 Fins Cleaned, Barrels Blacked
PostSubject: Fins Cleaned, Barrels Blacked   Mon Jul 28, 2014 10:08 pm
I know this has been covered elsewhere, but I'm so chuffed with they way these have turned out.
I'd been meaning to do something about the fins & barrels before they got too bad
They didn't look too bad from a distance, but close up, they were starting to look tatty
I treated myself to a bench polisher a couple of years back & it's been worth its weight in gold.  It came with a flexi-spindle (like a Dremel, but driven by the polisher motor), which means that you can work on areas that'd be impossible with the bench unit.
I ran the hard & medium mops over the fins first, then ran 150 emery cloth next.  When I'd done one barrel, I reused the emery to take down the surface.  I then ran 400 & 800 wet & dry over them.
So now the end of the fins looked better, but the black between them was not the best.  Gave them a good clean off with an engine de-greaser, then used this stuff
I used to use it on the Katana exhaust which had been black ceramic coated.  This stuff is brilliant - it contains microscopic traces of graphite which bond to the surface when it warms up.  However, it's the filthiest stuff in existence - if you use it, make sure you wear disposable gloves.  I worked it in with a toothbrush (best throw it out afterwards)
Give it about ten minutes to dry off (by the time you've finished putting it on, it's about time to take it off), then buff it off with a cloth.
Couple of hours per side, bear in mind that it you want to do the off-side properly, you'll need to remove the air-filter & gubbins
PostSubject: Re: Fins Cleaned, Barrels Blacked   Mon Jul 28, 2014 10:34 pm
Looks well Dave,black engine fins set the engine off well.
PostSubject: Re: Fins Cleaned, Barrels Blacked   Mon Jul 28, 2014 10:47 pm
What a transformation! It looks great!  ,  I've used that stuff on old fireplaces but would never have thought to use it on the bike  :good i:
ps. who's that ugly guy on your cylinder head covers? when I look at mine I see a model like adonis?  hyst
PostSubject: Re: Fins Cleaned, Barrels Blacked   Mon Jul 28, 2014 11:03 pm
Dunno - but I keep seeing him in my bathroom mirror - reckon he's my stalker.  And I think he's sleeping with my missus  !!!
PostSubject: Re: Fins Cleaned, Barrels Blacked   Mon Jul 28, 2014 11:31 pm
What a great change, well worth doing.
PostSubject: Re: Fins Cleaned, Barrels Blacked   Tue Jul 29, 2014 3:26 pm
Wow what a transformation, wonderful. What a great tip
DaveC
PostSubject: Re: Fins Cleaned, Barrels Blacked   Tue Jul 29, 2014 6:08 pm
Great job, well worth the effort
DaveK
PostSubject: Re: Fins Cleaned, Barrels Blacked   Tue Jul 29, 2014 9:13 pm
nice job dave have done my fins been on the think how to get the black on the block back thx for the tip
EazyDuz
PostSubject: Re: Fins Cleaned, Barrels Blacked   Mon Apr 20, 2015 10:05 am
That is the only area on the bike i can't be bothered to clean lol.
Actually, that area and wheel spokes.
PostSubject: Re: Fins Cleaned, Barrels Blacked   Mon Apr 20, 2015 10:33 am
Worth the effort - makes a helluv a difference.  Did the spokes over winter - pig of a job, but looks good.  Saying that, I may have them powdered next year
PostSubject: Re: Fins Cleaned, Barrels Blacked   Mon Apr 20, 2015 1:22 pm
I need to do my spokes, just need to work out the easiest way. I like minimal effort, maximum result, not always easy to find the best results that way.
PostSubject: Re: Fins Cleaned, Barrels Blacked   Mon Apr 20, 2015 10:03 pm
Dave let someone else do them, this is the easiest and  minimal effort. Glad to see you are getting back into your bike.
waynecomp
PostSubject: um...?   Wed Apr 06, 2016 2:58 pm
the results are great, but what did you use? the info seems to be missing. I hunted google using hints from your post, but i dont know what im looking for. thanks in advance.
PostSubject: Re: Fins Cleaned, Barrels Blacked   Wed Apr 06, 2016 3:35 pm
Hi Wayne - looks like Amazon have stopped selling it now, which is probably why the link has gone.  This is what I used Hotspot Grate Polish - Amazon are selling this now Stovax Graphite Polish.  To top the shine up, I use this stuff - SDoc 100
waynecomp
PostSubject: Thanks Dave.   Wed Apr 06, 2016 5:10 pm
Any idea why this stuff is only available in the uk? I something i think is comparable here locally, but who knows.  It's Rutland Stove Polish. I'd post a link, but I'm to new.
PostSubject: Re: Fins Cleaned, Barrels Blacked   Wed Apr 06, 2016 5:18 pm
Yeh - that looks like the sort of stuff.  I can't think why Hotspot is not available your side of the pond - probably contains some noxious ingredient that we don't mind coming into contact with.
To post a link - copy the page address that you wish to link to, click on the "insert a link" tab (next to the "YouTube" icon, then paste the link address in - if you want it read what it is that you're linking to (rather than a long web address), write it in the "Description" box - easy peasy, lemon squeezy !!!
PostSubject: Re: Fins Cleaned, Barrels Blacked   Wed Apr 06, 2016 8:09 pm
lgd
» Hello from Cheshire.
by johnboss Yesterday at 4:49 pm
» hello all from Somerset
by Chadders Yesterday at 3:49 pm
» Hello from Burlington Ontario, Canada
by peardrop3 Wed May 23, 2018 3:36 pm
» Installing coolant/water temperature gauge . . . . . . (Now Done)
by butcherman Tue May 22, 2018 10:14 pm
» my Suzuki Intruder VZ800M K6 2006 REG
by bagtoracer68 Tue May 22, 2018 2:26 am
» batty battery
by bagtoracer68 Tue May 22, 2018 2:13 am
by bagtoracer68 Tue May 22, 2018 2:11 am
» just wanted to say hello fellow riders
by bagtoracer68 Tue May 22, 2018 2:07 am
» New in Florida
by bagtoracer68 Tue May 22, 2018 2:06 am
» Greetings from Denmark
by bagtoracer68 Tue May 22, 2018 2:05 am
» Hello from Shelley Idaho
by bagtoracer68 Tue May 22, 2018 2:04 am
» Hello from Missouri, USA
by bagtoracer68 Tue May 22, 2018 2:03 am
» Time for a new one?
by bagtoracer68 Tue May 22, 2018 2:01 am
» Hi all
by bagtoracer68 Tue May 22, 2018 1:57 am
» hi everyone. im from kent uk.
by bagtoracer68 Tue May 22, 2018 1:55 am
» Fuel pump don’t come on when I turn the ignition key
by jester29 Thu May 17, 2018 10:20 pm
» 1998 VZ800 MondoDrive 14 Belt Conversion
by bigmal Wed May 16, 2018 9:36 pm
» Powder coat wheels
by captain morgan Mon May 14, 2018 10:28 pm
» Exhausts
by captain morgan Mon May 14, 2018 10:19 pm
» F1 light flashing.
by Gazza66 Fri May 11, 2018 7:33 pm
