 Indicators and LED bulbs.
Billyz
Billyz
PostSubject: Indicators and LED bulbs.   Mon Sep 12, 2016 1:06 pm
hi everyone, long, long time since I've been on here but have spent some time recovering from my second triple heart bypass, I can tell you it was a somewhat long and torturous path! Enough of that stuff. I have recently reintroduced myself to my Volusia trike and am the proud owner of a new MOT. I have been fiddling around with the trike recently and wanted to change out my standard indicator bulbs for LED bulbs. All went well but for some reason the front left hand indicator, whilst happy to flash an ordinary bulb refuses to power up an LED. I have tried the bulb in the other sockets and it works fine. Is this just a connection issue with this particular indicator or am I missing something? Any advice appreciated. Cheers
PostSubject: Re: Indicators and LED bulbs.   Mon Sep 12, 2016 6:06 pm
I'd check out all the connectors that side Bill but do note that you'll need an LED compatable indicator flasher unit to make the LED's work correctly.
Glad to hear you are feeling better after your illness as well!
Billyz
Billyz
PostSubject: Re: Indicators and LED bulbs.   Mon Sep 12, 2016 7:06 pm
Thanks for the kind words Pete.
I've already changed out the flasher unit so not that I think. I must have spent a couple of hours on the flipping thing today but try as I might I cannot find the fault. Thought perhaps I might just replace the whole front units with something off of E bay, lots of LED units on there from about a Fiver to seventy or eighty pounds, if anybody has any recommendations let me know.
PostSubject: Re: Indicators and LED bulbs.   Mon Sep 12, 2016 9:44 pm
Hi Pete hope you get over your op, as regards to your leds you may need a diode to change the direction of the current, not sure, I know that the warning light does not always work on one side when fitting leds, lets hope someone pops up with the answer.
hmac
hmac
PostSubject: Re: Indicators and LED bulbs.   Mon Sep 12, 2016 10:40 pm
Sounds like a polarity issue. Led bulbs have a positive and negative side and wont work if they are connected wrong way round, try swapping round the wires going to that indicator.
» WHO'S GOT JUST REPLACEMENT BULBS IN THERE RHINO????
» Indicators and Quartz reefs
» Pike hangers/indicators
» Drop off indicators
» Home made pike tackle
» Old Biker New to VS 800
by peardrop3 Yesterday at 6:10 pm
» Greeting from Sussex
by peardrop3 Yesterday at 6:09 pm
» 6" straight risers with flat bars
by Sergio-Intruder-Newbee Wed Mar 20, 2019 4:21 am
» Rear seat bolt size
by hmac Tue Mar 19, 2019 11:23 pm
» Memphis Shades Lowers Installed
by simbo Mon Mar 18, 2019 10:25 pm
by ardie Mon Mar 18, 2019 2:30 pm
» Hello from the UP of Michigan USA
by stingray Sun Mar 10, 2019 4:56 pm
» clubman handlebar?
by Blue Fri Mar 08, 2019 7:13 pm
» The most simple mods are the most satisfying - thumb screw
by EazyDuz Wed Mar 06, 2019 8:24 pm
» Hello from FRANCE
by zorg premier Sun Mar 03, 2019 11:16 am
by EazyDuz Thu Feb 28, 2019 8:51 pm
» Wont start after washing bike, urgent help needed!
by ardie Thu Feb 28, 2019 8:37 pm
» Bono Estente
by peardrop3 Wed Feb 27, 2019 3:11 pm
» Wider Rar Tire 200/70R15
by jan1 Wed Feb 27, 2019 9:08 am
» Metzeler tyres in M800!?
by jan1 Wed Feb 27, 2019 9:05 am
» Greetings from Scandinavia
by jan1 Wed Feb 27, 2019 9:02 am
» Hyphercharger style air intake
by jan1 Wed Feb 27, 2019 9:01 am
» Hello to all
» CLUTCH SLIPPING STILL
» Engine swap
