 Question about the top yoke C800/Vl800 - M800/VZ800
PostSubject: Question about the top yoke C800/Vl800 - M800/VZ800   Sun Oct 12, 2014 9:30 pm
I am thinking of doing some bits and bobs to my bike is the top yoke the same on a c800/vl800 as on the m800 bike is a 2009 model the one without the cowling round the headlight would the holes that the risers bolt through be the same size?
Thanks
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Sun Oct 12, 2014 9:59 pm
I'd say the top yolk on the Fishtail M800 model is very similar if not the same to the VL top yolk (from seeing Mal's) the only difference I would imagine is the size of the fork clamps due to the upside down forks, the riser bolts are 12mm on the VL and I'd say the same for the M800 too, Could be worth being confirmed first though.
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Mon Oct 13, 2014 10:11 am
thanks Sim sounds promising, big Mal if you see this thread could ya have a quick look at your bike for me just to make sure if it is a 12mm bolt. if not I will be able to check me self on Wednesday that's when I pick up me bike  wont hurt me to wait till then before ordering bits hehehehehe
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Mon Oct 13, 2014 4:20 pm
Just spoke with Dave (Mr Intruder) he has just told me that the yoke is not the same on the two bikes. He will be on later this evening if you need more information about it
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Mon Oct 13, 2014 7:45 pm
I an not sure what are & what are not the cross over capabilities of the yokes
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Mon Oct 13, 2014 8:58 pm
aint they got different forks on the M800 and C800, I think they are upside down forks on the M800?
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Mon Oct 13, 2014 9:03 pm
Thanks
I think Morgan's after changing the risers not the top yoke.
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Mon Oct 13, 2014 9:06 pm
it's just the holes really I have seen some risers that I like but it just says that they fit m50 boulevard  or American c50..... so I was just trying to find out whether they would fit on to a m800 would a 59 plate 800 be a vz800 or a m800 would it be the same as the m50 all gets a bit tricky as there is quite a few types of potentially the same bike (same engine anyway)  I might try sending an email to the place that is selling them and try to find out. If it's not the same I might have to look in to drilling it out so that the risers will fit
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Mon Oct 13, 2014 9:07 pm
Thanks
 yep that's right Sim u just beet me to my last post lol
O now I get it, I just read "is the top yoke the same on a c800/vl800 as on the m800" and panicked and rang Dave up, ignoring the rest
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Mon Oct 13, 2014 9:57 pm
I am not guaranteeing this info at all but I believe the riser bolts on the C800 are bigger than the M800.
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Mon Oct 13, 2014 10:28 pm
hyst you silly sod Crash lol
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Mon Oct 13, 2014 10:33 pm
the add says that they fit volusia 800 and the boulevard c50.
I've got a feeling your right Dave hence the questions, looks like drilling will be required got two people I know that can help with this for a precision job sooooo when it happens it should go smoothly, famous last words
Thanks for the help guys
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Mon Oct 13, 2014 10:56 pm
Confirmed
I looked at the risers I got with the VL800 handlebars, and they use bigger bolts compared to my M800.
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Mon Oct 13, 2014 11:02 pm
thanks for confirming Kim is there a lot of difference in the size or just next bolt size up? 8mm to 10mm for example. Drilling it is then why do the things that look the dogsb need adjustment to fit lol
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Tue Oct 14, 2014 1:24 am
I just measured to make sure, and the 2007 M800 uses 10mm bolts, and the rises I got from a VL800 uses 14mm bolts.
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Tue Oct 14, 2014 1:39 am
thanks Kim much appreciated
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Tue Oct 14, 2014 2:22 pm
Just read through the whole thread and it seems I was right to ring Dave on you behalf after all, different yokes, different risers, different bolt lengths and different bolt sizes and bolt holes. In fact nothing the same in that area, you may be able to mod it but others may not, so all the info is needed where possible because others will read it at another time. Ner ner dee ner ner
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Tue Oct 14, 2014 7:10 pm
I think it sounds more complicated than it will be when said like that Crash hehehe I hope lol gunna give it a go anyway spoze I've just got to pick whether I want to fit one inch bar or seven eighth's this could become a pain in the arse lol I'm not the best at picking what I want in fact when I walk in to a shop for a chocolate bar I normally just narrow down my choice then by two or three it's quicker hahahaha
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Tue Oct 14, 2014 7:27 pm
O no I think I have met my long lost twin brother  hyst I think from what I have read you may be better of picking your bars and then picking your risers but saying that tho most bars are going to be available in both sizes I would of thought
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Tue Oct 14, 2014 9:53 pm
I've seen some really nice bars would be easier to get risers that original bars will fit strait in to so I can fit them  then I can get all the other bits as I go along grips, mirrors the bars them self...... otherwise there will be a large amount of cash needed to do it all at once.
what size are the stock bars?
well should be picking up bike tomorrow so I can find out then
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Tue Oct 14, 2014 10:39 pm
just to check stock bars are 1" ,  4" height,   31" wide,   10 and a half inch pullback 7" centre I think?
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Wed Oct 22, 2014 11:14 pm
Whoops....sorry chaps .... Only just seen this thread. Mind you, I know f all about it anyway, so probably couldn't have added anything useful! Hope you get sorted out Morgan...
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Wed Oct 22, 2014 11:26 pm
hehehe yeh I'm on the way to getting this mod done Mal well I've ordered the riser's today for a start on it anyway lol I'll see what they look like when they arrive but I think I may need longer cables if that is the case I will wait till I get cables, new bars then do it all at the same time might be a little while till I get all the bits lol
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Thu Oct 23, 2014 10:16 am
Morgan before you go to the expense of new cables see if you can reroute the old ones to the back of the tree,this gives you more space.
PostSubject: Re: Question about the top yoke C800/Vl800 - M800/VZ800   Thu Oct 23, 2014 12:24 pm
thanks Alfie yep going to wait till I get the risers and see what they look like will then make decision on the cables
» My Baby has arrived
» Hello from Glasgow
by Wiggo Yesterday at 5:53 pm
» Yokes
» Wotcha From U.K.
» Dunlop family
» Hi Everyone......
» Hello From Maine
» Temporary "tinking" Sound
» Hello from Arkansas,USA
» Drill holes in Exhaust
» Switch housing help?
