 Dynojet Power Commander V or FI Tuner Pro
namery
namery
Dynojet Power Commander V or FI Tuner Pro Empty
PostSubject: Dynojet Power Commander V or FI Tuner Pro   Dynojet Power Commander V or FI Tuner Pro Icon_minitimeFri Apr 25, 2014 11:42 am
hi all
i am think to install now on my bike one of these devices, but what are really the differences between this two?? which is better?? both can make for me a reduction of fuel consumption without lose power horses???
PostSubject: Re: Dynojet Power Commander V or FI Tuner Pro   Dynojet Power Commander V or FI Tuner Pro Icon_minitimeFri Apr 25, 2014 1:03 pm
I have the Fi2000 Pro on my Trike. I like it because there are not any adjustments to make. It is designed to handle any configuration. I don't know about improvement in fuel consumption.
PostSubject: Re: Dynojet Power Commander V or FI Tuner Pro   Dynojet Power Commander V or FI Tuner Pro Icon_minitimeFri Apr 25, 2014 6:24 pm
As far as I know the FI2000 Pro when fitted will adjust to any alterations you make bit by bit. So if you have a stock bike and you add an aftermarket exhaust and then a hi flow filter and then change one of them or take one off it will make the adjustments automatically itself
The Power Commander it has three adjust pots that you have to turn depending on the setup, easy really
If you have lots and lots of money and you dont want to turn even a pot screw then buy the FI2000 Pro. If you don't have lots and lots of money and you are happy to turn a pot screw then buy the Power Commander.
If they are both setup properly then one will not make the bike run better than the other. It all depends on what you are happy to spend on your bike. If both of them cost the same to buy then I would buy the FI2000 but they dont so I would have to buy the Power Commander
PostSubject: Re: Dynojet Power Commander V or FI Tuner Pro   Dynojet Power Commander V or FI Tuner Pro Icon_minitimeFri Apr 25, 2014 6:53 pm
It helps to have a Daughter with money and loves her Dad. She bought my Fi2000 Pro. I like it because it takes care of any changes I might make. Also takes care of Temp changes and Atmospheric changes.
PostSubject: Re: Dynojet Power Commander V or FI Tuner Pro   Dynojet Power Commander V or FI Tuner Pro Icon_minitimeFri Apr 25, 2014 6:59 pm
I would buy it for a fact but I dont want to go to  Dynojet Power Commander V or FI Tuner Pro 53847  for robbing a bank or mugging an old lady  Dynojet Power Commander V or FI Tuner Pro 3307848339
PostSubject: Re: Dynojet Power Commander V or FI Tuner Pro   Dynojet Power Commander V or FI Tuner Pro Icon_minitimeFri Apr 25, 2014 7:07 pm
I think the power commander can be programmed manually or with a lap top, to suit the set up of the bike, ie exhaust, airflow etc.
PostSubject: Re: Dynojet Power Commander V or FI Tuner Pro   Dynojet Power Commander V or FI Tuner Pro Icon_minitimeFri Apr 25, 2014 7:28 pm
The Power Commander V is a good unit with downloadable maps for various stages of tune, it also has a port for an auto tune facility which plugs into the o2 sensor ports and adjusts the mixture accordingly by itself (it's about an extra $200 though), The FI tuner Pro isn't programmable or manually adjustable, It's like a PC-V with auto tune already fitted so the mixture is always correct whatever set up you use, Personally I'd go for the Tuner Pro because it adjusts itself to whatever you throw at it and I've got one  Dynojet Power Commander V or FI Tuner Pro 852880  Neither will save fuel though, More likely to use more, as the bike won't be running lean any more like it does from the factory.
