| | Aux plug inside headlight? (Passing light connector) | |
Speck1965 Member
| Subject: Aux plug inside headlight? (Passing light connector) Tue Dec 27, 2016 5:06 pm | |
| Hi,
Is it possible to buy the "other end" of this plug anywhere? I have a new bike and would rather not cut or splice in. Is it a standard connector?
Thanks | |
| Subject: Re: Aux plug inside headlight? (Passing light connector) Tue Dec 27, 2016 5:41 pm | |
| Try your local automotive wiring sales place or use 2 female single plugs. | |
| | | Speck1965 Member
| Subject: Re: Aux plug inside headlight? (Passing light connector) Tue Dec 27, 2016 6:18 pm | |
| Cheers bud. Is there an idiots wiring diagram anywhere for wiring these things up with a handlebar switch? Is it easier to ignore aux connector and go direct to battery?
Many thanks | |
| Subject: Re: Aux plug inside headlight? (Passing light connector) Tue Dec 27, 2016 6:27 pm | |
| The auxillary connector is only live when the ignition is switched on. As for a wiring diagram try downloading the owners manual which can be found in the forum items listings or look in electrical items for a detailed write up on doing the work ok? | |
| | | Speck1965 Member
| Subject: Re: Aux plug inside headlight? (Passing light connector) Tue Dec 27, 2016 7:26 pm | |
| Thanks for reply, I am not looking for a general wiring diagram, just a diagram to wire up after market spotlights. I have done a search and can find plenty of information on the hardware side but nothing on wiring them up. From what I can make out I can use the aux connector in the headlight shell as a relay trigger and I think I will still need to run a supply from the battery also, just don't want to get it wrong.
Cheers. | |
| Subject: Re: Aux plug inside headlight? (Passing light connector) Tue Dec 27, 2016 8:25 pm | |
| If you look through the electrical threads I'm sure you will find some help there or try to contact V-Twin or Sim as they are more up in these things than myself. | |
| | | yorky VIP Member
| Subject: Re: Aux plug inside headlight? (Passing light connector) Tue Dec 27, 2016 10:15 pm | |
| If i remember correctly the aux. supply is from a 10 Amps fuse. A spade connector of the correct size will push into it. Fit a correctly sized inline fuse if the 10 Amps is too much for you. | |
| | | Speck1965 Member
| Subject: Re: Aux plug inside headlight? (Passing light connector) Tue Dec 27, 2016 10:20 pm | |
| From what I have read on this forum the aux connector is not man enough to power 2 x 55w spotlights. I was going to fit a relay powered directly from the battery and use the aux connector as the relay trigger. I am no auto electrician though so was looking for guidance as to the correct wiring procedure.
Cheers | |
| | | yorky VIP Member
| Subject: Re: Aux plug inside headlight? (Passing light connector) Tue Dec 27, 2016 10:35 pm | |
| If my maths is correct...2 lamps at 55 w = 110 watts
10 Amps at 12 volts = 120 watts
110 watts will draw approx. 9.2 Amps | |
| | | Speck1965 Member
| Subject: Re: Aux plug inside headlight? (Passing light connector) Tue Dec 27, 2016 10:37 pm | |
| Yes, but the aux circuit has the bikes lights on it as well? | |
| | | yorky VIP Member
| Subject: Re: Aux plug inside headlight? (Passing light connector) Tue Dec 27, 2016 10:58 pm | |
| No choice then, you will need another feed. | |
| | | yorky VIP Member
| Subject: Re: Aux plug inside headlight? (Passing light connector) Wed Dec 28, 2016 9:13 am | |
| As you say ...if you want a feed that goes on and off with the ignition then you need a relay and use the aux. supply ( or some other circuit that comes on with the ignition ) to operate the relay via a switch.
If you wanted something simpler you could just take a fused feed from the battery to a switch (that can take 10 Amps ) but if you leave them on you will have a flat battery.
Some people fit a 40A relay feeding a fuse bank to give them easy connections for other bits of kit they want to connect up ( heated grips etc. ) | |
| | | Speck1965 Member
| Subject: Re: Aux plug inside headlight? (Passing light connector) Wed Dec 28, 2016 9:57 am | |
| Love the idea of the second fuse bank, reckon I will go for that subject to having room to fit it. Nice idea yorky - Cheers! | |
| | | KeithW Member
| Subject: Re: Aux plug inside headlight? (Passing light connector) Wed Dec 28, 2016 10:26 am | |
| Have you seen this? I always used to use a 5 way fuse panel but came accross this while researching dual dash cams for bikes. I may use this on the new bike.
Well, I tried to post a link but I'm not allowed yet. Google INNOVV POWER SUPPLY HUB and have a look.
KeithW | |
| Subject: Re: Aux plug inside headlight? (Passing light connector) Wed Dec 28, 2016 11:51 am | |
| - Speck1965 wrote:
- Yes, but the aux circuit has the bikes lights on it as well?
How have you come to this conclusion mate ? | |
| | | Speck1965 Member
| Subject: Re: Aux plug inside headlight? (Passing light connector) Wed Dec 28, 2016 1:57 pm | |
| Read it on this very forum somewhere? | |
| Subject: Re: Aux plug inside headlight? (Passing light connector) Thu Dec 29, 2016 4:12 pm | |
| This was the route I went down when I wanted extra feeds | |
| Subject: Re: Aux plug inside headlight? (Passing light connector) | |
Latest topics | » Choke plunger by flying1 Wed Mar 13, 2024 4:43 pm
» Will be making my own exhausts by JagLite Sun Feb 04, 2024 2:26 am
» just saying hello to this site by Mack Sun Jan 21, 2024 8:34 pm
» New old guy by Badger Sun Jan 14, 2024 8:26 pm
