 Oil filter wrench
PostSubject: Oil filter wrench   Mon Mar 09, 2015 7:29 pm
Can anyone tell me the size of the oil filter wrench for the M800 (2013), I think the part No. is 09915-40611 but I cant find the size in mm, only one on Ebay is in the USA, am I right in thinking it may be 68mm, 14 flute, thanks in advance guys,
PostSubject: Re: Oil filter wrench   Mon Mar 09, 2015 9:57 pm
One of these you mean? they'll fit but I've no idea what size they are?, you'll probably find a cheaper one if you search VL800 oil filter wrench.
http://www.ebay.co.uk/itm/SUZUKI-C50-M50-BOULEVARD-VL800-C800-INTRUDER-OIL-FILTER-WRENCH-TOOL-/300955706515?pt=UK_Motorcycle_Parts_13&hash=item46125ba493
rossmofo
rossmofo
PostSubject: Re: Oil filter wrench   Tue Mar 10, 2015 4:46 pm
Hand and thin rubber glove, apply hand to filter, grip tightly and twist until the veins are popping out your neck or filter loosens ..
PostSubject: Re: Oil filter wrench   Tue Mar 10, 2015 5:02 pm
grip it with some some sandpaper in your hands works too.
PostSubject: Re: Oil filter wrench   Tue Mar 10, 2015 7:37 pm
Thanks guys but I've had to put a screwdriver through it, it still would not budge, ended up using a cold chisel to free it. Suzuki done the service, they must have tightened it with a 10 foot bar and NO oil on the rubber seal ,s
PostSubject: Re: Oil filter wrench   Tue Mar 10, 2015 9:27 pm
I bet that was a bum clenching moment  affraid I've done it myself before though when needs must  Embarassed
ippikin
ippikin
PostSubject: Re: Oil filter wrench   Sun Mar 15, 2015 11:12 pm
K&N oil filters have a nut welded on the top of the filter... such a good idea; makes removal/installation a breeze. Only about £10 a go.http://www.knfilters.co.uk/motorcycle_oil_filters.aspx
PostSubject: Re: Oil filter wrench   Mon Mar 16, 2015 2:11 pm
Thanks all, it is a 68mm, 14 flute wrench & I obtained one for £7.00. Do your own servicing guys, don't rely on anyone else, this was a totally avoidable problem resulting from no oil on the 'O' ring and over-tightening the filter way too much by the so called "experts"
dougr1411
dougr1411
PostSubject: Re: Oil filter wrench   Wed May 06, 2015 8:43 pm
I use a leather strapped  jar opening device  I got in a local shop , cheaper than any purpose built filter removal tool .works a treat
PostSubject: Re: Oil filter wrench   Wed May 06, 2015 8:51 pm
Good thinking!
PostSubject: Re: Oil filter wrench   Wed May 06, 2015 9:00 pm
Now that's thinking outside the box. msrke
PostSubject: Re: Oil filter wrench   Wed May 06, 2015 10:03 pm
Yep, the 'jar strap' is a cheap alternative, but might not cope with an over-tightened oil filter as mentioned by John above.
Interestingly, I followed the 'Suzuki' instructions for tightening the oil filter on the 'VX' & it seemed to require a tightness level above what I would have 'guessed' from experience ! - There is no excuse for not lubricating the 'O'-ring with fresh oil on assembly though.
Oil filter wrench
» Air Filters 101: Why, when and how to service my engine’s air filter
» 2010/2011 K&N Air Filter
» Twin Air filter for 09 & up Can-Ams.
» Which air filter oil...
» King Quad Owners.... Throw out your factory air filter!
» Bono Estente
» Hello to all
» Greetings from Scandinavia
» CLUTCH SLIPPING STILL
» Engine swap
» Hello from Hong Kong
» Re: My first project bike
» Miss ing
» new new new
» Newby from Norfolk
» con rod problem
» Whats goin on everybody
» Hi fellow riders
