 EFI conversion on VS800
4 posters
DIYer
EFI conversion on VS800 Empty
PostSubject: EFI conversion on VS800   EFI conversion on VS800 Icon_minitimeWed May 19, 2021 8:09 pm
Hi all,
Well, please excuse my English but it is not my native one. After some struggling with weak rear cylinder and misfiring, followed by carbs inspection and refreshing and purchase of new fuel pump, finally I threw the towel and decided to take the easier way. The switch to EFI was on the table. The motor proved to be mechanically in sound condition. I didn't found any similar EFI conversion on this bike so this is probably the only existing EFI conversion on VS800.
Here is the beginning:
EFI conversion on VS800 49528675323_f401e70ecb_k
EFI conversion on VS800 49528674718_90b75bcd65_k
EFI conversion on VS800 49529407442_28dd496fde_k
EFI conversion on VS800 49529180196_ba285f6b2f_k
EFI conversion on VS800 49528673718_8c8afb8480_k
EFI conversion on VS800 49529406702_28ce30b1a9_k
Here are the baked generator coils. Fortunately still functional and no short to ground or interna in the coils. Later will take care for that too.
EFI conversion on VS800 49529406492_98f8e5ab89_k
EFI conversion on VS800 49529406277_96d7a05320_k
EFI conversion on VS800 49529406067_a5a70b1c7f_k
EFI conversion on VS800 49529405892_14afc4f353_k
The coil connectors to the regulator/rectifier:
EFI conversion on VS800 49529405717_87539fd98f_k
Here is where the new regulator will be wired but ... later:
EFI conversion on VS800 49529405537_23558df311_k
Needed new crank position trigger wheel with much more resolution:
EFI conversion on VS800 49529405337_a39bdf211e_k
DIY 24 tooth trigger ring/wheel and rotor/FW removing clamp:
EFI conversion on VS800 49528671738_78d6be60d4_k
EFI conversion on VS800 49529404957_2c3f847756_k
EFI conversion on VS800 49528671448_ae0f408e59_k
EFI conversion on VS800 49529177526_22bb50d85e_k
EFI conversion on VS800 49529177356_03b22a9bd3_k
EFI conversion on VS800 49529404187_897130248c_k
EFI conversion on VS800 49529403907_cc3a0140a3_k
At the same time the Ducati Monster 796 throttle bodies transformation has begun. I bought the throttles on ebay.co.uk for 29GBP. I choose these because of the similar CID as the VS800 and the low price (incl. he injectors and TPS sensor):
EFI conversion on VS800 49529403622_a071479af3_k
Had to modify them because of the limited space in the frame:
EFI conversion on VS800 49528670183_1cbb5dc36c_k
EFI conversion on VS800 49529176356_ad2643f4c2_k
EFI conversion on VS800 49529176161_87aef5bd3b_k
EFI conversion on VS800 49528669443_07d15155c0_k
EFI conversion on VS800 49529175941_38e9590de1_k
Decided to use the OEM crank position/rpm sensor:
EFI conversion on VS800 49528669268_1c14e78a7b_k
EFI conversion on VS800 49529397297_681366cb8e_k
EFI conversion on VS800 49529402182_f8a60ba495_k[
EFI conversion on VS800 49528669063_7053895ebf_k
EFI conversion on VS800 49529401887_3c94a37d6c_k
Deciding where to place the missing tooth based on the Megasquirt manual:
EFI conversion on VS800 49529174496_9cf6f650c9_k
Had to be very cautious because this is an odd fire V-Twin engine and the correct place is where the cranking rpms are relatively stable/constant, i.e. no compression strokes:
EFI conversion on VS800 49528667503_7c56746b38_k
EFI conversion on VS800 49529400767_f2aaf9d4c6_k
Let me post now because I don't want to lose the uploaded so far.
