 Rear Wheel Removal, Suzuki C800 / M800
Rear Wheel Removal, Suzuki C800 / M800 Empty
PostSubject: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeSun Mar 03, 2013 4:13 pm
Removing the rear wheel is a 20 minute job that even the least experienced spanner hand can do. So here is a quick how to.
You will need to jack your bike up to do this easily, and before removing the axle ensure that your wheel is supported from underneath.
Remove the nut on the rear brake rod, it will turn easily by hand after a few turns. Just push the lever on the drum forwards, this will take up the tension from the spring and undo by hand. If it is stiff use a 14mm socket or spanner to loosen it first. When you have removed the nut, you will also have a washer behind it and a spring further up the rod, Remove all 3,
Rear Wheel Removal, Suzuki C800 / M800 IMG_1074_zpsbe16da90
Rear Wheel Removal, Suzuki C800 / M800 IMG_1099_zps72a87021
Next Undo the nut and bolt that secures the brake drum in place via the rod.
Rear Wheel Removal, Suzuki C800 / M800 IMG_1097_zps72a33e32
I used a 14mm ring spanner for this task on the nut at the rear and a 14mm socket on the front bolt head.
Rear Wheel Removal, Suzuki C800 / M800 IMG_1101_zps3072fdfa
Rear Wheel Removal, Suzuki C800 / M800 IMG_1104_zps3f0de463
Now undo the nut that holds the rear wheel axle on, for this you will need a 22mm socket.
Rear Wheel Removal, Suzuki C800 / M800 IMG_1073_zpsb020ea22
Rear Wheel Removal, Suzuki C800 / M800 IMG_1079_zps72a3f985
Rear Wheel Removal, Suzuki C800 / M800 IMG_1080_zps6eb744cc
Now gently tap the axle bolt through a little from the side you are working on towards the drive shaft side.
Rear Wheel Removal, Suzuki C800 / M800 IMG_1086_zps2177dec7
This is what you will now see from the drive shaft side. Now pull the axle through and out of the wheel.
Rear Wheel Removal, Suzuki C800 / M800 IMG_1088_zps19027d02
Rear Wheel Removal, Suzuki C800 / M800 IMG_1089_zps621cccf1
Now remove the spacer that is between the frame and wheel if it has not already fallen.
Rear Wheel Removal, Suzuki C800 / M800 IMG_1091_zpsf542c5af
Rear Wheel Removal, Suzuki C800 / M800 IMG_1095_zps33e7527f
Rear Wheel Removal, Suzuki C800 / M800 IMG_1093_zps597ebb04
Your wheel will now come out
Rear Wheel Removal, Suzuki C800 / M800 IMG_1116_zps2bc4da5e
As already mentioned this is a 20 minute job that even the least experienced spanner hand can do without any worry at all.
Cheers Dave (Mr Intruder)
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeSun Mar 03, 2013 5:08 pm
Good write up Dave as usual,should put peoples mind at ease doing it themselves.Rear Wheel Removal, Suzuki C800 / M800 996187811
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeSun Mar 03, 2013 7:16 pm
Very informative write up Dave Rear Wheel Removal, Suzuki C800 / M800 276246 It will give the less mechanically minded the confidence to do the job and save themselves a few quid.
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeSun Mar 03, 2013 7:20 pm
Cheers guys. Rear Wheel Removal, Suzuki C800 / M800 433968
Also if the rear wheel is ever off. That is a very good time to check the rear brake shoes.
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeSun Mar 03, 2013 7:25 pm
A good time to grease the shaft as well Rear Wheel Removal, Suzuki C800 / M800 3498837457
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeSun Mar 03, 2013 7:39 pm
Excellent write up davey Rear Wheel Removal, Suzuki C800 / M800 3322349030 Rear Wheel Removal, Suzuki C800 / M800 276246
Just what we need, some of the basics covering in detail. This sort of job would scare a newbie without any wrenching skills because of the bike being shaft driven. They can see from threads like this how easy it really is Rear Wheel Removal, Suzuki C800 / M800 184121345
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeSun Mar 03, 2013 7:56 pm
Sim, very good point mate. I will be addressing that soon in another thread. A very very easy task that is too.
