 Naked jugs mod.
PostSubject: Naked jugs mod.    Wed May 28, 2014 4:06 pm
I had some time last night and this morning, while adjusting the grill for pulled pork, and thought why not use the waiting time to complete the "naked jugs" air intake mod.
The filter is made from Uni Filter BF-1 filter foam, cut a strip of 34cm X 7,5cm and glued with rubber cement, the top is made by tracing around the throttle body with a pen and paper, then cut to the exact shape.
The filter is oiled with some leftover K&N filter oil I had on the shelf.
There are two vacuum sensor mounted on the original air duct and they are zip tied to the frame.
The temperature sensor from the original airbox is mounted just in front of the filter, to pickup the exact temp.
PostSubject: Re: Naked jugs mod.    Wed May 28, 2014 5:02 pm
Wow Kim your on a mission lately, your making some ace changes to your bike and its becoming cooler than the north pole. Fabulous write up and well explained, that will be copied by many people over time. I know its been a known mod for years but your thread is simple and easy to follow
PostSubject: Re: Naked jugs mod.    Wed May 28, 2014 6:22 pm
Nice job Kim! I like the idea of a uni filter and naked jugs   One to copy for sure
PostSubject: Re: Naked jugs mod.    Wed May 28, 2014 6:33 pm
Sorry, I stopped reading after "naked jugs"
PostSubject: Re: Naked jugs mod.    Wed May 28, 2014 7:12 pm
Very interesting indeed, never thought of such a thing was possible.
PostSubject: Re: Naked jugs mod.    Wed May 28, 2014 7:50 pm
Well done Kim, very informative thread & well explained. An inspirational mod that is a very good looking after the fact, shows the head's off nicely with the fugly stock air filter removed.
PostSubject: Re: Naked jugs mod.    Wed May 28, 2014 8:23 pm
a) why it changed colour? (did oil do that?)
b) so is it left exposed like that and then squashed with fuel tank?
PostSubject: Re: Naked jugs mod.    Wed May 28, 2014 10:02 pm
Good job well done and explained.
PostSubject: Re: Naked jugs mod.    Thu May 29, 2014 8:21 am
a) yep
b) there is plenty of room under the tank, it is squashed a bit but not much. People usually make the filter 10cm high instead of 7,5cm, but I think that is for the C800.
PostSubject: Re: Naked jugs mod.    Thu May 29, 2014 9:39 am
I forgot to add a picture of the bike after the mod, so here it is.
It is great to not have that big box pressing against the leg, and I think it looks nice too.
PostSubject: Re: Naked jugs mod.    Thu May 29, 2014 3:16 pm
That looks so much cleaner
PostSubject: Re: Naked jugs mod.    Thu May 29, 2014 3:47 pm
Looking good Kim.
PostSubject: Re: Naked jugs mod.    Thu May 29, 2014 5:00 pm
Looks good!
PostSubject: Re: Naked jugs mod.    Thu May 29, 2014 7:35 pm
My goodness that does look good without the filter sticking out in the breeze!
Doc Cox
The Nutty Professor
PostSubject: Re: Naked jugs mod.    Thu May 29, 2014 8:40 pm
Excellent job Kim, really tidys up the engine, looks much cleaner, have you thought of a couple of ducting pipes to put some extra cool air onto the filter to avoid heat soak, and should be possible to do it without them showing, great instructable    regards Doc Cox
PostSubject: Re: Naked jugs mod.    Thu May 29, 2014 9:33 pm
Doc Cox wrote:
...have you thought of a couple of ducting pipes to put some extra cool air onto the filter to avoid heat soak, and should be possible to do it without them showing...
   That is a great idea, I'll look into it.
PostSubject: Re: Naked jugs mod.    Thu May 29, 2014 9:36 pm
Good idea Doc
PostSubject: Re: Naked jugs mod.    Fri May 30, 2014 10:08 am
Looking good kim, real good. I do agree with Doc, a cool air induction pipe or pipes would be an extra blessing with that mod.
PostSubject: Re: Naked jugs mod.    Fri May 30, 2014 11:27 am
looks good and as usual great ideas from site members
22Reed
PostSubject: Re: Naked jugs mod.    Sun Jan 18, 2015 4:58 pm
looks awesome.... do this mod need powercommander3`? read that somewhere!!!??
PostSubject: Re: Naked jugs mod.    Sun Jan 18, 2015 5:23 pm
As I understand it, you can change either the intake or the exhaust without needing a new fuel processor.
But if you change both the intake and put on a new exhaust, or drill your exhaust, you need a fuel processor, as the stock one can't compensate for the added flow.
