 Disable F1 error on O2 sensors ???
Stein
Disable F1 error on O2 sensors ??? Empty
PostSubject: Disable F1 error on O2 sensors ???   Disable F1 error on O2 sensors ??? Icon_minitimeTue Nov 17, 2015 1:54 pm
HI.
I have a Suzuki M800 , 2012 model.
I have connected a Powercommander V and a Autotune set.
I am not using the stock O2 sensors , 2 pieces , on mine.
I have used the plugs/eliminators for the O2 outlets , but i still get the F1 errors , C44 and C64.
On the earlier model , 2008 , you can cut wire 23 to disable the error light, that is White/Black as i can see on the web.
But i cant find anything about mine.
The 23 is NOT White/Black on my model.
That is number 17.
But number 23 and 24 is the same color , Black with White stribe, maybe this the one.
if i look on the O2 outlets , they are both White with Black stribe .
Stein
PostSubject: Re: Disable F1 error on O2 sensors ???   Disable F1 error on O2 sensors ??? Icon_minitimeTue Nov 17, 2015 5:19 pm
Hi Stein, I thought after 2011 Suzuki removed the wire from port 23 on the ECU and just put a blank in? I'm not sure which wire does the o2 sensors now sorry,  on another note, Does the Autotune feature on the power commander not gather information from the o2 sensors and other engine fuelling sensors to work out an optimum map?
Stein
PostSubject: Re: Disable F1 error on O2 sensors ???   Disable F1 error on O2 sensors ??? Icon_minitimeTue Nov 17, 2015 8:11 pm
Hi Simbo.
I hope somebody knows something about that ECU.
The Powercommander and Autotune , goes around the ECU , so as i can see , there is no issue about the F1 error beside the warning light , but i cant have it , he he.
And i cant understand why the eliminator doesnt Work .
Maybe i should try to plug the stock O2 sensors in the sockets to see if the warning light goes out .
Stein
Stein
PostSubject: Re: Disable F1 error on O2 sensors ???   Disable F1 error on O2 sensors ??? Icon_minitimeMon Nov 30, 2015 3:56 pm
Disable F1 error on O2 sensors ??? Vzvl800Disable F1 error on O2 sensors ??? Suzuki2012
I have now a wiringdiagram over my bike. But the O2 sensors is NOT on nr 23 , but instead on nr 17 . On nr 23 and 24 is a Black/White wire . And i have testet it  the w/b from the O2 sensors is going to nr 17. I have cut the wire but still get a F1 error.
PostSubject: Re: Disable F1 error on O2 sensors ???   Disable F1 error on O2 sensors ??? Icon_minitimeMon Nov 30, 2015 4:46 pm
I'm not sure what wires do what sorry but I did fit an FI module made by healtech same one as Mr intruder (Dave) fitted  I just followed his vid and how to fit guide that he put on the site. I have a m800 2009  I don't have o2 sensors fitted to my exhaust pipes though. sorry I cant be more help hopefully   one of the members can help you Disable F1 error on O2 sensors ??? 184121345
Stein
PostSubject: Re: Disable F1 error on O2 sensors ???   Disable F1 error on O2 sensors ??? Icon_minitimeMon Nov 30, 2015 5:12 pm
A F1 module ???
Is that : http://www.ebay.com/itm/251105095462
If it is , i have tried that , didnt help.
Stein
PostSubject: Re: Disable F1 error on O2 sensors ???   Disable F1 error on O2 sensors ??? Icon_minitimeMon Nov 30, 2015 5:23 pm
no not that mate go have a look at the section on this site for it's under the heading
c800 FI pro (instructions and video)
Stein
PostSubject: Re: Disable F1 error on O2 sensors ???   Disable F1 error on O2 sensors ??? Icon_minitimeMon Nov 30, 2015 6:30 pm
PostSubject: Re: Disable F1 error on O2 sensors ???   Disable F1 error on O2 sensors ??? Icon_minitimeMon Nov 30, 2015 10:54 pm
I've no idea on this one Stein, Your findings will be of great use to members with 2011+ bikes though, please keep us updated  Disable F1 error on O2 sensors ??? 3498837457
Stein
PostSubject: Re: Disable F1 error on O2 sensors ???   Disable F1 error on O2 sensors ??? Icon_minitimeThu Dec 10, 2015 3:55 pm
I took a chance today , and cut wire nr 23 .
