 VZ800 ran rich, now lean under acceleration
SinCityLocal
SinCityLocal
VZ800 ran rich, now lean under acceleration Empty
PostSubject: VZ800 ran rich, now lean under acceleration   VZ800 ran rich, now lean under acceleration Icon_minitimeMon Apr 10, 2017 4:15 am
A few weeks ago, I got the bike out for the first spring ride for a couple hours. The engine ran rich, and after highway runs, I had to babysit the throttle to keep it from stalling. I parked it in the garage and made no adjustments.
Last weekend, I tried to run it up the street, expecting the same situation. When I accelerated, it pulled hard, but then immediately fell on its face. After some investigating, I found a lean condition now. I pulled both carbs, checked for debris, and cleaned them thoroughly, checked float levels, and reassembled the bike. When I started and revved the engine, it ran strong then rpm dropped and lots of backfiring from the exhaust. Several times today, I did this same process, thinking there's something I missed. I found nothing amiss with either carburetor. If I cover the main air jets with my fingers, it seems to perform properly. I even swapped a spare rear carb, and got the same results. I'm about to lose my mind...
Does anybody have an idea of what to do now?
hmac
hmac
PostSubject: Re: VZ800 ran rich, now lean under acceleration   VZ800 ran rich, now lean under acceleration Icon_minitimeTue Apr 11, 2017 12:13 am
Have you put fresh gas in?
SinCityLocal
SinCityLocal
PostSubject: Re: VZ800 ran rich, now lean under acceleration   VZ800 ran rich, now lean under acceleration Icon_minitimeTue Apr 11, 2017 12:32 am
Yes.
SinCityLocal
SinCityLocal
PostSubject: Re: VZ800 ran rich, now lean under acceleration   VZ800 ran rich, now lean under acceleration Icon_minitimeTue Apr 11, 2017 4:33 am
I posted my situation on another site. As it turns out, my folly was running with the carbs open. It was explained to me, that the filter boxes act somewhat as restrictors, and the engine shouldn't even run without them. That explains why it wouldn't do much more than idle. Once I put the filters back together and synchronized the carbs, it ran great!
PostSubject: Re: VZ800 ran rich, now lean under acceleration   VZ800 ran rich, now lean under acceleration Icon_minitimeTue Apr 11, 2017 8:11 am
Glad you got your answer :)
Lots of members on here have fuel injected bikes, so may not have known the answer...
» Weltklasse Zürich (SUI) Diamond league- Thurs, Aug 30 RESULTS, Bolt 19.66 & Rudisha 2nd
» Very rich people in the NE
» Paul Walker's example - How the famous &/or rich should use their wealth
» SAFC IN WORLDS TOP 50 RICH LIST
» Going out on a Hyde
VZ800 ran rich, now lean under acceleration Icon_minitimeby stingray Mon Feb 17, 2020 8:38 am
» Crash Bars
VZ800 ran rich, now lean under acceleration Icon_minitimeby Ish992019 Sun Feb 16, 2020 9:26 pm
VZ800 ran rich, now lean under acceleration Icon_minitimeby pledge Sun Feb 16, 2020 3:29 pm
VZ800 ran rich, now lean under acceleration Icon_minitimeby RonB58 Fri Feb 14, 2020 5:59 pm
VZ800 ran rich, now lean under acceleration Icon_minitimeby ardie Fri Feb 14, 2020 11:42 am
» New member in Florida
VZ800 ran rich, now lean under acceleration Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 6:08 pm
VZ800 ran rich, now lean under acceleration Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:51 am
» VS1400 rear end on a VS750
VZ800 ran rich, now lean under acceleration Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:42 am
» Led turn signals!
VZ800 ran rich, now lean under acceleration Icon_minitimeby mhicks2517 Tue Feb 11, 2020 5:38 pm
VZ800 ran rich, now lean under acceleration Icon_minitimeby DickB Tue Feb 11, 2020 12:05 pm
VZ800 ran rich, now lean under acceleration Icon_minitimeby steve co Fri Feb 07, 2020 2:03 pm
VZ800 ran rich, now lean under acceleration Icon_minitimeby steve co Fri Feb 07, 2020 1:40 pm
VZ800 ran rich, now lean under acceleration Icon_minitimeby steve co Fri Feb 07, 2020 1:28 pm
» Newby
VZ800 ran rich, now lean under acceleration Icon_minitimeby malone55 Mon Feb 03, 2020 1:58 pm
» Hello from Stockholm
VZ800 ran rich, now lean under acceleration Icon_minitimeby stingray Mon Feb 03, 2020 9:49 am
» Glad to be here!
VZ800 ran rich, now lean under acceleration Icon_minitimeby stingray Mon Feb 03, 2020 9:48 am
» Hey Guys
VZ800 ran rich, now lean under acceleration Icon_minitimeby oldtom Sun Feb 02, 2020 12:49 pm
» White walls
VZ800 ran rich, now lean under acceleration Icon_minitimeby ardie Mon Jan 27, 2020 7:52 pm
VZ800 ran rich, now lean under acceleration Icon_minitimeby creol Sat Jan 25, 2020 8:24 am
» Back in the saddle.
VZ800 ran rich, now lean under acceleration Icon_minitimeby ardie Fri Jan 24, 2020 8:13 pm