DIYer
PostSubject: Re: EFI conversion on VS800   EFI conversion on VS800 Icon_minitimeWed May 19, 2021 8:58 pm
EFI conversion on VS800 49529400572_e93bcd61fd_k
EFI conversion on VS800 49529173486_ec1e7d65c9_k
EFI conversion on VS800 49529173211_ebc1a3ecf7_k
EFI conversion on VS800 49529172326_afb9825b38_k
There is no space for the tps sensor so I had to move it down:
EFI conversion on VS800 49528665693_8956b42c2b_k
EFI conversion on VS800 49528665238_25821a16cb_k
EFI conversion on VS800 49528665098_d30a2fd898_k
EFI conversion on VS800 49528664913_48de7a6689_k
EFI conversion on VS800 49528664523_8ed23ee5b9_k
EFI conversion on VS800 49529397792_530c824fdf_k
EFI conversion on VS800 49529397612_c8eae129bc_k
EFI conversion on VS800 49528663998_5f7c856ea1_k
EFI conversion on VS800 49529329956_a2838b951a_k
Using the OEM throttle cables:
EFI conversion on VS800 49529557467_f9bba26103_k
EFI conversion on VS800 49528825688_22feb36a92_k
DIYer
PostSubject: Re: EFI conversion on VS800   EFI conversion on VS800 Icon_minitimeWed May 19, 2021 9:31 pm
EFI conversion on VS800 49528825433_f0578a83be_k
EFI conversion on VS800 49529457497_745a697eb2_b
EFI conversion on VS800 49529328591_b7e8b43b49_k
EFI conversion on VS800 49528824913_cb620335fa_k
EFI conversion on VS800 49529327971_54dd46704e_k
EFI conversion on VS800 49528824418_945bb260e4_k
The throttle adaptors because the Ducati ones have 45mm ID compared to the Suzuki's 36mm:
EFI conversion on VS800 49529327626_606c44f868_k
I didn't want so bigger throttles but that's how it happened. I expect more "jumpy" throttle responce and probably some more power.
EFI conversion on VS800 49528824008_7af3385f3b_k
The work on the rear throttle begun
EFI conversion on VS800 49529555402_fb45e0e7aa_k
EFI conversion on VS800 49529555262_4bab7c01a8_k
EFI conversion on VS800 49529555097_75378470fe_k
EFI conversion on VS800 49528823378_e2bc169a65_k
Had only about 80mm to fit the throttle between the frame bars:
EFI conversion on VS800 49528823073_d0cd9d7af2_k
EFI conversion on VS800 49529326266_b326b876fd_k
EFI conversion on VS800 49528822688_cda349ee3a_k
EFI conversion on VS800 49528822263_d56b518bb8_k
EFI conversion on VS800 49529441727_ca0d6c93e5_b
EFI conversion on VS800 49528822023_1958ce4930_k
DIYer
PostSubject: Re: EFI conversion on VS800   EFI conversion on VS800 Icon_minitimeFri May 21, 2021 7:58 pm
EFI conversion on VS800 49529325241_fd02a0528f_k
EFI conversion on VS800 49528821203_5d8e8a7f36_k
EFI conversion on VS800 49529552077_14bb24b526_k
EFI conversion on VS800 49528820498_7c4ad18efd_k
EFI conversion on VS800 49529551772_ed68f05aa0_k
EFI conversion on VS800 49528820068_98e19e23e6_k
EFI conversion on VS800 49529323206_1acb3d5ac5_k
EFI conversion on VS800 49529551192_2548df45b0_k
EFI conversion on VS800 49528819603_4fb8af2cb4_k
EFI conversion on VS800 49529550792_f992851e93_k
EFI conversion on VS800 49529550567_e73300c2c6_k
EFI conversion on VS800 49528819068_7256ebbe97_k
EFI conversion on VS800 49529550167_f5f2761f48_k
EFI conversion on VS800 49529549862_c224d12978_k
EFI conversion on VS800 49528818488_8753385945_k
EFI conversion on VS800 49529321436_b8307dc970_k
EFI conversion on VS800 49528794408_b83d4f3ce5_k
EFI conversion on VS800 49529298581_026119a6ef_k
EFI conversion on VS800 49529525702_4f780d2528_k
The GM 1 bar MAP sensor:
EFI conversion on VS800 49529298091_274e895247_k
The BOSCH idle control valve:
EFI conversion on VS800 49528793508_dd897c33d1_k
EFI conversion on VS800 49529296996_fdaac08624_k
EFI conversion on VS800 49528791903_eef39df433_k
