 Speedo Clock etc & Neutral Light failure
DavidMcGarvie
DavidMcGarvie
PostSubject: Speedo Clock etc & Neutral Light failure   Thu May 19, 2016 7:46 pm
Hi All, I have the M800 14 reg, intruder and the other day as I was driving along the speedo, clock etc just stopped working, the neutral light also does not come on. The bike kept running and there is no problem re the this, I have checked and can only find 2 x 30 amp fuses under the end of the petrol tank and these were both OK. I pulled the bike apart looking for more fuses but can't find any? Has anyone got any suggestions as to what it might be that's causing this, or where the fuses might be? Thanks in advance..... Dave
PostSubject: Re: Speedo Clock etc & Neutral Light failure   Thu May 19, 2016 9:34 pm
Hiya, I don't know the 2014 model as mines an oldie. But there's bound to be a fuse panel elsewhere with other fuses on. On my 05 model the speedo is on the same circuit as the horn I think.
Do you have a chunky aftermarket horn that isn't running through a relay? Might have popped the fuse.
Hopefully someone with the newer bike will chime in. Good luck Wink
DavidMcGarvie
DavidMcGarvie
PostSubject: Re: Speedo Clock etc & Neutral Light failure   Thu May 19, 2016 10:19 pm
Hi, no aftermarket horn, hopefully someone will know..... Laughing
PostSubject: Re: Speedo Clock etc & Neutral Light failure   Thu May 19, 2016 10:20 pm
there should be a fuses inside the rear left hand engine cover where the coolant bottle is, 4 screws but ones a dummy so only 3 come out, think you have to remove the side panel to remove it too.
Old Luner
Old Luner
PostSubject: Re: Speedo Clock etc & Neutral Light failure   Fri May 20, 2016 2:55 am
Aah, so there's a fuse box in there is there ?
Bit awkward to get at if your at the side of the road and wanting to change a fuse.
It's an arse on to have to get someone to hold the bike upright and get laid on the floor with a torch just to check your water level too.
Bugsy
Bugsy
PostSubject: Re: Speedo Clock etc & Neutral Light failure   Fri May 20, 2016 8:27 am
PostSubject: Re: Speedo Clock etc & Neutral Light failure   Fri May 20, 2016 10:02 am
That's a handy bit of kit
PostSubject: Re: Speedo Clock etc & Neutral Light failure   Fri May 20, 2016 10:59 am
Exactly what I use for checking the oil level in the round window. That way you can sit on the bike, hold it dead level, then fish around with the mirror. You'll see a view up your trouser leg and all kind of other unwanted pictures affraid until you get he angle right, but practice makes perfect.
Old Luner
Old Luner
PostSubject: Re: Speedo Clock etc & Neutral Light failure   Fri May 20, 2016 11:27 am
Bugsy wrote:
Four level checks you need one of these Mart, good for oil and water checks whilst sitting on the bike.
https://www.amazon.co.uk/dp/B00HSJKJYS/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=569136327&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B000R9ZVHG&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=05QG2QWY9EGM41JXJVT9
That'll do nicely thankee kindly, already have one that I call the "dipstick mirror" (yeah yeah belongs to a dipstick fuck off Sim  dogsb) for checking oil level but it hasn't got led's on it so can't see the water level with it.
DavidMcGarvie
DavidMcGarvie
PostSubject: Re: Speedo Clock etc & Neutral Light failure   Fri May 20, 2016 11:51 am
Hi Simbo,
Many thanks you were spot on the fuses are next to the cooler bottle at the end left engine cover....great help cheers.....Dave Mc
PostSubject: Re: Speedo Clock etc & Neutral Light failure   Fri May 20, 2016 4:32 pm
DavidMcGarvie wrote:
Hi Simbo,
Happy to help    I'm guessing it was a blown fuse then?
DavidMcGarvie
DavidMcGarvie
PostSubject: Re: Speedo Clock etc & Neutral Light failure   Fri May 20, 2016 5:18 pm
Yep...... I couldn't find anything in the handbook to say where the fuses are located..... very helpful of Suzuki! cheers
» First Light - BBC2, Tuesday the 14th, 9:00pm
» xentech hid light kit
» Rhino 660 Speedo Install
» backup light
» Epic Infinity Light wind kite
» Old Biker New to VS 800
by peardrop3 Yesterday at 6:10 pm
» Greeting from Sussex
by peardrop3 Yesterday at 6:09 pm
» 6" straight risers with flat bars
by Sergio-Intruder-Newbee Wed Mar 20, 2019 4:21 am
» Rear seat bolt size
by hmac Tue Mar 19, 2019 11:23 pm
» Memphis Shades Lowers Installed
by simbo Mon Mar 18, 2019 10:25 pm
by ardie Mon Mar 18, 2019 2:30 pm
» Hello from the UP of Michigan USA
by stingray Sun Mar 10, 2019 4:56 pm
» clubman handlebar?
by Blue Fri Mar 08, 2019 7:13 pm
» The most simple mods are the most satisfying - thumb screw
by EazyDuz Wed Mar 06, 2019 8:24 pm
» Hello from FRANCE
by zorg premier Sun Mar 03, 2019 11:16 am
by EazyDuz Thu Feb 28, 2019 8:51 pm
» Wont start after washing bike, urgent help needed!
by ardie Thu Feb 28, 2019 8:37 pm
» Bono Estente
by peardrop3 Wed Feb 27, 2019 3:11 pm
» Wider Rar Tire 200/70R15
by jan1 Wed Feb 27, 2019 9:08 am
» Metzeler tyres in M800!?
by jan1 Wed Feb 27, 2019 9:05 am
» Greetings from Scandinavia
by jan1 Wed Feb 27, 2019 9:02 am
» Hyphercharger style air intake
by jan1 Wed Feb 27, 2019 9:01 am
» Hello to all
» CLUTCH SLIPPING STILL
» Engine swap
