject: Re: DIY TRE for M800 Thu Jan 03, 2013 11:52 am | |
| can't wait for your test ride It would seem you have the same problem with rain as we do | |
| Subject: Re: DIY TRE for M800 Thu Jan 03, 2013 5:47 pm | |
| Good on you Gad, looking forwrd to your findings and some pictures hopefully | |
| Subject: Re: DIY TRE for M800 Thu Jan 03, 2013 5:52 pm | |
| good work hope the suns out soon for you or with sum luck the rain stops | |
| | | Gad_ST Prospect
| Subject: Re: DIY TRE for M800 Sat Jan 26, 2013 7:10 am | |
| Finally connectors arrived, everything is soldered up and sun is shining :) went on the test ride, and all i can say there is a noticeable difference, especially in 2nd and 3rd gear. | |
| Subject: Re: DIY TRE for M800 Sat Jan 26, 2013 11:28 am | |
| Nice one Gad, sounds very interesting. do you have any pictures of the item and install? | |
| Subject: Re: DIY TRE for M800 Sat Jan 26, 2013 5:18 pm | |
| That's good to read, a mod well worth doing especially at DIY prices. | |
| Subject: Re: DIY TRE for M800 | |
Latest topics | » just saying hello to this site by sgtruth60@gmail.com Yesterday at 8:04 pm
» Newbie by M800chimp Yesterday at 11:28 am
