 help withe model ID of engine
twistedspirit
twistedspirit
PostSubject: help withe model ID of engine   Mon Nov 09, 2015 11:02 pm
hi. i am trying to adjust the valves on my trike. i know it is a vx800 engine but thats about it. the manual says that you use different marked positions for TDC if its and E18 model or other model.
can anyone tell me the model or more info on my engine so that i can set it up correctly please? i am not having much luck finding stuff out.
the engine number is S501-112772.
cheers for any help
PostSubject: Re: help withe model ID of engine   Tue Nov 10, 2015 5:41 pm
not sure mate but u might be able to find out if you look at a manual
hmac
hmac
PostSubject: Re: help withe model ID of engine   Tue Nov 10, 2015 5:50 pm
Might be worth talking to your local dealer see if they can get the info from their system.
PostSubject: Re: help withe model ID of engine   Tue Nov 10, 2015 8:19 pm
The 'S' means it is 750—849cc, the '5' means its Four-stroke twin, the '01' means nothing as far as I can tell and everything after the '-' is its actual number, that's about I can help with, sorry. I can not even cross reference it with mine as its engine number is '14', that's all it says!!
PostSubject: Re: help withe model ID of engine   Tue Nov 10, 2015 8:48 pm
The 01 should be the year of manufacture.
PostSubject: Re: help withe model ID of engine   Tue Nov 10, 2015 10:26 pm
I'm not sure if that is the case Sim on older Suzuki's, I have seen some engine codes for 3 different VX engines from 3 different years and they all start with S501 besides, they never made the VX in 2001!!
PostSubject: Re: help withe model ID of engine   Fri Nov 13, 2015 9:15 am
PostSubject: Re: help withe model ID of engine   Fri Nov 13, 2015 11:35 am
Well done CC
» Mintor 33cc Petrol engine
» Ranking of Engine Manufacturers and Models
» Can you help me with an onan engine?
» RCGF 45cc Petrol Engine
» Tecumseh engine
» Bono Estente
» Hello to all
» Greetings from Scandinavia
» CLUTCH SLIPPING STILL
» Engine swap
» Hello from Hong Kong
» Re: My first project bike
» Miss ing
» new new new
» Newby from Norfolk
» con rod problem
» Whats goin on everybody
» Hi fellow riders
