 VZ800 Jetting question
HolmZ
VZ800 Jetting question Empty
PostSubject: VZ800 Jetting question   VZ800 Jetting question Icon_minitimeMon Apr 10, 2017 6:27 pm
Hi, I notice there's a post from back in 2013 put up as a guide to jet sizes for various configurations. I'm a bit confused by it, I've a 1999 VZ800 and on it the front and rear carbs are fitted with different size jets, the guide doesn't reflect this, or am I missunderstanding the guide, anyone able to clarify or alternately, anyone have experience fitting a stage 2 jet kit I'd love to hear from you? Cheers.
hmac
hmac
PostSubject: Re: VZ800 Jetting question   VZ800 Jetting question Icon_minitimeTue Apr 11, 2017 12:10 am
Different sized jets front and rear seems to be normal on the VZ.  A little bit of home work for you http://home.wyan.org/~jrhdlh/jetting.txt
SinCityLocal
SinCityLocal
PostSubject: Re: VZ800 Jetting question   VZ800 Jetting question Icon_minitimeTue Apr 11, 2017 4:40 am
Yep, my 97 VZ has 100 in the front, and 90 in the rear.
HolmZ
PostSubject: Re: VZ800 Jetting question   VZ800 Jetting question Icon_minitimeTue Apr 11, 2017 11:03 am
Thanks hmac, must be an omen, found this same link last night myself while googling down the back of the internet and ordered some jets based on what I read.
Originally tackled this using a kit I bought from the US but going by the direct experience of the guys who've posted that info, the kit is out by as much as 30...recommendation was 95/105 just 5 up from stock, what's needed for my set up (Straight through 50mm Highway Hawks/K&N SU5589's box mounted high flows) is around 122.5/132.5 - 125/135.
I'll post again once I've tried the larger jets and let you guys know how it goes.
Thanks guys for your replies, good to know this is such an active forum,
hmac
hmac
PostSubject: Re: VZ800 Jetting question   VZ800 Jetting question Icon_minitimeTue Apr 11, 2017 11:55 am
Let us know how you get on, I'm tempted to do mine.
Are you the owner of  the  Marauder with the custom paint job I met at the Alba West show?
VZ800 Jetting question 10492303_690431577728011_306439869016223777_n
HolmZ
PostSubject: Re: VZ800 Jetting question   VZ800 Jetting question Icon_minitimeTue Apr 11, 2017 1:05 pm
I'm impressed, how did you figure that out? Yes, how you doing, still haven't moved forward with the back end job I wanted to do so still looking at yours with envy. I'll defo post how I get on once I've got the bike up and running, what drove me down this path was that the bike won't run with straight through pipes on the stock set up...or at least mine won't, just overheats with being way too lean. Gutted, thought it was all ok back in October, wasn't until I got it out on the road and above half throttle that I realised there was a big problem...or as it looks a too small jet problem, still it's the joys of biking eh. All ok with you and yours, nice to hear from you in any case?
hmac
hmac
PostSubject: Re: VZ800 Jetting question   VZ800 Jetting question Icon_minitimeWed Apr 12, 2017 12:16 am
Not many Marauders in Scotland, apart from ours I've only seen three. When I saw your handle and that you were in Scotland a wee bell rung and I remembered speaking to Brian Holmes at  the Alba West. Not done much to the bike since you saw it, been enjoying riding it too much.
Did you do anything about forward controls? You spoke about getting something like mine made up.
Maybe see you at Alba or some of the other rallies over the summer.
HolmZ
PostSubject: Re: VZ800 Jetting question   VZ800 Jetting question Icon_minitimeWed Apr 12, 2017 8:10 pm
...thought I was Sherlock! Yeh, you're right you don't see many going around.
Naw, likewise not much changed, got close to rear end mods, had the mudguard off for cloning by a friend who's into fibreglassing, didn't happen though, he moved up to the 21 and found he'd no time too himself so it got bunged back on. Forward pegs I decided against, in the cold light of day I realised I need to be about four inches longer in the leg to justify it. Probably end up with something different but not forward, just for looks.
