| | Replacing Clutch Cable VZ800 | |
ippikin Member
| Subject: Replacing Clutch Cable VZ800 Wed Dec 25, 2013 11:07 pm | |
| I would like to replace my clutch cable before a big trip next year (just in case). Has anyone done this?....... the connection at the engine end looks a bit complicated. Is it simple? Thanks and Merry Christmas! | |
| Subject: Re: Replacing Clutch Cable VZ800 Thu Dec 26, 2013 7:57 pm | |
| Simple Grob, not a concern at all. Take your time & all will become clear. | |
| Subject: Re: Replacing Clutch Cable VZ800 Thu Dec 26, 2013 8:22 pm | |
| No worries grob you will be fine doing that | |
| | | NotesNut Member
| Subject: Re: Replacing Clutch Cable VZ800 Thu Jun 19, 2014 4:36 pm | |
| Do you have to remove the fuel tank? Looks like the cable sits on the inside of the frame under the tank....
Need to do mine tomorrow (it snapped today).
G | |
| Subject: Re: Replacing Clutch Cable VZ800 Thu Jun 19, 2014 5:19 pm | |
| | | NotesNut Member
| Subject: Re: Replacing Clutch Cable VZ800 Thu Jun 19, 2014 5:55 pm | |
| | | NotesNut Member
| Filled it 5 minutes before the cable snapped! | |
| Subject: Re: Replacing Clutch Cable VZ800 Thu Jun 19, 2014 6:37 pm | |
| It's only 3 gallon Graeme it's not that heavy | |
| | | NotesNut Member
| Subject: Re: Replacing Clutch Cable VZ800 Thu Jun 19, 2014 7:20 pm | |
| - simbo wrote:
- It's only 3 gallon Graeme it's not that heavy
Hmmm.....*thinks of witty reply* :7348: | |
| | | NotesNut Member
| Subject: Re: Replacing Clutch Cable VZ800 Thu Jun 19, 2014 8:55 pm | |
| Dumb question time.....
On the Virago's I had, I had to drain the tank as when you took the hoses off the underside it all came out.
Looking at the removal instructions for the M800 it doesn't mention draining the tank. However, I would need to disconnect the fuel feed hose - which I am assuming will have the same effect (all my lovely paid-for fuel will come out...
Please correct me if I am wrong...
Cheers
G | |
| Subject: Re: Replacing Clutch Cable VZ800 Thu Jun 19, 2014 8:58 pm | |
| Fuel will stay in the tank, completely different setup to the older yamaha virago
Last edited by captain crash on Thu Jun 19, 2014 9:01 pm; edited 1 time in total | |
| | | NotesNut Member
| Subject: Re: Replacing Clutch Cable VZ800 Thu Jun 19, 2014 9:00 pm | |
| I am assuming its because the pump isn't working? | |
| | | NotesNut Member
| Subject: Re: Replacing Clutch Cable VZ800 Thu Jun 19, 2014 9:01 pm | |
| Yep, thats about it | |
| Subject: Re: Replacing Clutch Cable VZ800 Thu Jun 19, 2014 10:02 pm | |
| You'll get about a thimble full coming out so might be wise putting a rag over the cylinders. | |
| Subject: Re: Replacing Clutch Cable VZ800 Thu Jun 19, 2014 10:52 pm | |
| Graeme a tip for taking the tank off,what I do is take the console of the tank first 3 small fixings,leave the wiring connected and place it out of the way towards your forks.Then when you lift the tank you have more room underneath to get at the petrol feed,it is easy to release by gripping the two lugs and pulling down,as stated by Sim you will only loose a small amount of petrol,the only other connection is the electrical plug to the fuel pump. | |
| | | NotesNut Member
| Subject: Re: Replacing Clutch Cable VZ800 Thu Jun 19, 2014 10:55 pm | |
| Cheers guys - you are all invaluable! | |
| Subject: Re: Replacing Clutch Cable VZ800 | |
