 V&H Cruzers - fitting
Kev Smith
PostSubject: V&H Cruzers - fitting   Fri Jul 19, 2013 3:31 pm
Hi.....I've ordered some V&H Cruzers (with Oxygen sensor fit) which will arrive next week and I'd appreciate some advice; are there any top tips on getting the existing Oxygen sensors out of the original exhaust, will they be cemented in and a bugger to shift.....
Cheers
Kev
PostSubject: Re: V&H Cruzers - fitting   Fri Jul 19, 2013 3:46 pm
The oxygen sensors will screw out and screw into the threaded boss on the new exhausts, it should be an easy enough thing to do, as they are not cemented in.(or should'nt be).
PostSubject: Re: V&H Cruzers - fitting   Fri Jul 19, 2013 4:45 pm
Yeah Kev, just give them a squirt of wd40 half an hour before removing them, they come out fine.
PostSubject: Re: V&H Cruzers - fitting   Fri Jul 19, 2013 5:42 pm
Never ever read of anyone even mentioning having an issue with removing or refitting these
Kev Smith
PostSubject: Re: V&H Cruzers - fitting   Sat Jul 20, 2013 4:38 pm
Many thanks to simbo, lowey and captain crash for your advice on removing oxygen sensors.....cheers
KS
» Fitting longer studs to your VFR hub to take a car wheel
» Driver fitting made simple
» banjo/inverted flare union tee fitting
» Fitting progressive springs
» Brake fitting adapters for wilwood with part numbers
» Bulb sizes
by peardrop3 Yesterday at 12:58 pm
by OldManYam Thu Jan 18, 2018 10:00 pm
