| | Lollipops fitted today. | |
| Subject: Lollipops fitted today. Sun May 08, 2016 7:12 pm | |
| After removing most of the catalytic converter, you can see the tube going straight to the header pipe on my completely gutted stock mufflers. I have noticed a little loss in backpressure and hence torque after this final stage so decided to make a new set of lollipops similar to the ones I installed on my HH pipes a few years back. First I purchased some 50mm washers, brackets and bolts/nuts (£3) Next I made up a bracket to withstand the force from the exhaust output and a bolt to insert through a hole in the muffler. The top nut is to stop the bolt spinning when tightened from below and the wing nut as a prototype Inserted and tightened about 6 inches in. After testing, I replaced the wing nut with a square nut, hidden where the eye cannot see. I had to jack the bike up to get the drill into the lower pipe. You have to shine a light down the pipes to see the lollipops but when sprayed with matt black HT paint, you cannot tell there is anything inside when viewed from the back The bike now has more torque but the nice crack of sound is much the same. I guess this completes the stock exhaust modification. Possibly needs locknuts. I have tested for quite a few miles and so far the lollipops have remained in position. This method can be done on debaffled or gutted stock pipes and aftermarkets and is considerably cheaper than torque cones and if you like messing around, great fun! | |
| | | ardie Valued Member
| Subject: Re: Lollipops fitted today. Sun May 08, 2016 7:32 pm | |
| well impressed with that really neat and precise job very little cost hats off to you | |
| Subject: Re: Lollipops fitted today. Sun May 08, 2016 8:31 pm | |
| Nice job John You should be on Dragons Den with this mod | |
| Subject: Re: Lollipops fitted today. Mon May 09, 2016 4:32 pm | |
| Well done especially for someone who say's he's not mechanically minded!!! | |
| | | | Sponsored content
| Subject: Re: Lollipops fitted today. | |
Latest topics | » just saying hello to this site by sgtruth60@gmail.com Yesterday at 8:04 pm
» Newbie by M800chimp Yesterday at 11:28 am
