 CHEAPO electircal test meter: ALDI
PostSubject: CHEAPO electircal test meter: ALDI   Sun Dec 30, 2012 6:58 pm
Got one of these today from ALDI for less than a fiver.
Handles both 12v and mains.
Doesn't give voltage level, but tells you +ve and -ve which is dead handy when wiring in accessories etc.
PostSubject: Re: CHEAPO electircal test meter: ALDI   Sun Dec 30, 2012 7:38 pm
Me thinks there is going to be a run on ALDI now, good post Mal
icetechaus
icetechaus
PostSubject: Re: CHEAPO electircal test meter: ALDI   Thu Apr 04, 2013 7:55 am
Be really careful if you are going to try to use that for fault finding. Not knowing the difference between 2V and 12V.
PostSubject: Re: CHEAPO electircal test meter: ALDI   Thu Apr 04, 2013 1:22 pm
Sorry mate you've lost me there....
icetechaus
icetechaus
PostSubject: Re: CHEAPO electircal test meter: ALDI   Thu Apr 04, 2013 1:34 pm
Dirty contacts or corrosion can cause a high resistance. With a test LED like that the led will light up whether you have 6V or 12V there. You can spend a lot of time chasing your tail because everything looks OK even though there's a problem there.
PostSubject: Re: CHEAPO electircal test meter: ALDI   Fri Apr 05, 2013 8:20 am
So that would mean that you could only use it to see if there is a current rather than there is enough current.
icetechaus
icetechaus
PostSubject: Re: CHEAPO electircal test meter: ALDI   Fri Apr 05, 2013 9:05 am
In basic terms that would be it.
PostSubject: Re: CHEAPO electircal test meter: ALDI   Fri Apr 05, 2013 10:06 am
Lost me too? I thought it was just for testing for live wires and taking the guess work out, not giving voltage readings :what1:
PostSubject: Re: CHEAPO electircal test meter: ALDI   Fri Apr 05, 2013 4:49 pm
No confusion on your part Sim, that is what it is for!
icetechaus
icetechaus
PostSubject: Re: CHEAPO electircal test meter: ALDI   Fri Apr 05, 2013 5:12 pm
I only bring up as through years of experience of working on electrical and electronic systems I have seen people waste a huge amount of time and money using things similar to that and deciding that a circuit or wire was OK because the LED came on.
If you have a way of using it that satisfies your need go for it.
PostSubject: Re: CHEAPO electircal test meter: ALDI   Fri Apr 05, 2013 7:27 pm
I agree with Ian, these little tools have a use but are very limited. Much better to buy a cheapo meter.
PostSubject: Re: CHEAPO electircal test meter: ALDI   Fri Apr 05, 2013 10:53 pm
You can always get the live and earth, stick them in your mouth at the same time and give them a good suck & if your eyebrows burst in to flames and you piss yourself you know the connections good
PostSubject: Re: CHEAPO electircal test meter: ALDI   Fri Apr 05, 2013 11:30 pm
But don't try this on your home electrics folks
PostSubject: Re: CHEAPO electircal test meter: ALDI   Sat Apr 06, 2013 8:00 am
PostSubject: Re: CHEAPO electircal test meter: ALDI   Sat Apr 06, 2013 12:16 pm
Good find Mick I always wanted a tester but funds have always made me say no but even I can afford that one
Simbo your a good man for putting in the household wiring warning, sucking that stuff will make you shit yourself as well
PostSubject: Re: CHEAPO electircal test meter: ALDI   Sat Apr 06, 2013 2:14 pm
Crickey, that's a silly price. Got one as a spare, be silly not too.
» Rest Bay Wind Meter
» Canoe & Kayak Drysuit Comparison Test
» Kid born to be a sports star? Take genetic test.
» Where to test a new GPX5000
» Kiteworld test on the Fluid ATV
» Bono Estente
by Skidalot Yesterday at 4:51 pm
» Hello to all
» Greetings from Scandinavia
» CLUTCH SLIPPING STILL
» Engine swap
» Hello from Hong Kong
» Re: My first project bike
» Miss ing
» new new new
» Newby from Norfolk
» con rod problem
» Whats goin on everybody
» Hi fellow riders
