 VS1400 rear end on a VS750
vinny
vinny
VS1400 rear end on a VS750 Empty
PostSubject: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSat Jul 12, 2014 8:39 pm
Hi, i'm really hoping i can get some help on here. I'm fitting a 1400 rear end to my vs750, i have the rear wheel/swingarm/caliper etc, I know that the swingarm is approx 30mm wider so will have to be spaced out, the info i need is about the drive shaft, i have the original 750 shaft. I think the shaft U/J is longer on the 1400. I have read somewhere else that the 750/800 shaft is longer than the 1400, this is where it goes a bit fuzzy for me. I can probably measure up when it is all fitted and spaced out but I wondered whether anyone else had done this and already knows whether the shaft has to be shortened/lengthened etc as i think the 1400 swingarm is also 10mm longer?
thanks
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSat Jul 12, 2014 8:47 pm
Dave nobody on here has done the mod to a 750cc but as long as your not in a mighty big rush our gurus will give you a definitive answer but you might have to wait a few days for it maybe. They are some clever sods & they like a challenge, so if you can bear with them they will research the 750 to see if there are any extra differences but I very much doubt there is. I would of thought it would of been engine bore only
Dave out of curiosity what year is your bike, not sure if they will need to know that or not but they might
vinny
vinny
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSat Jul 12, 2014 8:55 pm
thanks mate, no problems with waiting, its a 1990, i've heard conflicting reports about differences in ratio from the 750 to 800, so i have no idea either whether the final drives/shafts even vary from the 750 to 800, never mind the 1400! I will make if fit whatever it takes lol, look forward to any information and help........
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSat Jul 12, 2014 9:28 pm
Sounds an interesting mod Dave  VS1400 rear end on a VS750 3498837457 Myself and a few others have got the VS1400 drive's fitted to our C/M800's to improve the gearing after following Mr Intruders lead, I wouldn't have thought there would be much difference between the VS 750/800 and 1400 other than gearing, If you have a browse through the part numbers you'll see what's the same and what's not?
http://www.cmsnl.com/suzuki-motorcycle_model13053/
vinny
vinny
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSat Jul 12, 2014 9:32 pm
thanks, i know the uj's and shafts are different parts/lengths from other posts, but not sure whether longer/shorter/interchangeable etc?
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSat Jul 12, 2014 9:37 pm
Can I ask why you want the 1400 "Rear end"? Final drive ratio?, Wheel size?
vinny
vinny
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSat Jul 12, 2014 9:45 pm
yes mate, for the taller gearing, extra tyre width, rear disc brake, as i'm also going to fit a different front end altogether with a disc brake, and the 750 swingarm had been 'modded' and ruined.....
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSat Jul 12, 2014 9:57 pm
Sounds good!  VS1400 rear end on a VS750 3498837457
vinny
vinny
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSat Jul 12, 2014 10:35 pm
just trying to work out a front now, i'd even considered ktm black usd'ers with a spoked supermoto front fatter tyre, and pre-loading the forks to make them a bit stiffer?
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSat Jul 12, 2014 11:18 pm
I like your thinking Dave, hopefully someone comes in with the info you require very soon but if they don't, curiosity will kill the cat & I will have to know and will do a bit of part swap compatibility research with you. Nosey b'stard me. VS1400 rear end on a VS750 852880
vinny
vinny
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSat Jul 12, 2014 11:21 pm
ok, cheers mate
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSat Jul 12, 2014 11:38 pm
Just going back through your post's, I will have to check but off the top of my head the stock VS1400 drive is I believe approximately  12" long. I will again check but the Stock 800 drive is off the top of my head 17" long and we mill back the head & shoulder by about 3/16" of an inch to make it fit.
Hope this helps a little.
vinny
vinny
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSat Jul 12, 2014 11:44 pm
12" and 17" long seems too much of a difference to me to be honest - 5"?, I think the 3/16" milling is for anyone fitting a 1400 rear hub to the 800 wheel rather than the whole rear end swap, but i could be wrong?
vinny
vinny
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSat Jul 12, 2014 11:46 pm
someone said that they did an 800 marauder with usd forks on one of the years? i wouldn't mind that if i can find one...???
Two-Bears
* VZ Guru *
Two-Bears
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSun Jul 13, 2014 3:45 am
Hello vinny,
If my memory serves me well today I believe M800 forks are the same Diameter as the VZ 800 Marauder. But their about 79cm long fully extended The VZ800 Marauders front forks are about 82cm long fitted to the bike on the ground is. VZ 800 Marauder fork spacing is about 21.5cm but I don't know if the yokes will swop over.
People have swapped VZ 800 Marauder front forks with M800`s and lowered the front by 2 inches and vise-versa so if you cannot find VZ800 Marauder forks M800 may do,, you can also get extension tubes for the forks if you want to make them even longer
Hope this is of some help mate and good luck with your project.
P.S do you have any Fox`s Biscuits going spare.
