| | * Mr Intruders Battery Upgrade Mod * | |
| Author | Message |
 | Subject: * Mr Intruders Battery Upgrade Mod * Mon Feb 18, 2013 2:50 pm | |
| I have been researching batteries recently because I am looking at getting a new one for my bike as mentioned in another post. The issue with the Intruder as per the stock battery is that unless it is at peak, it just will not start the bike. Simply leaving your ignition on for a few minutes which in turn puts the lights on, will strip the battery of a little power & in doing so takes you below the peak power that is required to start the bike. To get a more powerful battery you either have to get a bigger or more powerful one, the issue that we have then unless we want to spend loads of cash on ridiculously priced batteries is size. If you get a bigger battery you will have to do either major or minor adjustments to the bike. With this in mind and trying to find a battery that would give increased AH & EN to the majority of members wishing to get more power without any real hassle, I looked at which batteries would fit the battery box in both width & depth, so that only minor modding need be done to the seat because of extra battery height. Here is a comparison between the Stock YTX12-BS & the one I will install on my bike the YTX14-BS You could possibly go to a "16" but that is a little to tight for comfort for me.
Stock battery --------- Replacement battery Brand: Yuasa YTX12-BS ----- Brand: Yuasa YTX14-BS Voltage : 12 V ----- Voltage : 12 V Capacity : 10 Ah ----- Capacity : 12 Ah Cold start performance: 180 EN ----- Cold start performance: 200 EN Dimensions : 152mm x 88mm x 131mm ----- Dimensions : 150mm x 87mm x 145mm Weight (filled) : 4.2kg ----- Weight (filled) : 4.6kg
The width of the battery will not be an issue as it is only 2mm wider and if needed (doubtful) that can be taken from the foam that is at either end inside the battery box. To install the YTX14-BS and gain the extra power increase all that need be done to the stock seat is to cut 14mm off of the foam block that is between the seat & the battery. After market seats may vary though, I have a Saddlemen profiler seat, that needs slightly more adjustment but again this is easy and is only a matter of cutting back a little of the seat base, which instead of being foam like the stock seat is fiberglass. Stock seat foam removal.  |
|  | | alfie92 Very Valued VIP Member
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Mon Feb 18, 2013 3:35 pm | |
| Good and interesting read,cheers Dave will keep that in mind. |
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Mon Feb 18, 2013 4:55 pm | |
| If all you have to do is trim a couple of millimeters off of that chunk under the seat, then that is a mod well worth doing. So that means you gain 10% on the amperage hours and 10% on the cold cranking amps, well worth upgrading and doing that at battery renewal time Nice one Dave, well thought out as usual mate  |
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Mon Feb 18, 2013 5:13 pm | |
| Thanks guys, its modding that keeps the brain in gear.  |
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Mon Feb 25, 2013 2:16 pm | |
| Well the proof is always in the pudding, so today I bought my battery and fitted it. As you can see, here is a visual direct comparison between stock & upgrade battery.  Here are 2 photo's, the first of the stock battery YTX12-BS in place and the second of the upgraded YUASA YTX14-BS in place. Stock YTX12-BS  Upgrade YUASA YTX14-BS  As you can see from the pictures the battery fits perfectly in to the battery box as I had suggested, with just the extra height of 14mm. The upgrade gives me an extra 10% power accross the board but with the all important increase in cold cranking amps that I was after. |
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Mon Feb 25, 2013 4:12 pm | |
| Good to see you have done it dave, extremelly well thought out this mod  A question tho. Would any battery make that has the extra power but is still the same size be OK or not? |
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Mon Feb 25, 2013 4:38 pm | |
