| | VZ800 fork measurement | |
AmericanJambo Member
| Subject: VZ800 fork measurement Tue Jan 22, 2013 5:26 pm | |
| Does anyone know what the measurement is for the forks on a VZ800? I'm looking for turnsignal mounts and I don't know what size in mm I need. I haven't been able to find the information anywhere. Can anyone help? Thanks! | |
| Subject: Re: VZ800 fork measurement Tue Jan 22, 2013 7:37 pm | |
| The measurements for bike sizes are across. not circumference, i.e. 1" bars =across the circle of the end of the bars, 2" forks = across the end of the fork leg, sorry I can't help with your bike though as I have a different model | |
| Subject: Re: VZ800 fork measurement Thu Jan 24, 2013 5:12 pm | |
| Hi Jambo on the m50 the the width is 21.70mm at the widest point,going down to 20.00mm hope this helps.The part that normally takes the turn signal bracket is 21.70mm. | |
| Subject: Re: VZ800 fork measurement Thu Jan 24, 2013 9:23 pm | |
| - alfie92 wrote:
- Hi Jambo on the m50 the the width is 21.70mm at the widest point,going down to 20.00mm hope this helps.The part that normally takes the turn signal bracket is 21.70mm.
Thank you! Do you know of any aftermarket turn signal mounts that work with the m50? | |
| Subject: Re: VZ800 fork measurement Mon Jan 28, 2013 7:05 pm | |
| Just so everyone knows, the forks on the VZ800 are 54mm. | |
| Subject: Re: VZ800 fork measurement Tue Jan 29, 2013 6:27 am | |
| - simbo wrote:
- The measurements for bike sizes are across. not circumference
| Subject: Re: VZ800 fork measurement Tue Jan 29, 2013 4:22 pm | |
| Yep, Exactly. Measured across (diameter). 5.4cm, i.e. 54mm. I think Alfie might have accidentally measured in inches. Some bikes have forks that are 55mm, which if you measured that in inches would be 2.17in. If you measured across and the forks were 21.7mm that would equal .85 inches and there's no way that the forks of any bike are only .85" in diameter. | |
| Subject: Re: VZ800 fork measurement Tue Jan 29, 2013 10:37 pm | |
| good shout | |
| Subject: Re: VZ800 fork measurement | |