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSun Jul 13, 2014 9:01 am
I put in the measurements of our 800 drive & the 1400 drive for comparisons to be made. As you have the 750 drive, what is the length of that?
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSun Jul 13, 2014 3:33 pm
I have now spent several hours trawling the net and can't find anybody that has swapped the whole rear end as you want to. Fitting the VS1400 drive has been done a good few times with your VS 750/800 model so I would happily try that part myself. Saying that though I keep finding different information from people which would put me off encouraging anyone else, as there just seems to be no definitive info that I could find.
Sorry but I will have to bow out of this one, as I can see no descent write up anywhere that gives me confidence with the mid range VS model swap.
Good luck with it.
vinny
vinny
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSun Jul 13, 2014 5:39 pm
thanks for looking mate, i had the same problem, you said the 1400 shaft was 12" and the 800 17"
is this correct? seems like a big difference to me? As soon as i get the 750 shaft off, i'll post the length up.....
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSun Jul 13, 2014 5:49 pm
Yeah, 1400 shaft off a VS is 12.5" the shaft off a VL/M 800 is 17" long, the VS range has a shorter swing arm than the VL/M range, you need to get the bike apart really, to compare what parts are compatible between the 750/800 to 1400 and what will require spacers or machining?
vinny
vinny
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSun Jul 13, 2014 5:58 pm
ahh i see, when you said the 800, i thought you meant the vs lol, Yes mate i will take all the parts offl off and work it out and adjust/modify/space etc, I was just wondering whether someone had come across it before, just so i had some idea what i was up against, TBH hands on is best, i'll post here when i know more..............thanks.........
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeSun Jul 13, 2014 6:33 pm
It would be great if you did Dave, there are still huge amounts of VS about and it would be great to have write up.  VS1400 rear end on a VS750 3498837457
Lukaszmlynaczyk
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeThu Feb 13, 2020 11:31 am
Hello. I was able to install diff 1.4 for the intruder 750. I need to shorten the fight by 5mm and reduce the sleeves by 4mm from what I remember.
Lukaszmlynaczyk
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeThu Feb 13, 2020 11:39 am
VS1400 rear end on a VS750 20200211
VS1400 rear end on a VS750 20200212
VS1400 rear end on a VS750 20200213VS1400 rear end on a VS750 20200211
Lukaszmlynaczyk
PostSubject: Re: VS1400 rear end on a VS750   VS1400 rear end on a VS750 Icon_minitimeThu Feb 13, 2020 11:42 am
the spacer was made by the turner. I left the original part
» Commander rear seat and cage.
» RZR rear seat and cage.
» Installing EMP's HD rear bumper for the Rhino
» Rear bushings.
» Rhino Rear Brake?????
VS1400 rear end on a VS750 Icon_minitimeby Breeze42355 Sun Feb 23, 2020 10:31 pm
VS1400 rear end on a VS750 Icon_minitimeby ardie Sat Feb 22, 2020 6:49 pm
» Crash Bars
VS1400 rear end on a VS750 Icon_minitimeby Ish992019 Sun Feb 16, 2020 9:26 pm
VS1400 rear end on a VS750 Icon_minitimeby pledge Sun Feb 16, 2020 3:29 pm
VS1400 rear end on a VS750 Icon_minitimeby RonB58 Fri Feb 14, 2020 5:59 pm
VS1400 rear end on a VS750 Icon_minitimeby ardie Fri Feb 14, 2020 11:42 am
» New member in Florida
VS1400 rear end on a VS750 Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 6:08 pm
VS1400 rear end on a VS750 Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:51 am
» VS1400 rear end on a VS750
VS1400 rear end on a VS750 Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:42 am
» Led turn signals!
VS1400 rear end on a VS750 Icon_minitimeby mhicks2517 Tue Feb 11, 2020 5:38 pm
VS1400 rear end on a VS750 Icon_minitimeby DickB Tue Feb 11, 2020 12:05 pm
VS1400 rear end on a VS750 Icon_minitimeby steve co Fri Feb 07, 2020 2:03 pm
VS1400 rear end on a VS750 Icon_minitimeby steve co Fri Feb 07, 2020 1:40 pm
VS1400 rear end on a VS750 Icon_minitimeby steve co Fri Feb 07, 2020 1:28 pm
» Newby
VS1400 rear end on a VS750 Icon_minitimeby malone55 Mon Feb 03, 2020 1:58 pm
» Hello from Stockholm
VS1400 rear end on a VS750 Icon_minitimeby stingray Mon Feb 03, 2020 9:49 am
» Glad to be here!
VS1400 rear end on a VS750 Icon_minitimeby stingray Mon Feb 03, 2020 9:48 am
» Hey Guys
VS1400 rear end on a VS750 Icon_minitimeby oldtom Sun Feb 02, 2020 12:49 pm
» White walls
VS1400 rear end on a VS750 Icon_minitimeby ardie Mon Jan 27, 2020 7:52 pm
VS1400 rear end on a VS750 Icon_minitimeby creol Sat Jan 25, 2020 8:24 am
