 Removing the catalytic convertors?
mick9264
PostSubject: Removing the catalytic convertors?   Sun Jun 29, 2014 9:24 pm
Hi all, anyone removed the cats on a FI model? as I understand, this will not light the FI light up and will sound better and give a bit more power or so I'm told by a car mechanic. Just thinking aloud at the moment but food for thought!
PostSubject: Re: Removing the catalytic convertors?   Sun Jun 29, 2014 10:06 pm
I can't see there being any noticeable gains Mick?
mick9264
PostSubject: Re: Removing the catalytic convertors?   Sun Jun 29, 2014 10:10 pm
Bugger it then!
PostSubject: Re: Removing the catalytic convertors?   Mon Jun 30, 2014 8:19 am
Mick we don't remove them, but members do remove there use though. They do it when looking for a better louder sound by belting a pointed rod up the center of the pipes which put a hole in the two plates that are half way up the pipes or another way of describing it, at the top section of the rear muffler.
Doc Cox
The Nutty Professor
PostSubject: Re: Removing the catalytic convertors?   Mon Jun 30, 2014 4:30 pm
Hi Mick, if you remove the cat it should help the engine breathe easier, it is surprising how restrictive they are and heavy, if you do that and fit more of a free breathing exhaust have a look at Mr I,s section on EFI boosting, also an exhaust that would look OK and is easy to de-restrict are the shotgun style ones off Harley's, will be doing an instruct able on these when we get back as I have a couple of these knocking about in the spares caravan and they are reasonably cheap to buy.
mick9264
PostSubject: Re: Removing the catalytic convertors?   Mon Jun 30, 2014 6:22 pm
Hi, I like the standard look but a bit more of a fruity sound, I have already spiked the exhaust but stopped at the cats as I'm a coward, bike seems better for it I have to say. I will try to man up and poke a stick through the cats and try to remove them completely when I get chance. I will have a mooch at the harley pipes though! Thanks for the reply.
mick9264
PostSubject: Re: Removing the catalytic convertors?   Mon Jun 30, 2014 9:46 pm
spoke to a pal of mine down at the shooting range and he said if the lambda sensor is behind the cat it could/should trigger a fault code but looked a bit confused when I told him that after market zoists don't have cats and don't trigger the FI light. he also said the best way to remove the cat is with a masonary drill as they are made of ceramic! you learn something new every day
PostSubject: Re: Removing the catalytic convertors?   Mon Jun 30, 2014 10:50 pm
There'll be no problems with the FI light if you remove the cat's, they're after the lambda sensors and the sensors only read the unburnt fuel/air ratio and send signals back to the ecu to lean things out accordingly, I'm not sure on noise improvement? but I still don't think you'll notice any performance gains by removing them but I'll be interested in your findings
mick9264
PostSubject: Re: Removing the catalytic convertors?   Mon Jun 30, 2014 10:54 pm
Cheers Sim, that's if I grow a pair and decide to give them a battering! Still scared!
PostSubject: Re: Removing the catalytic convertors?   Mon Jun 30, 2014 11:30 pm
Hi Mick,
it sounds like you are getting to 'crunch point' .... either 'rod the cat' (so to speak) or look at aftermarket pipes. (Or stay as you are).
I think the straight-shots look good on cruisers.
   Yam
PostSubject: Re: Removing the catalytic convertors?   Tue Jul 01, 2014 9:44 am
a length of 8 or 10mm thread sharpen the end with a angle grinder knock it down through all the plates in exhaust can be done nice and slowly while being in total control best to use a club hammer because of the weight of hammer you don't have to wack it just slowly bang it through thread is the best thing to use as if it feels stuck you can use mole grips to turn it out (like a screw) all so it's cheap to bye and normally comes in meter lengths from all the usual DIY shops I've done it to 3/4 bikes I have had in the past without any problems
mick9264
PostSubject: Re: Removing the catalytic convertors?   Tue Jul 01, 2014 6:57 pm
Hi, I stopped at the cats as I wasn't sure if it would make a difference, I used a 20mm drawn steel bar which I sharpened in my lathe and it breezed through the plates with very little effort. I was going to drill the cats out but wanted to hear off someone who had already done it in case I made a bollocks of my pipes. She sounds better for the mod especially under load and is still quiet on tickover but with a deeper tone. Cheers!
» newby
by Skidalot Today at 5:00 pm
» vs1400 drive mod
by G.Terence Today at 9:54 am
» VL800 C800 ENGINE
by Wiggo Today at 8:38 am
» VZ800 Compression question
by v-twin Sat Feb 17, 2018 9:05 pm
» Powder coat wheels
by peardrop3 Sat Feb 17, 2018 7:30 pm
» Gaskets thickness ?
by grumpy grandad Wed Feb 14, 2018 5:15 pm
» 2006 TO 2016 ENGINE SWAP
by simbo Tue Feb 13, 2018 8:43 pm
» VS 750 rat bike
by grumpy grandad Tue Feb 13, 2018 5:57 pm
» Hi All
by ardie Tue Feb 13, 2018 4:04 pm
» Hello from US
by ardie Sun Feb 11, 2018 6:58 pm
» newbee
by stingray Sun Feb 11, 2018 3:42 pm
» Hello from New Zealand
by stingray Sun Feb 11, 2018 3:35 pm
» Wider Angle Mirror Upgrade
by bigmal Sat Feb 10, 2018 6:34 pm
» Fitting additional on/off light switch
by v-twin Fri Feb 09, 2018 7:49 am
by simbo Tue Feb 06, 2018 9:19 pm
» Halogen/LED Headlamp Upgrade?
by simbo Mon Feb 05, 2018 7:56 pm
» exhaust seal
by mally Sat Feb 03, 2018 3:24 pm
» Starter motor switch jammed
by v-twin Fri Feb 02, 2018 8:50 pm
» Battery Replacement Conundrum
by bagtoracer68 Mon Jan 29, 2018 3:18 am
» Home-Made Rotor Resurfacing (Read "Red-Neck Refurb!")
by bagtoracer68 Mon Jan 29, 2018 3:14 am