EFI conversion on VS800 49529523132_14a5a07555_k
DIYer
PostSubject: Re: EFI conversion on VS800   EFI conversion on VS800 Icon_minitimeFri May 21, 2021 9:01 pm
EFI conversion on VS800 49529522782_731f942856_k
EFI conversion on VS800 49529294871_97f5acbe5f_k
The fuel filter:
EFI conversion on VS800 49529294706_15fe5f5882_k
EFI conversion on VS800 49529294076_54a4dce1e6_k
EFI conversion on VS800 49528790008_c249289cf9_k
EFI conversion on VS800 49528789863_8af87c59dc_k
EFI conversion on VS800 49528789633_5e71f660c1_k
EFI conversion on VS800 49529520987_0e6d0f4ad5_k
EFI conversion on VS800 49529293036_745b035956_k
EFI conversion on VS800 49529292831_b150312507_k
The WBO2 bungs on both downpires:
EFI conversion on VS800 49529292221_46f53537e9_k
EFI conversion on VS800 49529519967_0fc99201f9_k
EFI conversion on VS800 49529487912_63f1a6bc22_k
EFI conversion on VS800 49528754933_5e1d856a22_k
EFI conversion on VS800 49529259196_e568bbec34_k
EFI conversion on VS800 49528754293_546127506a_k
EFI conversion on VS800 49528753738_93fbbd1635_k
EFI conversion on VS800 49529485847_47ea4ec0ce_k
EFI conversion on VS800 49528752963_8c09b83388_k
EFI conversion on VS800 49529485162_3acacc98a0_k
The IAT sensor placement:
EFI conversion on VS800 49528751723_7266a63dc8_k
The COP ign. coil swap:
EFI conversion on VS800 49529255831_0f1fba2de2_k
EFI conversion on VS800 49529255676_ee5f519d92_k
A VAG COP:
EFI conversion on VS800 49529255466_21ceb0d9fc_k
EFI conversion on VS800 49528750963_6081366423_k
EFI conversion on VS800 49529483457_4d556a712a_k
EFI conversion on VS800 49528750443_0f50d2f0d4_k
EFI conversion on VS800 49528750143_96d7cebf8e_k
EFI conversion on VS800 49529481972_86de82caed_k
EFI conversion on VS800 49528749298_b9fe887b86_k
EFI conversion on VS800 49529480907_f9812ce967_k
EFI conversion on VS800 49528747823_aeda7efb4b_k
EFI conversion on VS800 49529251706_808e4f4fb4_k
EFI conversion on VS800 49529479807_8adb979f76_k
EFI conversion on VS800 49529479337_b978936ca0_k
EFI conversion on VS800 49528746508_98c4fc1724_k
EFI conversion on VS800 49528746333_555c09bfbd_k
EFI conversion on VS800 49528745953_c78a4e7ef8_k
EFI conversion on VS800 49528745808_4d8f492091_k
The Ducati fuel injector:
EFI conversion on VS800 49529250046_c6394ac77a_k
EFI conversion on VS800 49529478057_9383c29996_k
EFI conversion on VS800 49529477837_bd8ab4537a_k
EFI conversion on VS800 49529248801_5a8a863437_k
EFI conversion on VS800 49528743878_a3bc31ae82_k
EFI conversion on VS800 49528743733_6e57d0a2c6_k
EFI conversion on VS800 49529248336_08b7c84542_k
EFI conversion on VS800 49529248176_0b66182e3f_k
EFI conversion on VS800 49528725823_de949dfd99_k
DIYer
PostSubject: Re: EFI conversion on VS800   EFI conversion on VS800 Icon_minitimeMon May 24, 2021 7:44 pm
The fuel regulator & housing:
EFI conversion on VS800 49529458527_4ec9213c58_k
EFI conversion on VS800 49529230031_96d83cf17a_k
EFI conversion on VS800 49528724543_c4d4d2d479_k
EFI conversion on VS800 49528698863_f885584e30_k
The Ducati throttles as they came from UK ebay:
EFI conversion on VS800 49696378578_8f19d793d3_k
My WBO2 controller and sensor kit. Later will receive one more kit for the other cylinder. The Microsquirt ECU has option for independent cylinder fuel corrections based on its own WBO2 sensor readings. That means much better fuel control and MPG. The fuel control is already in my hands :-)
EFI conversion on VS800 49696397428_e88c90390a_k
EFI conversion on VS800 49696399203_0a40d2e2a3_k
These are out forever! There's no way back!