| Thanks mate, glad I have done it.  As for the make question, I only buy YUASA as I know they are quality, although they are expensive. I would advise anyone that needs to change their battery to do this, whatever make they end up using. For the sake of trimming off 14mm of foam (as shown above) they will have a battery with more grunt. 10% doesn't sound a lot but it is, especially when you consider the 0.1v can make the difference of the bike starting or not! |
|  | | simbo * Site Guru *
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Mon Feb 25, 2013 4:58 pm | |
|  The extra 10% could come in very handy if anyone's having trouble starting there bike, How have you gone on with it under the profiler seat ? |
|  | | Proudtexson VIP Member
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Mon Feb 25, 2013 5:37 pm | |
|  I always like the idea of more cranking amps. I have never figured out why we don't have the option to turn lights off on a Cycle. I guess these Gov's think we are to stupid to make that decision for ourselves. In the 80s my first wife (deceased) rode a Kawa. KZ650. If it didn't start right off the first start of the day it wouldn't start. It would start ok after the first start. if I could have turned of the lights it would start. had to pull fuse each time. I love Government. NOT!!!!!!!! BTW we are having another 45/45 day here. |
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Mon Feb 25, 2013 6:00 pm | |
| Just been showing & chatting to the father inlaw about this mod and he said you need to remember that the 10% gained is actually 20 amps & that is a a hell of a lot. So once again good shout dave  |
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Mon Feb 25, 2013 6:37 pm | |
| - simbo wrote:
The extra 10% could come in very handy if anyone's having trouble starting there bike, How have you gone on with it under the profiler seat ? The Profiler seat was nearly as simple the stock seat, only difference was that where the stock seat has a foam block I had fibreglass. So I trimmed that back in the same way but took off an extra 10mm and then stuck a 10mm foam block to the area that I had trimmed off so that I didn't have hard edges touching the battery. Took me 5 minutes, so that was easy. - captain crash wrote:
- Just been showing & chatting to the father inlaw about this mod and he said you need to remember that the 10% gained is actually 20 amps & that is a a hell of a lot. So once again good shout dave
 That's why I did it crash, loads more available power! |
|  | | Doc Cox The Nutty Professor
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Wed Feb 27, 2013 8:43 pm | |
| Good mod Dave,  20 amps is a big jump  did you remember to put vaseline on the terminals, this will keep corrosion at bay and keep the amps flowing, had thought about battery power for project virago as this needs a good belt to start it, have had both batteries on charge and the desulphater attatched to them and both have come up well and holding a good charge, there is enough room to fit one on each side so the silver one will be getting two batteries for good cranking amps and the alternator will be up to it as I won,t be fitting accessories to it, will let you know how it goes, regards Doc Cox, E=MC2. |
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Fri Mar 01, 2013 4:06 am | |
|  | | peardrop3 Very Valued VIP Member
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Sun Aug 04, 2013 7:02 pm | |
| Another one to remember when the time comes I feel! |
|  | | Lowey Valued Member
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Thu Aug 08, 2013 1:48 pm | |
| Hello Mr Intruder, When you purchased this battery did it arrive ready to fit from the supplier or did it come with acid for you to put in? |
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Thu Aug 08, 2013 7:24 pm | |
| You will need to put the acid in from the separate acid container. There is no chance of spillage or any issue due to the design of the vessels that the acid is in. |
|  | | Lowey Valued Member
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Thu Aug 08, 2013 7:46 pm | |
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Wed Apr 01, 2015 4:55 pm | |
