| | swing arm | |
mr t Prospect
| Subject: swing arm Sat Aug 09, 2014 9:45 am | |
| hi . i am looking for a bearing kit for my marauder 800,1998 . ive looked allover and the only thing i can find is 2 needle roller bearings on fleebay im sure there should be some tube type bushes that fit in there aswall any ideas . | |
| Subject: Re: swing arm Sat Aug 09, 2014 10:51 am | |
| I'm not sure this is your model? Vz800 1998 (W), there are 2 bushes along with 2 roller bearings according to the schematic. http://www.cmsnl.com/suzuki-vz800-1998-w_model14289/partslist/FIG54.html#results | |
| | | Two-Bears * VZ Guru *
| Subject: Re: swing arm Sun Aug 10, 2014 1:09 am | |
| Hello Tony, I think you will find that the bearings ( needle rollers ) are in a cage inside the spacer pivot. There is a longer spacer but it is re-used. " /> Look here :- http://www.wemoto.com/bikes/suzuki/vz_800_w_marauder/98/picture/swinging_arm_pivot_bearing_kit/ Cheaper I think than E-Bay,, £43.87 delivered. Hope this is of some help mate. | |
| | | DaveK Member
| Subject: Re: swing arm Sun Aug 10, 2014 11:28 am | |
| Tony do you know the inside/outside dimensions i did a upgrade on my old 125 to the tube type bushes it only cost me about £8 if there the same i can get them & post to you | |
| | | mr t Prospect
| Subject: Re: swing arm Wed Aug 13, 2014 9:12 am | |
| hi .. i had a word with a guy at the bike shop down the road from me, he said see if it will tighten up make sure you use a strong arm bar. i gave that a try and got half a turn and the play was gone, i stripped the arm off the bike at weekend to see what the wear was like then i could try and get something on order, it had very minimum wear so everything was cleaned and greased back up, all this because the nut was slightly loose, it felt like i had rear wheel steer, anyway job done i will see how this goes for now | |
| Subject: Re: swing arm Wed Aug 13, 2014 7:53 pm | |
| Good to hear you have it sorted. | |
| Subject: Re: swing arm Wed Aug 13, 2014 9:04 pm | |
| Good thread Tony - I'm sure it will be of help to others. Yam | |
| Subject: Re: swing arm | |
| | | | swing arm | |
