| | aftermarket tacho | |
bigdave1964 Prospect
| Subject: aftermarket tacho Thu Oct 30, 2014 2:02 pm | |
| like many i do the odd job here and there when funds allow (ie when not being robbed by the kids schools for something or other) I have an 05 m800,and i've been considering for a while fitting a rev counter. If possible id prefer a digital one but im not overly fussy couple of questions - what have people fitted and their opinions did you fit straight to handle bar or any more inventive ways finally what would you consider to be red line thanks very much in advance folks Dave | |
| Subject: Re: aftermarket tacho Thu Oct 30, 2014 3:21 pm | |
| I think Mr Intruder, Dave, will answer your question as well as a few others Dave ok. | |
| | | DocSjulle Hero Globs
| Subject: Re: aftermarket tacho Thu Oct 30, 2014 3:58 pm | |
| I have used a cheap battery powered, all weather hour/tachometer for my boat. It works great, is easy to install with just a wire around one sparkplug wire, and is dirt cheap.
Similar to this one:
Ebay Tachometer | |
| Subject: Re: aftermarket tacho Thu Oct 30, 2014 4:39 pm | |
| I have one of these from this thread, works ok, nothing fancy, just does as it says on the tin. Tacho thread | |
| Subject: Re: aftermarket tacho Thu Oct 30, 2014 5:03 pm | |
Dave I have now fitted a cheap electronic counter, the type that is usually stuck on and has the other end of the wire wrapped around the spark plug lead. it works very good ( - HERE - ) is a link to the original thread. I use to have a Baron tacho ( - LINK - ) but had no luck with it, which is not unusual, many many people on the net have complained about the particular product. My Baron tacho was fitted to the bars but the cheap tacho is fitted to the plastic clock display on the tank of my bike. Here is Red line info: 1st-34 2nd-65 3rd-87 4th-106 5th-125 - good luck with hitting that. You will have to of had the rev limiter removed & be riding downhill with the wind behind you. I have a VS1400 drive on my bike, the rev limiter over ridden & a FI module fitted & still not reached it. | |
| Subject: Re: aftermarket tacho Fri Oct 31, 2014 10:16 pm | |
| thanks to everyone. not as complicated or surprisingly as expensive as I expected cheers folks Dave | |
| | | strontyd Member
| Subject: Re: aftermarket tacho Thu Nov 27, 2014 8:55 am | |
| i managed to source a new original suzuki item from fleabay, fairly easy to fit if a bit fiddly. i think there was one on there a few days back from the US. | |
| Subject: Re: aftermarket tacho | |