PostSubject: Re: Dynojet Power Commander V or FI Tuner Pro   Dynojet Power Commander V or FI Tuner Pro Icon_minitimeFri Apr 25, 2014 11:25 pm
Yep a tuner is a must really, lean running from the factory is there only cause of the EU rules on pollution and sadly will reduce power a fraction to as well as the pollution a little. Flippin Eurotwats
PostSubject: Re: Dynojet Power Commander V or FI Tuner Pro   Dynojet Power Commander V or FI Tuner Pro Icon_minitimeSat Apr 26, 2014 12:55 am
Same environuts over here also CC. Dynojet Power Commander V or FI Tuner Pro 437349  Dynojet Power Commander V or FI Tuner Pro 453769
PostSubject: Re: Dynojet Power Commander V or FI Tuner Pro   Dynojet Power Commander V or FI Tuner Pro Icon_minitimeSat Apr 26, 2014 8:46 am
Buy what your wallet is happy about, they are all easy to set up.
namery
namery
PostSubject: Re: Dynojet Power Commander V or FI Tuner Pro   Dynojet Power Commander V or FI Tuner Pro Icon_minitimeWed Apr 30, 2014 10:26 am
look at this two software looks very very similar
Dynojet Power Commander V or FI Tuner Pro Fitune10
namery
namery
PostSubject: Re: Dynojet Power Commander V or FI Tuner Pro   Dynojet Power Commander V or FI Tuner Pro Icon_minitimeWed Apr 30, 2014 10:27 am
Dynojet Power Commander V or FI Tuner Pro Commad10
namery
namery
PostSubject: Re: Dynojet Power Commander V or FI Tuner Pro   Dynojet Power Commander V or FI Tuner Pro Icon_minitimeWed Apr 30, 2014 10:29 am
but on powercommander V i see more rpm like 500-750-1000-1250-1500-1750-2000-2250-2500 and on fi tuner it has 1000-1500-2000-2500
is that really means that i have more control in the ECU??
PostSubject: Re: Dynojet Power Commander V or FI Tuner Pro   Dynojet Power Commander V or FI Tuner Pro Icon_minitimeWed Apr 30, 2014 7:57 pm
I do apologise Raul, In my post above I was referring to the Cobra FI tuner pro, not the Healtech FI tuner Pro, Can the Healtech be compared to the PowerComander? The PCV is nearly twice the price as the Healtech, Yes it's adjustable in 250 rpm increments as opposed to 500 rpm increments, But how much do the values actually change over 250rpm?.
namery
namery
PostSubject: Re: Dynojet Power Commander V or FI Tuner Pro   Dynojet Power Commander V or FI Tuner Pro Icon_minitimeMon May 05, 2014 8:52 am
yes, that is what i think, the price is really too much diferent, but the performance looks very similar. really i dont know which one will be better
» Sold, Sold--Power Commander III for 2004 Polaris 700 EFI
» Commander rear seat and cage.
» New Can-AM Commander 1000cc SXS
» Power Mods ????
» Rhino Vs. Commander 1000
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby ardie Yesterday at 6:49 pm
» Crash Bars
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby Ish992019 Sun Feb 16, 2020 9:26 pm
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby pledge Sun Feb 16, 2020 3:29 pm
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby RonB58 Fri Feb 14, 2020 5:59 pm
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby ardie Fri Feb 14, 2020 11:42 am
» New member in Florida
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 6:08 pm
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:51 am
» VS1400 rear end on a VS750
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:42 am
» Led turn signals!
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby mhicks2517 Tue Feb 11, 2020 5:38 pm
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby DickB Tue Feb 11, 2020 12:05 pm
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby steve co Fri Feb 07, 2020 2:03 pm
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby steve co Fri Feb 07, 2020 1:40 pm
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby steve co Fri Feb 07, 2020 1:28 pm
» Newby
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby malone55 Mon Feb 03, 2020 1:58 pm
» Hello from Stockholm
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby stingray Mon Feb 03, 2020 9:49 am
» Glad to be here!
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby stingray Mon Feb 03, 2020 9:48 am
» Hey Guys
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby oldtom Sun Feb 02, 2020 12:49 pm
» White walls
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby ardie Mon Jan 27, 2020 7:52 pm
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby creol Sat Jan 25, 2020 8:24 am
» Back in the saddle.
Dynojet Power Commander V or FI Tuner Pro Icon_minitimeby ardie Fri Jan 24, 2020 8:13 pm