Hoping the new jets arrive tomorrow so I can give them a try and hopefully get up and running.
You ever do the Leadburn Thursday nights?
HolmZ
PostSubject: Re: VZ800 Jetting question   VZ800 Jetting question Icon_minitimeThu Apr 13, 2017 7:28 pm
Just a quick post. Received and fitted a 125/135 main jet pair today, absolutely no issues at an point through the full throttle range, short run as no MOT so don't know what the top end is like, but was still accelerating through 90 when I backed it off. Extra oomph can't be missed and detected no flat spots, all looking good. Will put up a full post with all the details once I've put in a few miles and checked plugs etc.
Happy biker.
hmac
hmac
PostSubject: Re: VZ800 Jetting question   VZ800 Jetting question Icon_minitimeThu Apr 13, 2017 8:16 pm
Sounds like you got a good result with those jets. What gearing are you running? I found the stock setup way undergeared, so I  got rid of the 15 tooth front sprocket and replaced it with a 17 and kept the standard 48 rear. Really made a difference to the bike, still accelerates well and the engine is a lot less stressed at motorway speeds.
One advantage for me having the forward pegs is I no longer leave a trail of sparks at every other roundabout, might be worth looking at raising yours an inch or two.
Not been to the Leadburn yet, probably take a trip over there one fine summer evening.
HolmZ
PostSubject: Re: VZ800 Jetting question   VZ800 Jetting question Icon_minitimeFri Apr 14, 2017 10:37 am
I'll take a look at the sprocket sizing, if you decide a trip to the Leady, first Thursday of the month is the big one, that's the night they have trade stalls and the like, drop me a line if you're coming and I'll treat you to a coffee.
» Beartracker Jetting Question
» Pulley Question
» grip strength advice..ask david horne any question on grip training....
» Level Adjust Question
» Boston Qualifying Question
VZ800 Jetting question Icon_minitimeby Breeze42355 Sun Feb 23, 2020 10:31 pm
VZ800 Jetting question Icon_minitimeby ardie Sat Feb 22, 2020 6:49 pm
» Crash Bars
VZ800 Jetting question Icon_minitimeby Ish992019 Sun Feb 16, 2020 9:26 pm
VZ800 Jetting question Icon_minitimeby pledge Sun Feb 16, 2020 3:29 pm
VZ800 Jetting question Icon_minitimeby RonB58 Fri Feb 14, 2020 5:59 pm
VZ800 Jetting question Icon_minitimeby ardie Fri Feb 14, 2020 11:42 am
» New member in Florida
VZ800 Jetting question Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 6:08 pm
VZ800 Jetting question Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:51 am
» VS1400 rear end on a VS750
VZ800 Jetting question Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:42 am
» Led turn signals!
VZ800 Jetting question Icon_minitimeby mhicks2517 Tue Feb 11, 2020 5:38 pm
VZ800 Jetting question Icon_minitimeby DickB Tue Feb 11, 2020 12:05 pm
VZ800 Jetting question Icon_minitimeby steve co Fri Feb 07, 2020 2:03 pm
VZ800 Jetting question Icon_minitimeby steve co Fri Feb 07, 2020 1:40 pm
VZ800 Jetting question Icon_minitimeby steve co Fri Feb 07, 2020 1:28 pm
» Newby
VZ800 Jetting question Icon_minitimeby malone55 Mon Feb 03, 2020 1:58 pm
» Hello from Stockholm
VZ800 Jetting question Icon_minitimeby stingray Mon Feb 03, 2020 9:49 am
» Glad to be here!
VZ800 Jetting question Icon_minitimeby stingray Mon Feb 03, 2020 9:48 am
» Hey Guys
VZ800 Jetting question Icon_minitimeby oldtom Sun Feb 02, 2020 12:49 pm
» White walls
VZ800 Jetting question Icon_minitimeby ardie Mon Jan 27, 2020 7:52 pm
VZ800 Jetting question Icon_minitimeby creol Sat Jan 25, 2020 8:24 am
