 Problem running engine after removing rear Carb
Gearbox
Gearbox
Problem running engine after removing rear Carb Empty
PostSubject: Problem running engine after removing rear Carb   Problem running engine after removing rear Carb Icon_minitimeTue Dec 16, 2014 12:52 am
Hi, Just got a VS800 intruder with Chinese diaphragm carbs - Mikuni BS36 (I think). I had a lot of backfiring and so removed the front carb, cleaned jets, checked float valve and found that the diaphragm looked like a sieve. Bought a new diaphragm and fitted it.
Connected up and the bike ran well but now some backfiring from the rear cylinder now. Took diaphragm out and found it was OK - no holes but there was a crack in the carb body which snapped off!!! I couldn't afford a new one so found an aluminium welder specialist and had it welded up. Of course I had to remove it to have it welded.
Put it back together, with a smidging of gasket goo just to be sure  and now find I can't get the engine to run at all. I realise that the Haynes manual suggests that it is not recommended to undo the couplings from the first carb to the second but had no choice. I have seemed to have put all the couplings back as they came off with the same settings but still no run.
The problem getting it to run has only occurred after removing the rear carb. I seem to be getting a spark but nothings firing up.
What have I done or not done - I'd appreciate the help from anyone who is more familiar with this set up.
Thanks for reading this chapter!!!
CanadianCruiser
CanadianCruiser
PostSubject: Re: Problem running engine after removing rear Carb   Problem running engine after removing rear Carb Icon_minitimeSat Dec 20, 2014 1:16 am
if you removed the cables running from the first to second carb you will need to sync them.  but sounds like a jet issue.. if your getting spark then I'm inclined to say examine the fuel delivery.
PostSubject: Re: Problem running engine after removing rear Carb   Problem running engine after removing rear Carb Icon_minitimeSat Dec 20, 2014 10:59 am
Given the work you've done,. it sounds more like a carb synchronisation issue ..... or the general set up of the cables. If you look through the workshop manual, there is a section describing where the cables have to be set at identical lengths. I'd suggest double checking everything there.
Since we are looking at start up from cold, I wonder if it may be connected with the fuel enrichment (choke). You need to check if you are getting a spark .... but also let the motor run for a short while, then check the rear plug to see if it is showing signs of getting fuel  .... the plug colour & if it is getting 'wet' with fuel could give further clues.
CanadianCruiser
CanadianCruiser
PostSubject: Re: Problem running engine after removing rear Carb   Problem running engine after removing rear Carb Icon_minitimeSat Dec 20, 2014 11:54 am
Section 4-29 in the Factory Service Manual.. it's a PITA.  I use the Emgo carb sync gauges.
» What do I need to do to swap a fuel pump to a gravity fed one?
» I seem to be new here. 1969? Sears Suburban
» RZR 1000 Drive shaft and carrier bearing removal
» Any reason for my carb to smoke from the choke side?
» Murray Rear Engine Tractor
Problem running engine after removing rear Carb Icon_minitimeby ardie Yesterday at 6:49 pm
» Crash Bars
Problem running engine after removing rear Carb Icon_minitimeby Ish992019 Sun Feb 16, 2020 9:26 pm
Problem running engine after removing rear Carb Icon_minitimeby pledge Sun Feb 16, 2020 3:29 pm
Problem running engine after removing rear Carb Icon_minitimeby RonB58 Fri Feb 14, 2020 5:59 pm
Problem running engine after removing rear Carb Icon_minitimeby ardie Fri Feb 14, 2020 11:42 am
» New member in Florida
Problem running engine after removing rear Carb Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 6:08 pm
Problem running engine after removing rear Carb Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:51 am
» VS1400 rear end on a VS750
Problem running engine after removing rear Carb Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:42 am
» Led turn signals!
Problem running engine after removing rear Carb Icon_minitimeby mhicks2517 Tue Feb 11, 2020 5:38 pm
Problem running engine after removing rear Carb Icon_minitimeby DickB Tue Feb 11, 2020 12:05 pm
Problem running engine after removing rear Carb Icon_minitimeby steve co Fri Feb 07, 2020 2:03 pm
Problem running engine after removing rear Carb Icon_minitimeby steve co Fri Feb 07, 2020 1:40 pm
Problem running engine after removing rear Carb Icon_minitimeby steve co Fri Feb 07, 2020 1:28 pm
» Newby
Problem running engine after removing rear Carb Icon_minitimeby malone55 Mon Feb 03, 2020 1:58 pm
» Hello from Stockholm
Problem running engine after removing rear Carb Icon_minitimeby stingray Mon Feb 03, 2020 9:49 am
» Glad to be here!
Problem running engine after removing rear Carb Icon_minitimeby stingray Mon Feb 03, 2020 9:48 am
» Hey Guys
Problem running engine after removing rear Carb Icon_minitimeby oldtom Sun Feb 02, 2020 12:49 pm
» White walls
Problem running engine after removing rear Carb Icon_minitimeby ardie Mon Jan 27, 2020 7:52 pm
Problem running engine after removing rear Carb Icon_minitimeby creol Sat Jan 25, 2020 8:24 am
» Back in the saddle.
Problem running engine after removing rear Carb Icon_minitimeby ardie Fri Jan 24, 2020 8:13 pm