And it seem to Work .
I had the bike running in about 10 minutes , and NO F1 errors , niceeeeeeeeeeee.
Stein
PostSubject: Re: Disable F1 error on O2 sensors ???   Disable F1 error on O2 sensors ??? Icon_minitimeThu Dec 10, 2015 8:39 pm
That's good to know Stein  Disable F1 error on O2 sensors ??? 3498837457 Disable F1 error on O2 sensors ??? 433968
PostSubject: Re: Disable F1 error on O2 sensors ???   Disable F1 error on O2 sensors ??? Icon_minitimeFri Dec 11, 2015 4:15 pm
wire number 23 same as on my bike and in Dave's  video Disable F1 error on O2 sensors ??? 3498837457 good to know it works on your 2012 model
» Moultrie Error Codes
» Hobbywing ESC
» Ottawa Senators 10/11 projected lineup
» Kitesurf Magazine
» How Garmin Footpod works?
Disable F1 error on O2 sensors ??? Icon_minitimeby Breeze42355 Sun Feb 23, 2020 10:31 pm
Disable F1 error on O2 sensors ??? Icon_minitimeby ardie Sat Feb 22, 2020 6:49 pm
» Crash Bars
Disable F1 error on O2 sensors ??? Icon_minitimeby Ish992019 Sun Feb 16, 2020 9:26 pm
Disable F1 error on O2 sensors ??? Icon_minitimeby pledge Sun Feb 16, 2020 3:29 pm
Disable F1 error on O2 sensors ??? Icon_minitimeby RonB58 Fri Feb 14, 2020 5:59 pm
Disable F1 error on O2 sensors ??? Icon_minitimeby ardie Fri Feb 14, 2020 11:42 am
» New member in Florida
Disable F1 error on O2 sensors ??? Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 6:08 pm
Disable F1 error on O2 sensors ??? Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:51 am
» VS1400 rear end on a VS750
Disable F1 error on O2 sensors ??? Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:42 am
» Led turn signals!
Disable F1 error on O2 sensors ??? Icon_minitimeby mhicks2517 Tue Feb 11, 2020 5:38 pm
Disable F1 error on O2 sensors ??? Icon_minitimeby DickB Tue Feb 11, 2020 12:05 pm
Disable F1 error on O2 sensors ??? Icon_minitimeby steve co Fri Feb 07, 2020 2:03 pm
Disable F1 error on O2 sensors ??? Icon_minitimeby steve co Fri Feb 07, 2020 1:40 pm
Disable F1 error on O2 sensors ??? Icon_minitimeby steve co Fri Feb 07, 2020 1:28 pm
» Newby
Disable F1 error on O2 sensors ??? Icon_minitimeby malone55 Mon Feb 03, 2020 1:58 pm
» Hello from Stockholm
Disable F1 error on O2 sensors ??? Icon_minitimeby stingray Mon Feb 03, 2020 9:49 am
» Glad to be here!
Disable F1 error on O2 sensors ??? Icon_minitimeby stingray Mon Feb 03, 2020 9:48 am
» Hey Guys
Disable F1 error on O2 sensors ??? Icon_minitimeby oldtom Sun Feb 02, 2020 12:49 pm
» White walls
Disable F1 error on O2 sensors ??? Icon_minitimeby ardie Mon Jan 27, 2020 7:52 pm
Disable F1 error on O2 sensors ??? Icon_minitimeby creol Sat Jan 25, 2020 8:24 am