EFI conversion on VS800 49696942436_c60b724f13_k
Here is a scope of the original trigger signal and 1st cyl coil control:
EFI conversion on VS800 49698138026_41fdb892cd_k
Here are the two coils control signals:
EFI conversion on VS800 49698449632_47457c0422_k
The new crankshaft trigger wheel with 24-1 teeth:
EFI conversion on VS800 49698752072_47bf9b8a39_k
EFI conversion on VS800 49701121786_4a0815652a_k
The DIY WBO2 cable extension to the WBO2 controller mounted under the seat. Two extension cables for both sensors/cylinders:
EFI conversion on VS800 49701470087_6de2cfca41_k
EFI conversion on VS800 49700627118_60cb786aa9_k
The first wireless (WiFi) ECU connection to the laptop:
EFI conversion on VS800 49701161471_b7bdb408c9_k
For sequential engine control I had to install synch sensor:
EFI conversion on VS800 49701468932_6b05e451c4_k
EFI conversion on VS800 49701160381_9559f36fdc_k
EFI conversion on VS800 49700626163_b4e363d1e2_k
EFI conversion on VS800 49701468117_57f05a380a_k
Adding a WiFi module to the setup:
EFI conversion on VS800 49700625773_db9f2f3903_k
How the WBO2 bungs install began:
EFI conversion on VS800 49701159331_f2f854142d_k
EFI conversion on VS800 49701467452_af2a8a24ea_k
EFI conversion on VS800 49700624888_fd44abc126_k
EFI conversion on VS800 49700624398_bea0b7a0a5_k
EFI conversion on VS800 49701157466_9bf829de10_k
EFI conversion on VS800 49701156941_4004d7783b_k
EFI conversion on VS800 49700622763_fb05ac2c56_k
EFI conversion on VS800 49700622573_56f51200f4_k
First start attempt:
EFI conversion on VS800 49701156121_a611c81b66_k
Vacuum connections:
EFI conversion on VS800 49701464162_45f95830f5_k
Making scope files for the MSExtra forum help desk:
EFI conversion on VS800 49700621683_77f3d5e2c9_k
Removed forever:
EFI conversion on VS800 49700621433_3e0744422e_k
EFI conversion on VS800 49700621183_cd14600783_k
The engine control put on paper:
EFI conversion on VS800 49700620603_49778d8fbe_k
The front cyl with the coil and the sync sensor in the back:
EFI conversion on VS800 49701462397_0c6785b95a_k
First views of the Android based dash on my smart phone. There are four different screen layouts with option for showing what engine parameter to be shown:
EFI conversion on VS800 49701150676_bf77ced6a6_k
EFI conversion on VS800 49700617103_e88fd142a1_k
EFI conversion on VS800 49701462027_d21b8ec35d_k
EFI conversion on VS800 49701461742_de9bde73fe_k
The new coil control signal capture:
EFI conversion on VS800 49700619438_678ebde089_k
A working screen on my tuning laptop:
EFI conversion on VS800 49701460637_fe098fc01b_k
Connected:
EFI conversion on VS800 49701152131_68ec80b16d_k
Added heatshield to protect the fuel lines and the fuel regulator from unwanted temp. rise:
EFI conversion on VS800 49700618093_80638936c8_k
EFI conversion on VS800 49701151566_b242ea1100_k
DIYer
PostSubject: Re: EFI conversion on VS800   EFI conversion on VS800 Icon_minitimeMon May 24, 2021 8:02 pm
EFI conversion on VS800 49700617628_6a2744da26_k
Some older pics when I was still trying to save the carbs:
EFI conversion on VS800 49704567836_1704a8f53f_b
Few of the many adustment screens:
EFI conversion on VS800 49708272728_d6b670947b_k
EFI conversion on VS800 49708806841_abd65744ac_k
EFI conversion on VS800 49708271578_e1c6b12bf0_k
That's all for now. Still more to come.
