 seized pilot screw & where to buy jets?
EazyDuz
EazyDuz
seized pilot screw & where to buy jets? Empty
PostSubject: seized pilot screw & where to buy jets?   seized pilot screw & where to buy jets? Icon_minitimeTue Jul 01, 2014 3:53 pm
I have a seized pilot screw in the carb and the head is ruined. I was wondering if the screw pokes out in the float chamber so I could get some vice grips on it from the inside. Is that how it works? If not how else can I get it out?
Also, where can I buy jets in the UK for the carb, and are main jets universal for mikuki carbs?
Lastly does anyone know the thread size and pitch and length of the screws that hold the float bowl on?
Thanks
Two-Bears
* VZ Guru *
Two-Bears
PostSubject: Re: seized pilot screw & where to buy jets?   seized pilot screw & where to buy jets? Icon_minitimeWed Jul 02, 2014 8:41 am
Hellon EasyDuz,,,
It`s a bugger when that happens,, the pilot screw/mixture screw is a solid screw and slightly recessed and no they won't be poking out inside the carb so no using your mole grips. I don't understand how it could seize as it ought not be tight, it has a taper on the end to meter fuel and a spring between it and the carb body to put tension on it to prevent it vibrating in and out when the engine is running so putting the adjustment out,, it should be in the region of two and a half turns out from lightly seated.
I`ve used this method of removing stuck/seized solid carb screws in the past,, with a steady hand drill a very small hole down the centre of the screw ( its brass so should drill easily) 5mm or so and then use the Tang end of a small file ( I use fine jewellers or modelling files) and lightly tap it into the hole you just drilled ( the hole being round and the file Tang being square or triangular ) it should grip the screw,, you then use your mole grip or pliers to grip the end of the file and keeping pressure on it short sharp anti-clockwise motion to shock the screw and hopefully it will free off,,, heating the carb body by immersing in hot water for a time would also help,,, take care with the file though mate as they are very hard yet brittle and can snap easily.
I use these for carb jets,,
http://www.motocarb.com/
But you can get them many places including E-bay
I recommend you use genuine  Mikuni jets for this reason,, Mikuni jets and after market jets tend to be marked and categorised differently e.g, a Mikuni N100.604# 105 Is marked according to its flow of fuel ( its flow rate) that is 105=105 cc of fuel per minute ware as for example DynoJet are marked according to the diameter of the hole through the middle of the jet so a DJ150 = 1.5 mm diameter. Another example is DynoJets have flat machined surfaces ware as Mikuni jets are chamfered on the inside opening of the threaded end so there are physical differences as well ( I have a chart some ware with cross references)
CARB SCREWS THREADS
8 x 4mm both float bowl
4 x 5mm top cover
4 x 4mm top cover
2 x 3mm needle plate
Measure the length and you can get them anyware and yes even E-bay, I recommend stainless steel cap head then you can use an allen key.
These are the sizes for a marauders carb screws so I guessing they are the same.
I also have made an assumption that the vl800 has a similar pilot screw setup to the VZ800.
Hope this is of some help mate and good luck.
EazyDuz
EazyDuz
PostSubject: Re: seized pilot screw & where to buy jets?   seized pilot screw & where to buy jets? Icon_minitimeWed Jul 02, 2014 12:08 pm
Thanks a lot for the info. Motocarb looks like a good site too
» Beartracker Jetting Question
» TGWTMBOFS- Phoenix Coyotes/Winnipeg Jets
» seized briggs
» Rescue a Downed Pilot
» An old Irish WW2 Spitfire Pilot
seized pilot screw & where to buy jets? Icon_minitimeby ardie Yesterday at 6:49 pm
» Crash Bars
seized pilot screw & where to buy jets? Icon_minitimeby Ish992019 Sun Feb 16, 2020 9:26 pm
seized pilot screw & where to buy jets? Icon_minitimeby pledge Sun Feb 16, 2020 3:29 pm
seized pilot screw & where to buy jets? Icon_minitimeby RonB58 Fri Feb 14, 2020 5:59 pm
seized pilot screw & where to buy jets? Icon_minitimeby ardie Fri Feb 14, 2020 11:42 am
» New member in Florida
seized pilot screw & where to buy jets? Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 6:08 pm
seized pilot screw & where to buy jets? Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:51 am
» VS1400 rear end on a VS750
seized pilot screw & where to buy jets? Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:42 am
» Led turn signals!
seized pilot screw & where to buy jets? Icon_minitimeby mhicks2517 Tue Feb 11, 2020 5:38 pm
seized pilot screw & where to buy jets? Icon_minitimeby DickB Tue Feb 11, 2020 12:05 pm
seized pilot screw & where to buy jets? Icon_minitimeby steve co Fri Feb 07, 2020 2:03 pm
seized pilot screw & where to buy jets? Icon_minitimeby steve co Fri Feb 07, 2020 1:40 pm
seized pilot screw & where to buy jets? Icon_minitimeby steve co Fri Feb 07, 2020 1:28 pm
» Newby
seized pilot screw & where to buy jets? Icon_minitimeby malone55 Mon Feb 03, 2020 1:58 pm
» Hello from Stockholm
seized pilot screw & where to buy jets? Icon_minitimeby stingray Mon Feb 03, 2020 9:49 am
» Glad to be here!
seized pilot screw & where to buy jets? Icon_minitimeby stingray Mon Feb 03, 2020 9:48 am
» Hey Guys
seized pilot screw & where to buy jets? Icon_minitimeby oldtom Sun Feb 02, 2020 12:49 pm
» White walls
seized pilot screw & where to buy jets? Icon_minitimeby ardie Mon Jan 27, 2020 7:52 pm
seized pilot screw & where to buy jets? Icon_minitimeby creol Sat Jan 25, 2020 8:24 am
» Back in the saddle.
seized pilot screw & where to buy jets? Icon_minitimeby ardie Fri Jan 24, 2020 8:13 pm
