 Tire clearance issues with wider rear tire
2 posters
KevinCt64
Tire clearance issues with wider rear tire Empty
PostSubject: Tire clearance issues with wider rear tire   Tire clearance issues with wider rear tire Icon_minitimeSun Jul 23, 2017 1:54 pm
I have recently increased the rear tire width to 150 and noticed that it now rubs the driveshaft side when riding 2 up. Is there a way to align the rear wheel / axle to increase this clearance slightly? Thinking maybe removing a shim in the driveshaft or similar? Some older bikes used to have an axle adjustment... Thanks.
PostSubject: Re: Tire clearance issues with wider rear tire   Tire clearance issues with wider rear tire Icon_minitimeSun Jul 23, 2017 9:14 pm
not sure it's doable? There's a spacer between the diff and wheel that determines the correct distance between the two, If you alter that distance to off set the wheel it'll cause handling problems I'd have thought.
» Wider Rar Tire 200/70R15
» the biggest rear tire / rim that fits on VX 800
» New Front Tire
» Whats the widest front tire can i install on my 2004 vs800?
» Tube type tire change
Tire clearance issues with wider rear tire Icon_minitimeby flying1 Wed Mar 13, 2024 4:43 pm
Tire clearance issues with wider rear tire Icon_minitimeby nano Tue Mar 05, 2024 2:19 pm
Tire clearance issues with wider rear tire Icon_minitimeby Brianhuck Sat Mar 02, 2024 7:30 pm
Tire clearance issues with wider rear tire Icon_minitimeby Billybop90 Fri Mar 01, 2024 12:44 am
Tire clearance issues with wider rear tire Icon_minitimeby Aikido789 Sat Feb 24, 2024 10:11 am
Tire clearance issues with wider rear tire Icon_minitimeby bernard chaddock Wed Feb 21, 2024 5:06 pm
Tire clearance issues with wider rear tire Icon_minitimeby bernard chaddock Wed Feb 21, 2024 4:58 pm
Tire clearance issues with wider rear tire Icon_minitimeby fabio almeida Tue Feb 20, 2024 9:28 am
Tire clearance issues with wider rear tire Icon_minitimeby icoolwecool99@gmail.com Mon Feb 19, 2024 9:47 pm
Tire clearance issues with wider rear tire Icon_minitimeby Billybop90 Fri Feb 16, 2024 7:16 pm
Tire clearance issues with wider rear tire Icon_minitimeby SWEET Fri Feb 16, 2024 6:25 pm
Tire clearance issues with wider rear tire Icon_minitimeby VAI777 Tue Feb 13, 2024 3:32 pm
Tire clearance issues with wider rear tire Icon_minitimeby redevil Tue Feb 13, 2024 10:59 am
Tire clearance issues with wider rear tire Icon_minitimeby Urko Sun Feb 11, 2024 11:12 am
Tire clearance issues with wider rear tire Icon_minitimeby CS_0427 Tue Feb 06, 2024 2:28 am
Tire clearance issues with wider rear tire Icon_minitimeby Badger Mon Feb 05, 2024 11:27 am
Tire clearance issues with wider rear tire Icon_minitimeby John Silver Sun Feb 04, 2024 7:05 pm
Tire clearance issues with wider rear tire Icon_minitimeby JagLite Sun Feb 04, 2024 2:26 am
» just saying hello to this site
Tire clearance issues with wider rear tire Icon_minitimeby Mack Sun Jan 21, 2024 8:34 pm
» New old guy
Tire clearance issues with wider rear tire Icon_minitimeby Badger Sun Jan 14, 2024 8:26 pm