Thanks for watching!
Badger
Badger
PostSubject: Re: EFI conversion on VS800   EFI conversion on VS800 Icon_minitimeWed May 26, 2021 1:57 pm
Wow ...  that's the most detailed and complex post I think I've seen here.
Mostly the chat is about fairly basic stuff.
well done.    EFI conversion on VS800 276246
DIYer likes this post
ArnoldinIdaho
PostSubject: Re: EFI conversion on VS800   EFI conversion on VS800 Icon_minitimeFri Jun 04, 2021 2:39 am
What planet are you from?  Certainly a highly advanced engineering culture!
mcitours
PostSubject: Re: EFI conversion on VS800   EFI conversion on VS800 Icon_minitimeFri Jun 04, 2021 2:27 pm
Staggered by the commitment to this project.
I have been playing with Tune ECU on a KTM RC8R but this is way more sophisticated...
DIYer
PostSubject: Re: EFI conversion on VS800   EFI conversion on VS800 Icon_minitimeFri Jun 04, 2021 9:39 pm
Hey guys,
Your comments made me feel very proud. Thank you very much! But let me stop with the chat and post the next portion of pictures.
Just recently started the engine suddenly stopped. A bit later it appeared the fuel pump has failed due to unknown reason. Probably some weld remainings in the small fuel tank have been sucked up and have damaged the pump impeler. I consider this as my fault as I was lazy enough to skip the fine strainer on the fuel pump inlet. Thought the petcock's strainer would be enough:
EFI conversion on VS800 49815656108_e70f4e93e2_k
EFI conversion on VS800 49816192116_fb18ff5bdf_k
Bought also a new battery:
EFI conversion on VS800 49816502247_4fccd72663_k
Decided to move the idle valve over the cyl. head and replace it with an external pump:
EFI conversion on VS800 49816191706_cd356d7517_k
EFI conversion on VS800 49816501992_250749ba1a_k
EFI conversion on VS800 49816191491_2313359907_k
EFI conversion on VS800 49815655363_8755a3e490_k
EFI conversion on VS800 50215025841_4a931425ad_k
EFI conversion on VS800 50215043191_54a15219ea_k
EFI conversion on VS800 50214521563_69940f118c_k
Meanwhile the chosen external low flow and low current Walbro pump appeared as non available worldwide anymore, and also due to the its higher price I decided to go back to the intank pump location. The new 3bar pump was ordered again from ebay.uk for about 15 euro.
