 Bouncy rear end...
Rubbermalletguy
Rubbermalletguy
Bouncy rear end... Empty
PostSubject: Bouncy rear end...   Bouncy rear end... Icon_minitimeThu Sep 11, 2014 9:44 pm
Hi,
I was more or less a dedicated sports bike fan but I thought I might try a cruiser and came across a VL800 so went for it...Though I noticed the rear end seems so bouncy I can't tell whether it was designed that way or rear shock is shot...When ever I go over some hump the rear end goes gedoing gedoing gedoing 3 times before it settles down.
Any thoughts?
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeThu Sep 11, 2014 9:47 pm
Check the spring setting. It sounds like your on the lowest setting which can be a real bouncy castle ride compared to your previous rides.
Rubbermalletguy
Rubbermalletguy
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeThu Sep 11, 2014 9:48 pm
It is in 3rd notch from highest...
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeThu Sep 11, 2014 10:02 pm
Any sign of oil leaks from the shocker rods ? ... if so possible loss of damping.
Rubbermalletguy
Rubbermalletguy
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeThu Sep 11, 2014 10:05 pm
I thought that as well but saw no signs...but I only got it a month ago so it is hard to tell.
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeThu Sep 11, 2014 10:25 pm
Yes ... if someone has been 'clever' they could have cleaned off the leaking oil - so it is hard to tell 'on the bike. I suppose you could remove one shocker and (if you have suitable kit) take off the spring to 'assess' the damper. If it is shot you will be able to push the rod in & pull it out with very little resistance - & if it is 'shot' then it needs replacing/rebuilding.
If you are removing the spring, wind the pre-load down to the softest setting. You can sometimes compress the spring with a decent lever or large open ended spanner (if you exercise appropriate caution) to remove the retainer cap - but a proper spring compressor is the 'safe' way to do it.
These comments are 'generalised' for a typical twin shock rear set up as I do not have the details of the VL shockers to hand.
I suppose if you knew someone else local with a VL you could swap shocks to test ..... but you'd need a good 'buddy' to do that kind of testing.
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSat Sep 13, 2014 11:37 am
put it on a stiffer setting and see if that firms it up if not sounds like the shock as had it lol sorry not much help I tend to get someone to hold the bike push the rear end down with my weight and let go it should go back up in a nice motion and stay there if you let go and it go's up then bounces up and down before stopping then the shocs seen better days
Rubbermalletguy
Rubbermalletguy
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeWed Sep 17, 2014 9:40 pm
Well I had it at 2nd hardest setting and it bounced around so much that I had to bring it down to 3rd notch...
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeWed Sep 17, 2014 9:52 pm
as mentioned above, Oils gone if there's no damping effect.
Rubbermalletguy
Rubbermalletguy
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeWed Sep 17, 2014 9:56 pm
Yeah sounds about right.
Rubbermalletguy
Rubbermalletguy
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSat Sep 20, 2014 7:53 pm
Not bouncy anymore...took off the swingarm cover and put in a shock for Austin Mini. Just the right amount of damping. Transformed it. It will do until ridiculously long Hagon monoshock order arrives.
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSat Sep 20, 2014 9:15 pm
Bloody hell thats one way of doing it, glad it has temporarily sorted the problem for you Bouncy rear end... 3005623951
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSat Sep 20, 2014 9:32 pm
Austin Mini? Kinnel! who'd have thought that would fit? lol Just out of interest though? Is there another Suzuki "donor bike" monoshock that would fit the C/VL/M 800?  Worth thinking about I'm sure  Suspect
Rubbermalletguy
Rubbermalletguy
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSat Sep 20, 2014 9:38 pm
Only from US I can get used ones from...
Bouncy rear end... 20140910
Rubbermalletguy
Rubbermalletguy
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSat Sep 20, 2014 9:48 pm
Bouncy rear end... 20140913
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSat Sep 20, 2014 10:10 pm
Now that's excellent improvisation! A Damper situated between the Final Drive and Helmet Lock bracket!  ilis
Rubbermalletguy
Rubbermalletguy
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSat Sep 20, 2014 10:23 pm
I actually had to grind off the helmet lock and weld much heavier steel onto the brace... The bottom bracket is just bolt on.
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSat Sep 20, 2014 11:02 pm
Hi,
You had me worried at first when I read 'Mini shocker', & I instantly thought what about the spring .... but in seeing what you have actually done I can see how it works ! ..... & why it will work.
Nice bit of innovative thinking .... Bouncy rear end... 2170595768  .... & I guess original Mini shox are cheap !
If you are struggling with Hagon, then other people have recommended Brook Suspension in Bradford (They may be able to rebuild O/E units).
See website :-  www.brooksuspension.co.uk/
I personally have not tried them yet .... but have bookmarked them for possible future use.
Bouncy rear end... 3005623951  Yam
Rubbermalletguy
Rubbermalletguy
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSat Sep 20, 2014 11:31 pm
Well....Hagon shocks nearly cost £300 Mini shock is £30 and they are far stronger than those original shocks!
