| | fuel | |
+4v-twin ardie simbo OldManYam 8 posters | Author | Message |
ardie Valued Member
| Subject: fuel Tue Jul 04, 2017 9:11 pm | |
| Right guys had this for awhile now was always got 180mls plus to a full tank, plugs air filter oil all changed once a year tyre pressure always done, the last year gone down to 160 at most. I have lost 25mls on a tank .the only thing I can now think of is this. I changed from the original tyres irc to dunlops front and back around the same time I started to notice this. Has anyone had drop or increase in mpg after a change of tyres .4000 mls on bike when I got it 8500mls now . | |
| Subject: Re: fuel Tue Jul 04, 2017 10:00 pm | |
| It's not impossible for tyres to have different characteristics that will effect the rolling resistance, and ultimately the fuel consumption ..... but it would be surprising if a change of tyres gave a 14% drop in fuel consumption ...... unless you've fitted very sticky tyres (Which would not last as long as the previous tyres).
Might be worth checking if there is any sticking on your brakes (Caliper pistons especially). Could be worth stripping down your brake pads & cleaning the pivot pins etc. - as even some light dragging of brake components would potentially effect your fuel consumption. Is there any significant build up of heat on your discs after a short run where you have minimal use of the brakes ? ..... if so it would suggest a problem in the braking system.
Its also worth remembering brake fluid should be changed every two years. Not only does the efficiency of brake fluid deteriorate with age (due to moisture absorption), it can promote internal corrosion in the brake system if fresh fluid is not introduced. (i.e. Old fluid with moisture absorbed can lead to promotion).
Hope that might help, | |
| | | | ardie Valued Member
| Subject: Re: fuel Tue Jul 04, 2017 11:56 pm | |
| Cheers YAM and SIM pads were changed 500 miles ago, cleaned every thing at the time rear shoes don't need changed till after SUMMER when I intend to do the shaft lube as when I did it last year hadn't got the dust seal in time so everything greased apart from behind the seal but cleaned every thing in there as well.Will double check the heat on disc and shoe area after short run, will change brake fluid asap .Had beef and guiness pie yesterday sim you spying on me thanks again guys cant get my head round it being the tyres .Brake adjustment done as you say Sim under load | |
| Subject: Re: fuel Wed Jul 05, 2017 7:40 am | |
| Radial tyres are more fuel efficient then Cross-Ply tyres (A Quote from Michelin - Another factor is rolling resistance. At all but very low speeds this resistance is dwarfed by the resistance extended on the body of the car by its passenger through the air. The principle contributor to rolling resistance is the friction provided by the loaded tires of the vehicle. Newer tire designs, in particular the steel belted radialply tires, provide a substantial reduction ranging from 15 percent on ice to 45 percent on sand. This may be translated into a fuel economy of 5 to 10 percent on the average road.), so that may be a factor but as Yam said, a 14% difference seems a lot. How long have you had the bike???? When you were getting the better range, were you conscious of the condition of your old tyres so you took it a bit 'easier', then when you changed the tyres you are now a hooligan again?? Traffic levels are increasing all the time, so average speeds are decreasing and using the gears/throttle more will also not help due to the traffic. Are you so used to the bike now that you are using the gears/throttle more??? Slightly binding Brakes will have an impact but it does not sound like that is the case. Have you changed the type of fuel you use, some people say that using Super Unleaded can get up 10% better Fuel Economy. | |
| | | G.Terence Valued Member
| Subject: Re: fuel Wed Jul 05, 2017 10:16 am | |
| Ardie, My experience is the exact opposite to you. With the I R C tyres a full tank would do about 160 mpg. After fitting Bridgestone tyres consumption is 180 plus on each tank. You appear to me to have a rolling restriction of some kind.
G.Terence | |
| | | | hawktheslayer Very Valued VIP Member
| Subject: Re: fuel Wed Jul 05, 2017 12:55 pm | |
| Also are you enjoying the riding more since changing to better tyres? The more confidence you have in a bike the faster you go and the quicker you use the throttle! | |
| | | ardie Valued Member
| Subject: Re: fuel Thu Jul 06, 2017 1:14 am | |
| Old tyres had good tread, cracking started to appear on side walls so binned them ,have bike almost three years noticed this nearly a year ago .I have been riding like I always have no different never have ridden this bike hard .In 40yrs of biking never had such a sudden drop in mpg I know its not my riding that's the cause .Andrew and Justin good and valid points I have gone out and ridden like a pussy no difference . Kept to same fuel for next 3 or 4 tank fills then changed to elsewhere no difference where I go to ride is on the coast mostly know the roads to avoid any traffic. On some tanks I was getting 190mls the best being 196 or so, was a bit of a thing with me to try to get 200 had a bet with a mate . I did do a lot of two up riding but last year or more its been mostly solo as wifes knee is fecked thanks again for the input guys . That's interesting Terence food for thought just cant get head round it | |
| Subject: Re: fuel Thu Jul 06, 2017 3:37 pm | |
| | | ardie Valued Member
| Subject: Re: fuel Thu Jul 06, 2017 4:03 pm | |
| fi with cobra pipes and power pro fitted already when I got it, bike always has and still does ride really sweet Justin | |
| Subject: Re: fuel Fri Jul 07, 2017 11:14 am | |
| Might want to check if the power pro is still actually working | |
| | | Badger Valued Member
| Subject: Re: fuel Fri Jul 07, 2017 7:04 pm | |
| - ardie wrote:
- .............. . I did do a lot of two up riding but last year or more its been mostly solo as wifes knee is fecked.........
You can get lowered rear foot pegs, that worked for my missis. | |
| | | ardie Valued Member
| Subject: Re: fuel Sat Jul 08, 2017 2:04 pm | |
| yes I got lowered rear pegs as soon as I got the bike as wifes knee has been bad for years but realy bad now, totally agree they do make a difference thanks badger | |
| | | ardie Valued Member
| Subject: Re: fuel Sat Jul 08, 2017 2:21 pm | |
| Justin first bike ive had with power pro on but bike is running sweet if it isn't working properly surely I would have noticed something, will take a look at it check connections . I have no manual for it so not sure what lights should be doing.Wont be able to work at bike for a week or so. will look online about power pro thanks Justin if I knew it was tyres I could live with it not knowing annoying. | |
| | | ardie Valued Member
| Subject: Re: fuel Mon Jul 17, 2017 7:55 pm | |
| I found a problem with connections on the power pro its tri pot one , all lights come on when turned on.Start up and only green stays on all normal .If I move the wires all come on its hit or miss at times the connectors are t tap ones two of them in total they a are shite system .I WANT TO replace with posi locks if poss but wires are really thin no room to solder very little room full stop. Does anyone know what guage these wires are. | |
| Subject: Re: fuel | |
| | | | fuel | |
Latest topics | » Choke plunger by flying1 Wed Mar 13, 2024 4:43 pm
» Will be making my own exhausts by JagLite Sun Feb 04, 2024 2:26 am
» just saying hello to this site by Mack Sun Jan 21, 2024 8:34 pm
» New old guy by Badger Sun Jan 14, 2024 8:26 pm
