| | How to stiffen up front forks and rear suspension | |
typan Member
| Subject: How to stiffen up front forks and rear suspension Sat Sep 01, 2012 9:28 pm | |
| anyone know how to stiffen up the frontforks on a vl 800 volusia is it a matter of adding more oil etc,also whats the best way to stiffen the rear suspension,i have the spanner from the tool kit but when i tried to turn it a notch or two it was really tough and with there not being much hand room i struggled to even make it move,any ideas guys.thanks in advance | |
| Subject: Re: How to stiffen up front forks and rear suspension Sat Sep 01, 2012 9:50 pm | |
| - typan wrote:
- ....whats the best way to stiffen the rear suspension,i have the spanner from the tool kit but when i tried to turn it a notch or two it was really tough and with there not being much hand room i struggled to even make it move,any ideas guys.thanks in advance
I find the best way to lever the pre-load spanner is with a short bit of pipe slipped over the spanner to lengthen it and get more leverage. | |
| Subject: Re: How to stiffen up front forks and rear suspension Sun Sep 02, 2012 12:44 am | |
| your best bet is remove the battery and box then it's not to bad | |
| | | typan Member
| Subject: Re: How to stiffen up front forks and rear suspension Mon Sep 03, 2012 7:01 am | |
| thanks bluesman an simbo i did what you said and it made it very easy,also changed the coolent at the same time,thanks for the advice. | |
| | | CycleBiker Member
| Subject: Re: How to stiffen up front forks and rear suspension Sat Sep 15, 2012 2:11 pm | |
| If the bike is on a lift then the rear suspension adjustment is easier to turn.
In the front forks you should not add more oil as that could cause a seal to blow but you can replace the oil with a heavier weight oil for stiffer fork action. | |
| Subject: Re: How to stiffen up front forks and rear suspension Sun Sep 16, 2012 10:33 am | |
| The only way to stiffen up the front suspention is to change the internal spacer as per the recent modification thread. LINK | |
| Subject: Re: How to stiffen up front forks and rear suspension | |