PostSubject: Re: Naked jugs mod.    Sun Jan 18, 2015 5:40 pm
DocSjulle wrote:
As I understand it
Correct
PostSubject: Re: Naked jugs mod.    Sun Jan 18, 2015 6:35 pm
Good job Kim
inferis
PostSubject: Re: Naked jugs mod.    Fri Feb 24, 2017 12:06 pm
Friends, I'm new here, and I was left with a doubt in this process ... where did this air tube go? I did not understand where he was arrested, and was put another filter on the end of it.
And this is the simplest and most beautiful modification I've ever seen to Boulevard. Congratulations!!!
PostSubject: Re: Naked jugs mod.    Fri Feb 24, 2017 4:23 pm
It's an engine breather and it goes into the back of the standard airbox, put a little filter on it and tuck it out of the way, you might get a little oil dripping from it from time to time if you do short trips.
inferis
PostSubject: Re: Naked jugs mod.    Fri Feb 24, 2017 6:17 pm
thanks!
understand. So I just need to put filter in three places? In these of the photo below:
Will I have something like that?
PostSubject: Re: Naked jugs mod.    Fri Feb 24, 2017 8:06 pm
I think 2 & 3 are the same hose routed to different places, 2 having a catch can for any oily residue that comes from the hose and 3 with a washable filter. I only seem to remember 1 engine crankcase breather going to the back of the air box? double check to be on the safe side
inferis
PostSubject: Re: Naked jugs mod.    Wed Mar 01, 2017 4:23 pm
When I remove the tank and the filter, I'll be sure. thank you. thank you
inferis
PostSubject: Re: Naked jugs mod.    Thu Mar 02, 2017 1:50 pm
Guys ... anyone had or could have any problem using this foam filter? Can this cause a motor problem? Just to know
PostSubject: Re: Naked jugs mod.    Thu Mar 02, 2017 8:38 pm
The only comment I can make is to look after the filter, if it starts to disintegrate it will get sucked into the carbs and make one hell of a mess.
PostSubject: Re: Naked jugs mod.    Thu Mar 02, 2017 8:42 pm
I can't see any problems? Only thing I could think of is if you used a foam that was too flimsy or not suitable for the job and it got sucked into the throttle body.
ps. as Andrew just stated above
Badger
PostSubject: Re: Naked jugs mod.    Fri Mar 03, 2017 12:20 pm
The only problem I can see, is that you loose approximately 10% bling.
PostSubject: Re: Naked jugs mod.    Fri Mar 03, 2017 4:55 pm
Not a problem for us that prefer black !!!!
rossmofo
PostSubject: Re: Naked jugs mod.    Sat Apr 15, 2017 9:47 pm
My bikes been like this for about 10k miles with no problems but as a precaution at the time I made up a wire cage that sits over the throttle bodies to prevent the foam filter being sucked into throttles. I made it from one continuous wire shaped and woven with pliers and patience. Also I would never run this mod without an uprated fuel processor.
Naked jugs mod.
» Welcome naked.john
» American Pie 5: The Naked Mile (2006) DVDrip
» 30 half-naked musclemen preparing for bizarre orgy called Royal Rumble
» Todays daily Mila Kunis naked thread
» Naked Sushi!
» Hey Guys
by ardie Wed Dec 05, 2018 1:19 am
by peardrop3 Tue Dec 04, 2018 4:40 pm
by peardrop3 Tue Dec 04, 2018 4:37 pm
» Newby for RSA
by ardie Mon Dec 03, 2018 11:51 pm
» Sachs-Biker... Hello from Germany
by ardie Mon Dec 03, 2018 11:50 pm
» New to the V twin thing.....
by ardie Mon Dec 03, 2018 11:48 pm
» Hi all
by Paul53 Sun Dec 02, 2018 9:18 am
» Sachs Roadster 800
by peardrop3 Tue Nov 27, 2018 1:29 pm
» Sachs Roadster 800 porn
by adilmon Sun Nov 25, 2018 7:30 pm
» Fitment VZ800 -08 & Intruder 125cc -02
by jan1 Fri Nov 23, 2018 12:51 pm
» Greetings from Hong Kong!
by ardie Wed Nov 21, 2018 10:06 pm
» Greetings From the Holly Land!
by ardie Wed Nov 21, 2018 10:05 pm
» Metzeler tyres in M800!?
by felipemazzino Wed Nov 21, 2018 4:23 am
» Greetings and Salutations from Ontario Canada
by ardie Tue Nov 20, 2018 1:57 am
» hi all
by OldManYam Sat Nov 10, 2018 8:39 pm
» Ideas 2001 VL800
by Wiggo Sat Nov 10, 2018 5:24 pm
» Innovv K2 cameras fitted to C800
by peardrop3 Wed Nov 07, 2018 2:04 pm
» Clutch Lever Problem
by Badger Sun Nov 04, 2018 8:41 pm
» Custom Suzuki Intruder 800 by Northworks motorcycles
by onion1892 Sun Nov 04, 2018 2:15 pm
» naked jugs
by mally Sun Nov 04, 2018 5:58 am
