 v&h pipes...what ones?
mk2mattw
PostSubject: v&h pipes...what ones?   Sun Dec 28, 2014 10:49 am
Hiya guys!new to bikes and this forum!recently purchased a 55plate volusia,bit of YouTube searching and found the awesome sound of the v&h pipes!!! Question is with all these random codes that I don't have a clue about yet,how do I know which ones will fit?
Cheers
Newbie Matt
PostSubject: Re: v&h pipes...what ones?   Sun Dec 28, 2014 11:10 am
Hi Matt, All the V&H Pipes for VL800's will physically fit your bike, It just depends on if the bike is fuel injected or has carbs?
PostSubject: Re: v&h pipes...what ones?   Sun Dec 28, 2014 11:21 am
I have V&H Cruisers fitted & love them. Some times I run them stock, some times I run them with quiet baffles installed, depends what mood I'm in. Great exhausts anyway, love them.
I do not know what codes you are talking of?
As mentioned by Sim, some 55 could be left over carb bikes. If yours is a true 55, then it will be fuel injected. If it's a carbed bike, just fit them, if it is fuel injected, do the following.
If you want to be very very very kind to the planet, then have the bosses & CO2 sensor fitted. This will require a single holes drilled in to one of the pipes on your year. have the boss welded to it & fit the CO2 sensor. The CO2 sensor is the thing you have sticking out of your top stock pipe with a lead coming from it.
If you don't want to save the planet from a minute amount of extra emission coming from the bike then:
Fit the pipes & open the side cover &simply cut wire #23 and ride the bike like you stole it. Simples.
mk2mattw
PostSubject: Re: v&h pipes...what ones?   Sun Dec 28, 2014 11:35 am
Great help cheers guys! The bike was registered 29/10/05 but I suppose I could have been sat waiting to be registered! So even though mine is a volusia it doesn't matter if I get one for a standard 800 or specific to it?
I'm handy with a welder so I can fit the lambda boss :)
The baffles come with them or is that an extra you bought Mr Intruder?
PostSubject: Re: v&h pipes...what ones?   Sun Dec 28, 2014 12:12 pm
I bought the extra quiet baffles.
If your bike has a wire coming from the top exhaust it's a fuel injected model.
mk2mattw
PostSubject: Re: v&h pipes...what ones?   Sun Dec 28, 2014 3:32 pm
Oh the codes I qas talking about earlier were m50 c50 does that mean anything to you guys?
mk2mattw
PostSubject: Re: v&h pipes...what ones?   Sun Dec 28, 2014 3:48 pm
And I have read something about a pair valve mod?no idea what that is tbh! Sorry for the millions of questions I'm just really excited to get this thing going and on the road as soon as I pass my test:)
PostSubject: Re: v&h pipes...what ones?   Sun Dec 28, 2014 4:56 pm
M50 & C50 are just the American names for M800 & VL/C800, they work in Cubic Inches (50) as we work in Cubic Centimeters (800) Same bikes just different numbers.
PostSubject: Re: v&h pipes...what ones?   Sun Dec 28, 2014 8:01 pm
Aaahhh now I get you, nice one Sim for decoding the codes.
mk2mattw
PostSubject: Re: v&h pipes...what ones?   Mon Dec 29, 2014 6:05 am
Ah that makes sense! Any ideas on this pair valve mod?
PostSubject: Re: v&h pipes...what ones?   Mon Dec 29, 2014 8:49 am
You can get a pair valve blanking kit from ( HERE ) can't see the point in it myself. I like the gurgling on deceleration.
PostSubject: Re: v&h pipes...what ones?   Tue Dec 30, 2014 3:55 pm
Does seem like a lot of work for very little result, I know depending on the setup the pipes can gurgle pop or bang on deceleration but I am sure there aint any performance result from doing it
PostSubject: Re: v&h pipes...what ones?   Tue Dec 30, 2014 4:57 pm
None, just what one wants to hear or not. A very common mod, what suits one doesn't always suit the other & vice versa.
PostSubject: Re: v&h pipes...what ones?   Sun Mar 22, 2015 1:09 pm
Hi Matt
Just seen your other post about PAIR valve removal.
There are two reasons (that I know of) for removal - one is aesthetic, some people like to see "naked jugs", rather than what looks like a mimi air filter cover.  The other (which seems to affect carb versions) is that fitting an after-market exhaust can bugger up the running if not set-up correctly.  This explains all the ins & outs - Moccs Place.  When I first had mine, the previous owner had fitted Highway Hawks.  It ran like a pig & sounded awful on over-run - I love a nice bit of "pop" on over-run, but this was way too much.  Removed 'em & the difference was amazing - cured the over-run completely & improved the running no-end.
Personally, I prefer the clean barrels look - but that is purely a matter of taste
PostSubject: Re: v&h pipes...what ones?   Sun Mar 22, 2015 5:29 pm
got to agree looks nice with out the pair valve plus it's one thing less to clean and also makes cleaning easier once it's out of the way hhhrrummmmmmmm think I want to do this mod lol
EazyDuz
PostSubject: Re: v&h pipes...what ones?   Sun Mar 22, 2015 7:40 pm
You could keep the pair valve cover and put a fuse box behind it, or a hidden switch for something.
» newby
by Skidalot Today at 5:00 pm
» vs1400 drive mod
by G.Terence Today at 9:54 am
» VL800 C800 ENGINE
by Wiggo Today at 8:38 am
» VZ800 Compression question
by v-twin Sat Feb 17, 2018 9:05 pm
» Powder coat wheels
by peardrop3 Sat Feb 17, 2018 7:30 pm
» Gaskets thickness ?
by grumpy grandad Wed Feb 14, 2018 5:15 pm
» 2006 TO 2016 ENGINE SWAP
by simbo Tue Feb 13, 2018 8:43 pm
» VS 750 rat bike
by grumpy grandad Tue Feb 13, 2018 5:57 pm
» Hi All
by ardie Tue Feb 13, 2018 4:04 pm
» Hello from US
by ardie Sun Feb 11, 2018 6:58 pm
» newbee
by stingray Sun Feb 11, 2018 3:42 pm
» Hello from New Zealand
by stingray Sun Feb 11, 2018 3:35 pm
» Wider Angle Mirror Upgrade
by bigmal Sat Feb 10, 2018 6:34 pm
» Fitting additional on/off light switch
by v-twin Fri Feb 09, 2018 7:49 am
by simbo Tue Feb 06, 2018 9:19 pm
» Halogen/LED Headlamp Upgrade?
by simbo Mon Feb 05, 2018 7:56 pm
» exhaust seal
by mally Sat Feb 03, 2018 3:24 pm
» Starter motor switch jammed
by v-twin Fri Feb 02, 2018 8:50 pm
» Battery Replacement Conundrum
by bagtoracer68 Mon Jan 29, 2018 3:18 am
» Home-Made Rotor Resurfacing (Read "Red-Neck Refurb!")
by bagtoracer68 Mon Jan 29, 2018 3:14 am
