 Bit of advice please.
Bugsy
PostSubject: Bit of advice please.   Mon Aug 01, 2016 9:44 am
Finally got fed up with the stock sound of my exhaust (2013 C800)
I have put a pointed rod through the first baffle no problem.
There is now what appears to be a second baffle just a small distance further in from the first.
Does this need to be done also and can it be done without upsetting the 'cat' ?
Thanks guys
PostSubject: Re: Bit of advice please.   Mon Aug 01, 2016 11:53 am
Yes it needs to be pierced as well, when the rod is touching the second baffle place a piece of insulating tape on the rod in line with the end of the exhaust, you'll feel it pierce the baffle and the tape should move around an inch or so, I believe the 'cat' is about 3"-4" away from the second baffle so you should not have a problem, hope this helps Gary.
Bugsy
PostSubject: Re: Bit of advice please.   Mon Aug 01, 2016 12:09 pm
Cheers much appreciated
johnboss
PostSubject: Re: Bit of advice please.   Mon Aug 01, 2016 12:35 pm
There's loads of stuff in the 'Garage' section on this - well worth a look. When you've poked the baffles through, have a listen, if the sound is what you want, fine if not think about drilling the backplates. Most folk seem to do 4 x 10mm holes. After plucking up courage (and with lots of guidance from the likes of Sim and others) I started off with 4X5mm and increased slowly until I got the sound I wanted. Happy I did as it sounds great, not offensive - just a nice burble especialy under a bit of power.
PostSubject: Re: Bit of advice please.   Mon Aug 01, 2016 12:59 pm
The end plate at the back of the exhaust has been removed in this pic but you can see what's inside the exhaust.
Bugsy
PostSubject: Re: Bit of advice please.   Mon Aug 01, 2016 1:34 pm
Thanks guys. All done and I'm more than happy. It is not too loud just deeper in note.
I was sure I'd read somewhere on here about two baffle plates with dimensions etc, but I couldn't find it.
I used a smaller rod first then a larger one. Tapping with a heavy hammer rather than full pelt smashing.
The holes made doing it this way look 'factory'
» newby
by Skidalot Today at 5:00 pm
» vs1400 drive mod
by G.Terence Today at 9:54 am
» VL800 C800 ENGINE
by Wiggo Today at 8:38 am
» VZ800 Compression question
by v-twin Sat Feb 17, 2018 9:05 pm
» Powder coat wheels
by peardrop3 Sat Feb 17, 2018 7:30 pm
» Gaskets thickness ?
by grumpy grandad Wed Feb 14, 2018 5:15 pm
» 2006 TO 2016 ENGINE SWAP
by simbo Tue Feb 13, 2018 8:43 pm
» VS 750 rat bike
by grumpy grandad Tue Feb 13, 2018 5:57 pm
» Hi All
by ardie Tue Feb 13, 2018 4:04 pm
» Hello from US
by ardie Sun Feb 11, 2018 6:58 pm
» newbee
by stingray Sun Feb 11, 2018 3:42 pm
» Hello from New Zealand
by stingray Sun Feb 11, 2018 3:35 pm
» Wider Angle Mirror Upgrade
by bigmal Sat Feb 10, 2018 6:34 pm
» Fitting additional on/off light switch
by v-twin Fri Feb 09, 2018 7:49 am
by simbo Tue Feb 06, 2018 9:19 pm
» Halogen/LED Headlamp Upgrade?
by simbo Mon Feb 05, 2018 7:56 pm
» exhaust seal
by mally Sat Feb 03, 2018 3:24 pm
» Starter motor switch jammed
by v-twin Fri Feb 02, 2018 8:50 pm
» Battery Replacement Conundrum
by bagtoracer68 Mon Jan 29, 2018 3:18 am
» Home-Made Rotor Resurfacing (Read "Red-Neck Refurb!")
by bagtoracer68 Mon Jan 29, 2018 3:14 am
