 Kickstand Mods VL800
PostSubject: Kickstand Mods VL800   Tue Oct 18, 2011 8:43 pm
Hello everyone,
I am waiting on parts to lower the back of my VL800. I was also planning on doing the kickstand stop removal. To gain a little lean angle when parked. (Mistress K) However, If I grind off the stop wont the weight of the bike/kickstand rest on the ignition kill switch, which is plastic? I dont want to crack the tabs off that piece. Any thoughts? I figured I could remove the lower bolt and insert a small piece of metal or a bushing to transfer the weight to the bolt instead of the plastic tab of the switch. If you have any ideas or solutions let me know.
Mr Intruder Founder ... & ... Senior Administrator
PostSubject: Re: Kickstand Mods VL800   Tue Oct 18, 2011 8:51 pm
A random selection of member bikes.
» Are some of the VS800/VZ800/c50/S50 parts interchangable?
by simbo Wed Mar 21, 2018 8:07 pm
» greetings from the neighbouring isle
by simbo Wed Mar 21, 2018 7:55 pm
» Bish
by Bish Wed Mar 21, 2018 7:53 pm
» Vs800 rear wheel removal please help
by ReynaSunshine Mon Mar 19, 2018 11:49 pm
» Wider Angle Mirror Upgrade
by bagtoracer68 Mon Mar 19, 2018 10:48 pm
» Coolant Smell
by bagtoracer68 Mon Mar 19, 2018 10:24 pm
» First suzuki
by bagtoracer68 Mon Mar 19, 2018 10:19 pm
» Rear Sprocket Bolts
by hmac Mon Mar 19, 2018 10:29 am
» Proud of my trike - bring on some good weather
by ardie Sun Mar 18, 2018 3:34 pm
by bagtoracer68 Sat Mar 17, 2018 5:47 pm
» Found me the perfect hoodie
by hawktheslayer Mon Mar 12, 2018 9:29 pm
» VS 750 rat bike
by grumpy grandad Mon Mar 12, 2018 6:05 pm
» New leathers ordered
by bagtoracer68 Sun Mar 11, 2018 2:34 am
» No sparks
by peardrop3 Fri Mar 09, 2018 1:33 pm
» Halogen/LED Headlamp Upgrade?
by bagtoracer68 Tue Mar 06, 2018 4:02 pm
» Fin Corrosion; Cleaning and Prevention?
by bagtoracer68 Tue Mar 06, 2018 12:55 am
» Hello from Upstate New York in the U.S.
by simbo Fri Mar 02, 2018 7:59 pm
» Hello Everyone
by bagtoracer68 Wed Feb 28, 2018 6:42 pm
» Powder coat wheels
by bagtoracer68 Mon Feb 26, 2018 5:21 pm
» Handle bar size
by bagtoracer68 Sat Feb 24, 2018 7:30 pm
