 Battery Removal M800 (2010)
Campbell59
Campbell59
PostSubject: Battery Removal M800 (2010)   Tue Feb 02, 2016 2:58 pm
I'm looking to remove the battery for charging while the machine is not in use. I can only find removal instruction for earlier models. The battery is located under the seat. I do see a plate which is attached by two bolts which seems to be securing the battery. I don't want to start taking things apart until I find out the proper way to remove the battery.
Any help would be much appreciated.
Thanks
TaurusTuga
TaurusTuga
PostSubject: Re: Battery Removal M800 (2010)   Tue Feb 02, 2016 4:38 pm
Perhaps this will help: Embarassed
After removing it from the terminal, don't let the (+) connector touch any metal part on the bike, ok?
Step One: Remove the (-) negative cable and after the (+).
Step Two: When you want to install it, do the inverse way: first the (+) and after the (-).
PostSubject: Re: Battery Removal M800 (2010)   Tue Feb 02, 2016 5:13 pm
good to remember negative first and last
TaurusTuga
TaurusTuga
PostSubject: Re: Battery Removal M800 (2010)   Wed Feb 03, 2016 10:38 pm
I forgot to say:
I've a Oxford Oximiser like this one:
that came with two different connectors as displayed in pic:
The ones on the top will be fit always on the bike directly to (+) and (-) battery. This method avoid to remove the battery from the bike. When it is not in use, i simply connect them directly to recharge&maintenance and stays as long as i want. No damage and it starts always at the first attempt.
PostSubject: Re: Battery Removal M800 (2010)   Wed Feb 03, 2016 11:04 pm
yes I got an optimate 3 in summer hook it up and forget about it no more seats off for me http://www.ebay.co.uk/itm/Optimate-3-12V-Battery-Charger-and-conditioner-/262243455592?hash=item3d0eed9268:g:cv8AAOSwD0lUbMy5 got mine for £38
Campbell59
Campbell59
PostSubject: Re: Battery Removal M800 (2010)   Thu Feb 04, 2016 12:13 pm
Thanks guys for the help. Battery out and on charge.
Using a Oxford Optimiser 900 (Will connect permanent lead when putting battery back)
PostSubject: Re: Battery Removal M800 (2010)   Thu Feb 04, 2016 4:13 pm
yes Campbell a lot less hassle all round with the lead  on
TaurusTuga
TaurusTuga
PostSubject: Re: Battery Removal M800 (2010)   Thu Feb 04, 2016 9:10 pm
» Prop shaft trouble on 2010 rzr s
» Woody Battery/Amplified Speaker System
» New kites for Blast, for 2010
» Nebelhorn Trophy 2010
» battery failures
» Bono Estente
by Skidalot Yesterday at 4:51 pm
» Hello to all
» Greetings from Scandinavia
» CLUTCH SLIPPING STILL
» Engine swap
» Hello from Hong Kong
» Re: My first project bike
» Miss ing
» new new new
» Newby from Norfolk
» con rod problem
» Whats goin on everybody
» Hi fellow riders
