 Exhaust Lambda Help
Spunky
PostSubject: Exhaust Lambda Help   Wed Mar 12, 2014 9:03 pm
Hi folks, I've got myself a M800 Intruder and I am currently fabricating some slip-on straight-through pipes.  Now the fabrication isn't an issue, and I've access to a full workshop.  However, when it comes to fitment I was going to drill and tap to fit the lambda sensors - will this be enough to run the bike on, or will I have to play about with the ECU?
Cheers in advance.
Edit: It's an '09 plate
PostSubject: Re: Exhaust Lambda Help   Wed Mar 12, 2014 9:22 pm
Fitting the original or replacement lambda sensor in the newly fabricated exhaust will be fine, without any ECU issues. Either do it the way you have planned or drill a hole and weld a lambda boss on to the newly fabricated pipe and screw the lambda sensor in to it. Failing that what you can do as is often done when fitting aftermarket pipes that do not have lambda bosses in place is simply take the side cover off the right side and cut wire #23 at the ECU & disconnect the lambda sensor from the fitting wire and unplug the wire.
PostSubject: Re: Exhaust Lambda Help   Wed Mar 12, 2014 9:30 pm
 As above.
Spunky
PostSubject: Re: Exhaust Lambda Help   Wed Mar 12, 2014 9:37 pm
Thanks for the help, I'm just going to manufacture a a threaded boss (i believe it's a M12 x 1.5 thread) and fit the sensors back to it.  Cheers folks, once ive got it all done ill post a video.
Second question, I quickly measured the downpipe outside diameter - I got 28.4mm, is this correct?
PostSubject: Re: Exhaust Lambda Help   Wed Mar 12, 2014 9:50 pm
M12x 1.25 pitch for the sensors and why go 28mm down pipe? very restrictive compared to aftermarket zorst.
Spunky
PostSubject: Re: Exhaust Lambda Help   Wed Mar 12, 2014 10:13 pm
I'm using the standard downpipes, got hold of some 64mm (18swg wall thickness) stainless pipe, so im making a a link pipe on the lathe - when i get enough money i'll just buy some nice aftermarket stuff
PostSubject: Re: Exhaust Lambda Help   Wed Mar 12, 2014 10:26 pm
Carry on, I like the sound of stainless pipe's, I'll look forward to seeing your work
Spunky
PostSubject: Re: Exhaust Lambda Help   Wed Mar 12, 2014 10:36 pm
I'm lucky, I'm a metal-basher in the RAF, so I've got hold of some scrap 76mm stainless bar, and I've put together a programme for the CNC lathe to make the link piece(s)... and it's also a damned good job I'm pretty nifty on the old TIG plant too haha
PostSubject: Re: Exhaust Lambda Help   Thu Mar 13, 2014 8:37 am
This is sounding like it will be worth watching, good on you.
It's always good to have the skills that can pay the bills turned towards a hobby.
Exhaust Lambda Help
» Hello from Cheshire.
by johnboss Yesterday at 4:49 pm
» hello all from Somerset
by Chadders Yesterday at 3:49 pm
» Hello from Burlington Ontario, Canada
by peardrop3 Wed May 23, 2018 3:36 pm
» Installing coolant/water temperature gauge . . . . . . (Now Done)
by butcherman Tue May 22, 2018 10:14 pm
» my Suzuki Intruder VZ800M K6 2006 REG
by bagtoracer68 Tue May 22, 2018 2:26 am
» batty battery
by bagtoracer68 Tue May 22, 2018 2:13 am
by bagtoracer68 Tue May 22, 2018 2:11 am
» just wanted to say hello fellow riders
by bagtoracer68 Tue May 22, 2018 2:07 am
» New in Florida
by bagtoracer68 Tue May 22, 2018 2:06 am
» Greetings from Denmark
by bagtoracer68 Tue May 22, 2018 2:05 am
» Hello from Shelley Idaho
by bagtoracer68 Tue May 22, 2018 2:04 am
» Hello from Missouri, USA
by bagtoracer68 Tue May 22, 2018 2:03 am
» Time for a new one?
by bagtoracer68 Tue May 22, 2018 2:01 am
» Hi all
by bagtoracer68 Tue May 22, 2018 1:57 am
» hi everyone. im from kent uk.
by bagtoracer68 Tue May 22, 2018 1:55 am
» Fuel pump don’t come on when I turn the ignition key
by jester29 Thu May 17, 2018 10:20 pm
» 1998 VZ800 MondoDrive 14 Belt Conversion
by bigmal Wed May 16, 2018 9:36 pm
» Powder coat wheels
by captain morgan Mon May 14, 2018 10:28 pm
» Exhausts
by captain morgan Mon May 14, 2018 10:19 pm
» F1 light flashing.
by Gazza66 Fri May 11, 2018 7:33 pm