Rubbermalletguy
Rubbermalletguy
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSat Sep 20, 2014 11:33 pm
I might send my old one in once I get hagon.
Rubbermalletguy
Rubbermalletguy
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSun Sep 21, 2014 7:34 am
Vl800 is not listed though...I have a strange feeling the original shock for vl800 is not rebuildable...just looking at it looks so cheap compared with monoshocks from other bikes. To disassemble it you have to grind off the welds and cut off the press formed sealed ends...
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSun Sep 21, 2014 8:44 am
What a brilliant improvisation, I am impressed by your thinking.
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSun Sep 21, 2014 12:15 pm
Brilliant use of a Mini shock matey!  ilis
Shows that necessity is indeed the mother of invention! oyili
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSun Sep 21, 2014 5:38 pm
What an amazing mod, now you can stay cause we likes you
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSun Sep 21, 2014 7:05 pm
Yep - I get where you are coming from thinking the standard shock might not be rebuildable - but it costs nowt to enquire. Their (Brooks Suspension) website suggests they can. Made me wonder if they cut off the welded section and thread the upper part of the shock body to retain a cap on the top thus creating a serviceable unit - this is wishful speculation - so don't quote me on that. They might have other components that could provide a workable solution though.
From my days of messing with minis, there were aftermarket mini shocks that would take coils over the shocker .... mainly used on grass track cars and some kit cars. Spax and AVO did them. My Haughton Coldwell Biota (Kit car) used Greeves scramble coil over shox on the rear suspension (Dates back to the early 70's). However adding the spring to your mini shock will not give the same rising rate effect if your existing mono-shock unit is on a pivoting link. (i.e. you would lose some of the 'sophistication' of the O/E spring loading pattern.
Rubbermalletguy
Rubbermalletguy
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSun Sep 21, 2014 7:37 pm
Yea, I checked out those but in the end it costs about as much as Hagon unit. Though I will enquire about the rebuild option. Unfourtunstely right now I have no other mode of transport I had to resort to an improvisation...
PostSubject: Re: Bouncy rear end...   Bouncy rear end... Icon_minitimeSun Sep 21, 2014 8:10 pm
Excellent mod,well thought out and engineered.
Bouncy rear end...
» Commander rear seat and cage.
» RZR rear seat and cage.
» Installing EMP's HD rear bumper for the Rhino
» Rear bushings.
» Rhino Rear Brake?????
» Ello
Bouncy rear end... Icon_minitimeby stingray Yesterday at 6:21 pm
Bouncy rear end... Icon_minitimeby ardie Sun Dec 01, 2019 11:18 am
» 2012 C50 Boulevard's new look and Thanks....
Bouncy rear end... Icon_minitimeby ardie Wed Nov 27, 2019 6:28 pm
Bouncy rear end... Icon_minitimeby ChuckT Wed Nov 27, 2019 6:44 am
» Burbles like a V Twin Now....
Bouncy rear end... Icon_minitimeby bob gibson Tue Nov 26, 2019 1:21 am
» Just a little help.
Bouncy rear end... Icon_minitimeby katsd Sun Nov 24, 2019 5:57 pm
» Do I Need A EFI Mapper or Not....
Bouncy rear end... Icon_minitimeby Badger Sun Nov 24, 2019 3:50 pm
» vz800 cams
Bouncy rear end... Icon_minitimeby 81ker Fri Nov 22, 2019 1:49 pm
» South Australian Owner....
Bouncy rear end... Icon_minitimeby ardie Wed Nov 20, 2019 6:30 pm
Bouncy rear end... Icon_minitimeby ardie Fri Nov 15, 2019 7:31 pm
» Saying hello
Bouncy rear end... Icon_minitimeby ardie Fri Nov 15, 2019 7:30 pm
» New noises???
Bouncy rear end... Icon_minitimeby Dmill1222 Thu Nov 14, 2019 6:14 pm
Bouncy rear end... Icon_minitimeby bob gibson Wed Nov 06, 2019 6:39 pm
» Electronic fuel injection
Bouncy rear end... Icon_minitimeby 03580 Wed Nov 06, 2019 2:18 pm
» Straight Shots on 2006 C800
Bouncy rear end... Icon_minitimeby Tucker Tue Nov 05, 2019 7:57 pm
» hi guys
Bouncy rear end... Icon_minitimeby ardie Mon Nov 04, 2019 12:07 pm
Bouncy rear end... Icon_minitimeby GPDave Mon Nov 04, 2019 9:00 am
» Insurance
Bouncy rear end... Icon_minitimeby ardie Sat Nov 02, 2019 12:50 pm
» Chase Williams in Tennessee
Bouncy rear end... Icon_minitimeby stingray Fri Nov 01, 2019 10:10 pm
Bouncy rear end... Icon_minitimeby Proudtexson Fri Oct 25, 2019 12:29 am
