 Optimate 3 charger / battery, possible issue?
Optimate 3 charger / battery, possible issue? Empty
PostSubject: Optimate 3 charger / battery, possible issue?   Optimate 3 charger / battery, possible issue? Icon_minitimeWed Aug 07, 2013 3:37 pm
I was wondering if any one could help with this small problem, a friend of mine has an optimate3 charger plugged into his bike when it is not in use, however recently the charger has been showing differant readings, sometimes it stays charging all the time (it should charge for two hours after being plugged in) other times it shows that the battery is weak other times that the battery is good then it sometimes just stays on desulfate. The battery itself shows no sign of being flat as it starts  his bike with no trouble at all and it runs all the electrics fine. I was wondering if these chargers have a life then fail to work properly after a time, he has used it for about eight years with no problem up to now. Any input on this would be very welcome.
PostSubject: Re: Optimate 3 charger / battery, possible issue?   Optimate 3 charger / battery, possible issue? Icon_minitimeWed Aug 07, 2013 3:55 pm
If I recall Mr I had a similar issue to this but I can't find a post on it so it may be that we discussed it in person. I think that battery is just starting to go down
PostSubject: Re: Optimate 3 charger / battery, possible issue?   Optimate 3 charger / battery, possible issue? Icon_minitimeWed Aug 07, 2013 4:23 pm
You are correct Crash I have had this very same issue.
I keep 3 separate motorcycles plus several spare car and motorcycle batteries topped up by using 2 chargers and have had this issue twice over the last few years. For me it was definitely the battery both times and I know this firstly because I would randomly swap the battery optimisers and would get the same resulting issues with just those 2 batteries. From my own experience what I did notice over time was how quickly they would discharge when under load compared to a properly 100% healthy battery. One of the batteries was even put on a dedicated desulphater by Doc Cox but this was not a long term fix.
So from experience I would guess that the battery is just starting to show the first signs of degeneration but with that said it probably has a lot of serviceable life left in it yet.
PostSubject: Re: Optimate 3 charger / battery, possible issue?   Optimate 3 charger / battery, possible issue? Icon_minitimeWed Aug 07, 2013 4:33 pm
Thanks both of you for your comments, I'll advice him to keep an eye on the battery.
PostSubject: Re: Optimate 3 charger / battery, possible issue?   Optimate 3 charger / battery, possible issue? Icon_minitimeWed Aug 07, 2013 5:13 pm
One other thing with these so called "sealed maintenance free batteries" is that they are lying!
What the actually mean is: you are too stupid to maintain this product and we don't want you too either because then you will throw it away when it shows signs of trouble.
Firstly they are no more maintenance free now than they ever were, they only difference in this one and the one you bought 20 years ago is that they have written maintenance free on it.
These batteries will evaporate the fluid in the cells through the tiny breather hole in just the same as your old batteries did. So it would be worth popping off the long cap on top of the battery and checking the fluid levels. Just pop the cap up with a small flat screwdriver or similar but obviously be as careful doing that as you would with any other battery due to the acid.
PostSubject: Re: Optimate 3 charger / battery, possible issue?   Optimate 3 charger / battery, possible issue? Icon_minitimeWed Aug 07, 2013 5:51 pm
It is a great marketing move to write maintenance free and expect people to buy new.
Good to know they can be refreshed
PostSubject: Re: Optimate 3 charger / battery, possible issue?   Optimate 3 charger / battery, possible issue? Icon_minitimeThu Aug 08, 2013 8:18 am
I have passed on all comments, thanks again for your answers.
» GP3000 - info on Lucky Lark Battery and Coil
» Woody Battery/Amplified Speaker System
» GP 3000 with Light weight Lithium Battery system
» bush battery charging Q?
» Lucky Lark Battery Pack With Audio Amplifier
» First post from Arnold in Idaho
Optimate 3 charger / battery, possible issue? Icon_minitimeby stingray Yesterday at 7:06 pm
» register logon - C'mon in and say hello - I think
Optimate 3 charger / battery, possible issue? Icon_minitimeby stingray Yesterday at 7:03 pm
» SAYING HELLO FROM WINNIPEG, MANITOBA
Optimate 3 charger / battery, possible issue? Icon_minitimeby Takkyu Fri Jun 21, 2019 5:33 pm
» Hello! This is Ed from Wash.,DC
Optimate 3 charger / battery, possible issue? Icon_minitimeby Takkyu Fri Jun 21, 2019 5:32 pm
» Hiyas
Optimate 3 charger / battery, possible issue? Icon_minitimeby Takkyu Fri Jun 21, 2019 5:31 pm
» Newbie
Optimate 3 charger / battery, possible issue? Icon_minitimeby peardrop3 Fri Jun 21, 2019 5:30 pm
Optimate 3 charger / battery, possible issue? Icon_minitimeby Takkyu Fri Jun 21, 2019 5:29 pm
» Ratchet noise from under tank.
Optimate 3 charger / battery, possible issue? Icon_minitimeby goshhub Fri Jun 14, 2019 11:39 pm
» First Time Ever Saw Mr Green
Optimate 3 charger / battery, possible issue? Icon_minitimeby ArnoldinIdaho Fri Jun 14, 2019 9:51 pm
» Hi new here...
Optimate 3 charger / battery, possible issue? Icon_minitimeby OldManYam Tue Jun 04, 2019 10:10 pm
» Hello from Bulgaria
Optimate 3 charger / battery, possible issue? Icon_minitimeby OldManYam Tue Jun 04, 2019 10:08 pm
» Hello from Ipswich
Optimate 3 charger / battery, possible issue? Icon_minitimeby OldManYam Tue Jun 04, 2019 10:07 pm
» VZ800 Charging issue
Optimate 3 charger / battery, possible issue? Icon_minitimeby peardrop3 Mon Jun 03, 2019 2:03 pm
» Hello from Calgary Alberta CANADA
Optimate 3 charger / battery, possible issue? Icon_minitimeby peardrop3 Sun Jun 02, 2019 4:55 pm
» Hi from South Wales
Optimate 3 charger / battery, possible issue? Icon_minitimeby Takkyu Mon May 27, 2019 3:35 pm
Optimate 3 charger / battery, possible issue? Icon_minitimeby ardie Sun May 26, 2019 6:54 pm
» My 2013 M50
Optimate 3 charger / battery, possible issue? Icon_minitimeby ardie Sun May 26, 2019 6:50 pm
» Brake lever!
Optimate 3 charger / battery, possible issue? Icon_minitimeby Shrek Sun May 26, 2019 1:45 pm
» Brake lever!
Optimate 3 charger / battery, possible issue? Icon_minitimeby Shrek Sun May 26, 2019 1:29 pm
» Hi from Calgary, Alberta, Canada! (2000 Maurader VZ800)
Optimate 3 charger / battery, possible issue? Icon_minitimeby Takkyu Sat May 25, 2019 8:36 pm