| Have just ordered a replacement battery for my VL800. It's a 12v 14ah one from County battery at Ilkeston near Derby at £36-99p. It's the same dimensions as Mr I's 12v 12ah one but as I said it's a 14ah instead so should throw the engine round like billyho!!! County Battery, 01159307434 part No. 11481487 www.countybattery.co.uk . Just thought that after 5 years on the bike it may feel like having a new battery even though the original one has only done about 5500 miles. |
|  | | stingray Very Valued VIP Member
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Wed Apr 01, 2015 6:13 pm | |
| Excellent mod Dave, I'll be doing it when renewal is needed  |
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Thu Apr 02, 2015 7:01 pm | |
| Collected my new battery today & the guy did me a deal & only charged me £34-99 instead of £36-99 as I was a returning customer. He said to mention that the next time I needed another battery. The battery is a gel type not an acid one but that's no problem so when I get the bike out next I'll be swapping it over. I would have done it today but my aunt is unwell so Rosie & I have been with her most of the day. |
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Thu Apr 02, 2015 7:42 pm | |
| Good man Peter, glad to here you've done it.  |
|  | | Ken1964 Valued Member
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Fri Apr 03, 2015 8:53 am | |
|  | | ardie Valued Member
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Wed Aug 31, 2016 6:32 pm | |
| hi guys my battery gave up on bank hol Monday 60 miles from home had to buy agm 12 v 6ah batt to get back home its physically half the size but it started her so looking a battery does this mod still apply thanks in advance.peter how are you getting on with yours |
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Thu Sep 01, 2016 3:12 pm | |
| Starts first time everytime Ardie! Would recommend looking at the higher amperage one's from a local retail battery dealer near your home as post might limit your costings a tad! |
|  | | ardie Valued Member
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Thu Sep 01, 2016 5:35 pm | |
| thanks peter will do can get the same as mr intruders in Halfords for 60 quid so will prob go down that route and cut the foam on the seat |
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Thu Sep 01, 2016 5:39 pm | |
| Did not need to cut the foam on mine Ardie so I guess they come in different sizes just to confuse us eh? |
|  | | ardie Valued Member
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Thu Sep 01, 2016 6:10 pm | |
| yes the one I am looking at is taller as in pic at top of thread |
|  | | ardie Valued Member
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Thu Sep 01, 2016 6:44 pm | |
| just ordered on ebay 50quid the agm battery I had to buy to get home was 40 was lucky to get anything on bank hol I suppose |
|  | | Rob Reimer Member
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Fri Sep 02, 2016 11:20 am | |
|  | | katsd Very Valued VIP Member
 | Subject: Re: * Mr Intruders Battery Upgrade Mod * Mon Sep 05, 2016 1:54 pm | |
| - peardrop3 wrote:
- Did not need to cut the foam on mine Ardie so I guess they come in different sizes just to confuse us eh?
Same here Pete - sits a bit taller, but the foam easily compresses to accommodate |
|  | | Sponsored content
 | Subject: Re: * Mr Intruders Battery Upgrade Mod *  | |
Similar topics |  |
Latest topics | » Ello
by stingray Yesterday at 6:21 pm
by ardie Sun Dec 01, 2019 11:18 am
» 2012 C50 Boulevard's new look and Thanks....
by ardie Wed Nov 27, 2019 6:28 pm
by ChuckT Wed Nov 27, 2019 6:44 am
» Burbles like a V Twin Now....
by bob gibson Tue Nov 26, 2019 1:21 am
» Just a little help.
by katsd Sun Nov 24, 2019 5:57 pm
» Do I Need A EFI Mapper or Not....
by Badger Sun Nov 24, 2019 3:50 pm
» vz800 cams
by 81ker Fri Nov 22, 2019 1:49 pm
» South Australian Owner....
by ardie Wed Nov 20, 2019 6:30 pm
by ardie Fri Nov 15, 2019 7:31 pm
» Saying hello
by ardie Fri Nov 15, 2019 7:30 pm
» New noises???
by Dmill1222 Thu Nov 14, 2019 6:14 pm
by bob gibson Wed Nov 06, 2019 6:39 pm
» Electronic fuel injection
by 03580 Wed Nov 06, 2019 2:18 pm
» Straight Shots on 2006 C800
by Tucker Tue Nov 05, 2019 7:57 pm
» hi guys
by ardie Mon Nov 04, 2019 12:07 pm
by GPDave Mon Nov 04, 2019 9:00 am
» Insurance
by ardie Sat Nov 02, 2019 12:50 pm
» Chase Williams in Tennessee
by stingray Fri Nov 01, 2019 10:10 pm
by Proudtexson Fri Oct 25, 2019 12:29 am
