| | hello camshaft timing vz800 | |
+5peardrop3 v-twin katsd simbo scubadogs 9 posters | Author | Message |
scubadogs Prospect
| Subject: hello camshaft timing vz800 Tue Oct 13, 2015 5:34 pm | |
| Hello , this forum looks great. I have a 1997 VZ800 which I just torn down the motor to replace crank and rod bearings because the last owner ran it with low to no oil. I have a question about camshaft timing. the front#2 cylinder and the back #1 cylinder have and arrow on the cam shaft. This is to be pointed towards the front of the engine when the generator rotor aligns up with T.D.C. The book shows TDC of No.1 cylinder is the RIF I T marking aligned with the mark on the generator cover. Do I use the FIF I T marking for the front #2 cylinder? They use both of these marking per the book when adjusting the valves but they only mention the RIF I T when setting the camshaft timing. Can someone help me out?? | |
| Subject: Re: hello camshaft timing vz800 Tue Oct 13, 2015 6:33 pm | |
| Hi scubadogs This is just a introductory & welcome page mate, you'll get a better response if you ask questions in the relevant section | |
| Subject: Re: hello camshaft timing vz800 Tue Oct 13, 2015 7:53 pm | |
| Hiya scubadogs - welcome on board - someone is sure to be able to help you out - try posting in the "Engine" section | |
| | | scubadogs Prospect
| Subject: Re: hello camshaft timing vz800 Wed Oct 14, 2015 2:05 am | |
| Thanks I did post it in the engine section. Don't know what I was thinking. Well Hello! I am restoring a 1997 vz800. Owner ran it with low to no oil. Other than that the bike is in great shape. I am doing the usual new tires, brakes etc. Can't wait to ride this baby! | |
| | | | peardrop3 Very Valued VIP Member
| Subject: Re: hello camshaft timing vz800 Wed Oct 14, 2015 2:32 pm | |
| scubadogs! | |
| | | | alfie92 Very Valued VIP Member
| Subject: Re: hello camshaft timing vz800 Wed Oct 14, 2015 9:29 pm | |
| Hi and welcome scubadogs. | |
| Subject: Re: hello camshaft timing vz800 Fri Oct 16, 2015 5:58 pm | |
| Welcome matey | |
| Subject: Re: hello camshaft timing vz800 Fri Oct 16, 2015 8:55 pm | |
| to the forum and hope you get your camshaft query sorted - I'm sure you will.. there's some very knowledgeable folk on here1 | |
| Subject: Re: hello camshaft timing vz800 | |
