 Rear Shock for M800
ROBBIE_B
PostSubject: Rear Shock for M800   Sat Mar 22, 2014 5:53 pm
I have a 2012 M800, love the bike except forit being "poor over the bumps"
Tried different settings on rear shock suspension - but no improvement, have it on the softest.
When I ride over large bump or ridge in the road - I really feel it in the small of my back.
I am thinking of fitting a different rear suspension unit.
Has anone done this - Any recommendations
PostSubject: Re: Rear Shock for M800   Sat Mar 22, 2014 6:22 pm
Your back must be extremely bad to say the #1 setting (softest) makes no improvement.
I would say that the suspension does not need changing if you already have it on #1, the seat does but others may think differently.
DaveC
PostSubject: Re: Rear Shock for M800   Sat Mar 22, 2014 6:36 pm
Tyre pressure's ?
ROBBIE_B
PostSubject: Re: Rear Shock for M800   Sun Mar 23, 2014 9:07 am
Previously I used 29 psi front & 36 rear. Now using 29/34 rear
PostSubject: Re: Rear Shock for M800   Sun Mar 23, 2014 3:11 pm
Do you not have the same issue on the Triumph tiger?
DaveC
PostSubject: Re: Rear Shock for M800   Sun Mar 23, 2014 4:37 pm
Have I seen something on here, where some of you guys use 32 front 38 rear, or am i dreaming
ROBBIE_B
PostSubject: Re: Rear Shock for M800   Sun Mar 23, 2014 5:27 pm
No - The Triumph Tiger is very good over the bumps, although I have it set fairly soft
PostSubject: Re: Rear Shock for M800   Sun Mar 23, 2014 7:12 pm
If your back is that bad I don't think you will get it anywhere near as acceptable to you as your Tiger is cause the shocks will be nowhere near as changeable and spongy as the Tiger is cause its an adventure tourer and it is designed to do a very different job
PostSubject: Re: Rear Shock for M800   Sun Mar 23, 2014 7:13 pm
I'd be thinking it's the seating position on the M800, your sat right on your tail bone, so any shock just goes up the back instead of taking a bit with your legs or under the body, like on a more upright bike, an aftermarket shock would be in the region of £300+ for a decent one (if one is readily available?) I'd be looking into having the seat foam replaced with something a little softer or even a cut out where the tail bone rests to cure the problem.
PostSubject: Re: Rear Shock for M800   Sun Mar 23, 2014 7:20 pm
Or do what Dave (Mr Intruder) did a few years ago and take the seat cover off and add some extra foam to the whole of the top of the stock seat before restapling the cover back on
TaurusTuga
PostSubject: Re: Rear Shock for M800   Sun Mar 23, 2014 8:20 pm
Or also Mr. Alfie92 did but in gel:
http://www.suzuki800.com/t3564-gel-pad-seat-conversion?highlight=seat+M800
Really cool
PostSubject: Re: Rear Shock for M800   Sun Mar 23, 2014 8:53 pm
I think Alfie's way is a great way, really impressed me.
PostSubject: Re: Rear Shock for M800   Mon Mar 24, 2014 3:33 pm
Rob the problem may be the way the seat is made,if you look at the rear fastening mount on your seat you will find it sticks up into your tail bone,what I done was took the seat cover off,then took the fastener off and made it flush,it may be worth while looking into to it to see if a little mod might work,if it is the riding position,or like me get a gel pad and fit as well.Just an idea.
ROBBIE_B
PostSubject: Re: Rear Shock for M800   Tue Mar 25, 2014 5:22 pm
Thanks Alfie, That sounds very logical I will have a look under the seat, I had not considered a gel pad.
What tyre pressures do you use ?
PostSubject: Re: Rear Shock for M800   Tue Mar 25, 2014 9:19 pm
Rated pressures are 29/36 normally check once a week if I remember.
Rear Shock for M800
» Radflo 2.5 Suspension System - from Overland Warehouse
» Suspension Choice
» Commander rear seat and cage.
» RZR rear seat and cage.
» rhino is pissing me off
» Ideas 2001 VL800
by ASantos Thu Oct 18, 2018 9:42 pm
» Hello from Canada
by ardie Thu Oct 18, 2018 3:46 pm
» Hallo from greece
by ardie Thu Oct 18, 2018 3:40 pm
» Hello from Cambridge
by ardie Thu Oct 18, 2018 3:37 pm
» Hi everyone!
by peardrop3 Tue Oct 16, 2018 7:01 pm
» Elecrical issue
by ardie Tue Oct 16, 2018 5:43 pm
» Sidestand switch faulty?
by Moggie Mon Oct 15, 2018 10:14 pm
» Custom Suzuki Intruder 800 by Northworks motorcycles
by ardie Mon Oct 15, 2018 10:03 pm
» Ignition problem VL800 K5
by Badger Sat Oct 13, 2018 4:58 pm
» Year of mamufacture
by jder Sat Oct 13, 2018 11:19 am
» Amazing Trip in the Rocky Mountains, Enjoy.
by cheekyscouser Wed Oct 10, 2018 12:46 am
» Getting back on it!
by peardrop3 Tue Oct 09, 2018 10:43 am
» Hello all
by stingray Tue Oct 09, 2018 10:33 am
» After market speedometer console
by Mick1969 Fri Oct 05, 2018 3:25 pm
» Fuel consumption with 14:1 Diff
by peardrop3 Thu Oct 04, 2018 4:03 pm
» Saddlemen Profiler on Suzuki Intruder C800 / VL800
by ardie Wed Oct 03, 2018 10:54 pm
» CLUTCH SLIPPING STILL
by fat intruder Wed Oct 03, 2018 7:52 pm
» Hi there New member here
by fat intruder Wed Oct 03, 2018 7:43 pm
» Sachs Roadster 800
by fat intruder Wed Oct 03, 2018 7:40 pm
» Hi new member and new to bike
by fat intruder Wed Oct 03, 2018 7:33 pm
