 Bleeding The Radiator
3 posters
Bleeding The Radiator Empty
PostSubject: Bleeding The Radiator   Bleeding The Radiator Icon_minitimeWed Feb 10, 2016 12:38 pm
I need to remove the radiator - when I refill it, is there an air bleed screw in the system, or do you just leave the rad cap off & run it up to temperature?
PostSubject: Re: Bleeding The Radiator   Bleeding The Radiator Icon_minitimeWed Feb 10, 2016 2:54 pm
Just fill the rad, then run it up to temperature with cap fitted then topped it up when I stopped the engine. That's what I did. Had no bother at all.
PostSubject: Re: Bleeding The Radiator   Bleeding The Radiator Icon_minitimeWed Feb 10, 2016 6:12 pm
Fill it really slowly to avoid airlocks and like Mick said  Bleeding The Radiator 3498837457
PostSubject: Re: Bleeding The Radiator   Bleeding The Radiator Icon_minitimeWed Feb 10, 2016 9:12 pm
Cheers guys - thanks for that
» Radiator fan (cut in) !!
» Sachs 800 radiator coolant switch
» Radiator Protector
» VX800. Radiator and fan connections.
» finally got my radiator fan installed but.....
Suzuki 800 Intruder Club & Forum :: The Garage :: Cooling system-
Bleeding The Radiator Icon_minitimeby alongfortheride Tue Mar 26, 2024 9:41 pm
Bleeding The Radiator Icon_minitimeby SAM11206 Wed Mar 20, 2024 6:34 pm
Bleeding The Radiator Icon_minitimeby Onigatudor Wed Mar 20, 2024 2:39 pm
Bleeding The Radiator Icon_minitimeby flying1 Wed Mar 13, 2024 4:43 pm
Bleeding The Radiator Icon_minitimeby nano Tue Mar 05, 2024 2:19 pm
Bleeding The Radiator Icon_minitimeby Brianhuck Sat Mar 02, 2024 7:30 pm
Bleeding The Radiator Icon_minitimeby Billybop90 Fri Mar 01, 2024 12:44 am
Bleeding The Radiator Icon_minitimeby Aikido789 Sat Feb 24, 2024 10:11 am
Bleeding The Radiator Icon_minitimeby bernard chaddock Wed Feb 21, 2024 5:06 pm
Bleeding The Radiator Icon_minitimeby bernard chaddock Wed Feb 21, 2024 4:58 pm
Bleeding The Radiator Icon_minitimeby fabio almeida Tue Feb 20, 2024 9:28 am
Bleeding The Radiator Icon_minitimeby icoolwecool99@gmail.com Mon Feb 19, 2024 9:47 pm
Bleeding The Radiator Icon_minitimeby Billybop90 Fri Feb 16, 2024 7:16 pm
Bleeding The Radiator Icon_minitimeby SWEET Fri Feb 16, 2024 6:25 pm
Bleeding The Radiator Icon_minitimeby VAI777 Tue Feb 13, 2024 3:32 pm
Bleeding The Radiator Icon_minitimeby redevil Tue Feb 13, 2024 10:59 am
Bleeding The Radiator Icon_minitimeby Urko Sun Feb 11, 2024 11:12 am
Bleeding The Radiator Icon_minitimeby CS_0427 Tue Feb 06, 2024 2:28 am
Bleeding The Radiator Icon_minitimeby Badger Mon Feb 05, 2024 11:27 am
Bleeding The Radiator Icon_minitimeby John Silver Sun Feb 04, 2024 7:05 pm