Crash, thats why I did it mate, gotta help the guys with very little experience. I have a few more I will be doing as well.
Jimmyboy
Jimmyboy
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeSat Dec 21, 2013 9:40 am
Just what I needed there Dave cheers mate, quick question though....when replacing the rear wheel is there anything to look out for in terms of the mating surfaces? Might sound thick here but what locks the wheel to the final drive assembly?
Cheers,
Jim.
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeSat Dec 21, 2013 10:32 am
Cheers Jim.  Rear Wheel Removal, Suzuki C800 / M800 3498837457
No mate nothing that locks the wheel into place when fitting it. Just lift the rear wheel into place and pull it over to the left until it is sat inside the drives splines & push the axle through.
Jimmyboy
Jimmyboy
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeSat Dec 21, 2013 1:41 pm
Cheers for that Dave.
Jim.
Bigredbus4468
Bigredbus4468
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeTue Nov 18, 2014 6:51 pm
Urgent please help. Flat rear tyre cannot ride. Unable to remove rear wheel as I can't get to axel bolt as exhausts in the way.
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeTue Nov 18, 2014 7:11 pm
Hi Kevin, Try taking the weight of the wheel of the spindle by lowering the jack till the wheel is touching the floor, leave the nut on the end of the spindle to protect the threads and tap with a sideways on hammer until it's released, failing that remove the top silencer to gain better access  Rear Wheel Removal, Suzuki C800 / M800 3498837457
Bigredbus4468
Bigredbus4468
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeTue Nov 18, 2014 7:20 pm
Thanks mate. How do I remove the top stock silencer?
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeTue Nov 18, 2014 7:25 pm
I never removed the pipe when I took my wheel off, cant remember how I did it tho cause it was so long ago
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeTue Nov 18, 2014 7:28 pm
Remove Two Allen Bolts from between the silencers then undo the clamp nut at the front of the silencer it's sort of underneath round the back.
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeTue Nov 18, 2014 7:43 pm
You might want to disconnect the o2 sensor plug if your removing the silencer and placing to one side, It's behind the right side panel just follow the wire from the sensor on the top silencer.
Bigredbus4468
Bigredbus4468
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeTue Nov 18, 2014 8:58 pm
Managed to remove top silencer and O2 sensor. Loosed bottom and got a spanner on the axel nut. Wheel removed. I'm not looking forward to putting it back together or paying another £140 if it can't be plugged. Tyre replaced only a couple of months ago with Michelin commander ggrrr... Thanks Sim.
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeTue Nov 18, 2014 9:02 pm
as long as the tyre is not damaged on the sides you should be able to get it fixed is even better if the hole is in the tread when fixing because the plug fixed bit wont wear down Rear Wheel Removal, Suzuki C800 / M800 3498837457 as the tyre does
if you had had slime or the like in ya tyre it would probably still be ok to ride on ohhh the what if's in life lol hopefully you can have it fixed Rear Wheel Removal, Suzuki C800 / M800 3005623951
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeTue Nov 18, 2014 9:13 pm
Get a plug kit and do it yourself Kev, it won't cost much more than having it plugged and you can throw it in the panniers in case you get another puncture  Rear Wheel Removal, Suzuki C800 / M800 3498837457
Bigredbus4468
Bigredbus4468
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeTue Nov 18, 2014 9:15 pm
I put in ultraseal in repair. Thought it had fixed it but it didn't. Oh well. Might have to clean that out before they plug it.