EFI conversion on VS800 50215313552_dd5887d18f_k
...this time with additional strainer:
EFI conversion on VS800 50215042966_681e864396_k
Soon I found that an intank designed pump can't be used as partially intank because of fuel leaks around the el. terminals. Hence my next step was to make it fully closed in the tank:
EFI conversion on VS800 50215311552_ee4740a10e_k
EFI conversion on VS800 50215312932_cdfef72ad8_k
EFI conversion on VS800 50214521388_04118f8117_k
EFI conversion on VS800 50214523053_bb3a1307a1_k
EFI conversion on VS800 50215045111_173df14fda_k
EFI conversion on VS800 50215045626_0c088723cb_k
EFI conversion on VS800 50214523258_901a70bf5d_k
EFI conversion on VS800 50215044336_7cb9678c17_k
EFI conversion on VS800 50215313302_1496f0f589_k
First time out of the garage:
EFI conversion on VS800 50215312347_fdae587ae3_k
... and the first drive on EFI:
EFI conversion on VS800 50214520328_bb5f5f6fb3_k
EFI conversion on VS800 50215108093_ae82173014_k
First trip out of the city:
EFI conversion on VS800 50314976541_51575a3a11_k
EFI conversion on VS800 50314975766_2e25b72902_k
Later will post some videos from the project.
Thanks!
DIYer
PostSubject: Re: EFI conversion on VS800   EFI conversion on VS800 Icon_minitimeFri Jun 25, 2021 2:35 pm
Hello all,
Here are the promised videos:
https://www.youtube.com/watch?v=uk7C1fgJufM
https://www.youtube.com/watch?v=9TMKgQ9vkug
https://www.youtube.com/watch?v=zMSOmn7ZPUM
https://www.youtube.com/watch?v=62hqkN2aT80
» VX800 conversion to cruiser
» Trike conversion query
» Belt conversion Yay or nay?
» C90/VL 1500 Drive conversion
» Drive conversion and mileage
EFI conversion on VS800 Icon_minitimeby alongfortheride Tue Mar 26, 2024 9:41 pm
EFI conversion on VS800 Icon_minitimeby SAM11206 Wed Mar 20, 2024 6:34 pm
EFI conversion on VS800 Icon_minitimeby Onigatudor Wed Mar 20, 2024 2:39 pm
EFI conversion on VS800 Icon_minitimeby flying1 Wed Mar 13, 2024 4:43 pm
EFI conversion on VS800 Icon_minitimeby nano Tue Mar 05, 2024 2:19 pm
EFI conversion on VS800 Icon_minitimeby Brianhuck Sat Mar 02, 2024 7:30 pm
EFI conversion on VS800 Icon_minitimeby Billybop90 Fri Mar 01, 2024 12:44 am
EFI conversion on VS800 Icon_minitimeby Aikido789 Sat Feb 24, 2024 10:11 am
EFI conversion on VS800 Icon_minitimeby bernard chaddock Wed Feb 21, 2024 5:06 pm
EFI conversion on VS800 Icon_minitimeby bernard chaddock Wed Feb 21, 2024 4:58 pm
EFI conversion on VS800 Icon_minitimeby fabio almeida Tue Feb 20, 2024 9:28 am
EFI conversion on VS800 Icon_minitimeby icoolwecool99@gmail.com Mon Feb 19, 2024 9:47 pm
EFI conversion on VS800 Icon_minitimeby Billybop90 Fri Feb 16, 2024 7:16 pm
EFI conversion on VS800 Icon_minitimeby SWEET Fri Feb 16, 2024 6:25 pm
EFI conversion on VS800 Icon_minitimeby VAI777 Tue Feb 13, 2024 3:32 pm
EFI conversion on VS800 Icon_minitimeby redevil Tue Feb 13, 2024 10:59 am
EFI conversion on VS800 Icon_minitimeby Urko Sun Feb 11, 2024 11:12 am
EFI conversion on VS800 Icon_minitimeby CS_0427 Tue Feb 06, 2024 2:28 am
EFI conversion on VS800 Icon_minitimeby Badger Mon Feb 05, 2024 11:27 am
EFI conversion on VS800 Icon_minitimeby John Silver Sun Feb 04, 2024 7:05 pm
