| | Quick release saddlebag brackets ? | |
DocSjulle Hero Globs
| Subject: Quick release saddlebag brackets ? Wed Sep 03, 2014 6:15 pm | |
| I have bought some cheap leather lookalike saddlebags, and want a quick release saddlebag bracket, because I dont like the look of the normal saddlebag mounts, when the bags are not mounted.
I have found the Easy Brackets and they look very nice and sturdy, but I cant find them anywhere but in USA.
Does anybody know of any alternatives, and perhaps a bit cheaper if possible ? | |
| | | CanadianCruiser Member
| Subject: Re: Quick release saddlebag brackets ? Tue Oct 28, 2014 4:48 pm | |
| I use Saddlemans S4 Quick disconnect on my VZ800. they can be used with their bags or with any rigid back bag.. not too pricy either. | |
| Subject: Re: Quick release saddlebag brackets ? Wed Oct 29, 2014 12:47 pm | |
| Don't you still need the bag bars/mount when using the this system ? | |
| Subject: Re: Quick release saddlebag brackets ? Fri Oct 31, 2014 11:54 pm | |
| Don't know how quick a system you want, but on mine I devised a system which means the bags can be removed in about 1 minute. And certainly cheaper than big quick release brackets. I would only suggest this on a bag that locks... Here's my write up from another part of this forum. Good luck whatever you decide. Linky | |
| | | streetboy Prospect
| Subject: Re: Quick release saddlebag brackets ? Mon Jan 26, 2015 1:59 pm | |
| try these http://www.customparts4less.com/epages/268147.sf/en_GB/?ObjectPath=/Shops/268147/Products/H66-020 | |
| Subject: Re: Quick release saddlebag brackets ? Mon Jan 26, 2015 4:42 pm | |
| Thx for the suggestions, but I don't want to have the support brackets on the bike when not using the bags.
So far I have still only found the Easy brackets and Edge brackets which only leave a small stud on the bike, when no bags are attached.
I will most likely order the Easy brackets version, as it look much sturdier being made of one piece of steel. | |
| Subject: Re: Quick release saddlebag brackets ? Sun Mar 15, 2015 1:07 pm | |
| Subject: Re: Quick release saddlebag brackets ? Sun Mar 15, 2015 1:57 pm | |
| They look a good bit of kit | |
| Subject: Re: Quick release saddlebag brackets ? Sun Mar 15, 2015 2:57 pm | |
| That looks really pukka! 5 minutes to change the fender bolts! They must have been on and off a good few times with your extensive redesign! They're often a right bastard.... | |
| Subject: Re: Quick release saddlebag brackets ? Thu Mar 19, 2015 7:25 pm | |
| Finally mounted the bags the the brackets, and now I'm all ready to go camping I made a 6mm plywood board painted black to go inside the bags to reinforce them. Unfortunately I manage to break one of the keys in the mounting process, and I hope I can get an extra one made. | |
| Subject: Re: Quick release saddlebag brackets ? Thu Mar 19, 2015 8:31 pm | |
| Good job, nice addition | |
| Subject: Re: Quick release saddlebag brackets ? | |
Latest topics | » 12inch apes by Mbroom21 Tue Apr 16, 2024 12:54 pm