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeTue Nov 18, 2014 10:24 pm
Ouch! Tyre repair places don't like that stuff  Rear Wheel Removal, Suzuki C800 / M800 594857
Bigredbus4468
Bigredbus4468
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeThu Nov 20, 2014 7:11 pm
Nope they don't. Wouldn't repair. In the end paid £120 for Michelin commander fitted to lose wheel. All back together cheers fellas.
atbarnett
atbarnett
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeSat Sep 12, 2015 8:49 am
Question regarding weight distribution when removing parts such as the rear wheel.  Thanks for posting the above - this is my first machine and I am keen to do a major clean over the winter being able to remove the rear wheel (and seeing how easy it is) is good news.  I have a flat based jack and holds up the bike really nice - when the rear wheel comes off do I need to think how this will effect the balance on the bike and therefore where I position the jack in the first place.  Or any other tip really for jacking up the bike.
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeSat Sep 12, 2015 9:59 am
It's always worth strapping the bike down just to be on the safe side but the bike stays steady enough when removing a wheel, I usually put something under the remaining wheel just to take the weight of any off balance.
atbarnett
atbarnett
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeSat Sep 12, 2015 10:36 am
That makes sense.  Cheers
churchy
churchy
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeTue Jan 03, 2017 4:54 pm
great write up m8 keeps it simple and good detailed photos.
Looking forward to reading more of your posts
gosh
gosh
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeMon Apr 17, 2017 6:46 pm
nice one , clear pics and great for us who havent had to do it yet...must admit i was wondering about removal with a shaftie, was worried  incase drive gearing would lose any fluids ,but put mind at rest and would def tackle  that  job .....NOW...
PostSubject: Re: Rear Wheel Removal, Suzuki C800 / M800   Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeWed Apr 19, 2017 9:01 pm
Piece of cake.  However, I recommend using a proper bike lift that fits under the frame - the wider the bed, the better.  Make sure you mark the exact position of the brake cam on the splines before you remove it - get it wrong & you're going to have to take it off to re-position it
» rzr rear wheel bearing
» Rear Wheel Bearing Cross Ref.
» Rear Wheel Steer.
» How do you remove stuck rear wheel hubs?
» murray widebody steering wheel removal.
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby ardie Fri Nov 15, 2019 7:31 pm
» Saying hello
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby ardie Fri Nov 15, 2019 7:30 pm
» New noises???
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby Dmill1222 Thu Nov 14, 2019 6:14 pm
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby bob gibson Wed Nov 06, 2019 6:39 pm
» Electronic fuel injection
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby 03580 Wed Nov 06, 2019 2:18 pm
» Straight Shots on 2006 C800
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby Tucker Tue Nov 05, 2019 7:57 pm
» Just a little help.
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby silvergriffin21 Mon Nov 04, 2019 6:45 pm
» hi guys
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby ardie Mon Nov 04, 2019 12:07 pm
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby GPDave Mon Nov 04, 2019 9:00 am
» Insurance
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby ardie Sat Nov 02, 2019 12:50 pm
» Chase Williams in Tennessee
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby stingray Fri Nov 01, 2019 10:10 pm
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby Proudtexson Fri Oct 25, 2019 12:29 am
» Hello, ne member from uk
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby ardie Tue Oct 22, 2019 6:44 pm
» Hello, new member from uk
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby stingray Mon Oct 21, 2019 2:42 pm
» VL800 / VZ800 Carb Jetting Guide
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby muppet Sun Oct 20, 2019 8:24 pm
» hi from Onterrible Canada! Formerly from bC Canada !
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby BirdMan Sun Oct 20, 2019 2:09 am
» 1999 vz800 rear light change
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby BirdMan Sun Oct 20, 2019 2:07 am
» VL and VZ exhausts interchangeable?
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby Asmotsat Wed Oct 16, 2019 1:26 pm
» hello from Antalya/TURKEY
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby stingray Thu Oct 10, 2019 11:27 am
» New Guy
Rear Wheel Removal, Suzuki C800 / M800 Icon_minitimeby stingray Thu Oct 10, 2019 11:24 am
