 vs750 fuel pump
grumpy grandad
vs750 fuel pump Empty
PostSubject: vs750 fuel pump   vs750 fuel pump Icon_minitimeSat Oct 07, 2017 7:48 pm
Hi their,Any body had to replace there fuel pumps? im in the process of rebuilding
this 1987/88 vs750,just replaced the battery but no life in pump ?
put meter across lines got power,looked at pionts end, very black and burnt
no clicking, can not move piston up or down, solid so needs replacement !
between £26 to £13 on fleabay anbody had one ?
RAnst4038
RAnst4038
PostSubject: Re: vs750 fuel pump   vs750 fuel pump Icon_minitimeSat Oct 28, 2017 2:56 am
If it was locked rotor or windings burnt it should blow the fuse. I would file those points and soak it with pen-oil.
65,000 on mine & only time it let me sit was when a spider spun a web between those points while I was tent camping. It stopped before I got out of campground. Took me a half hour to fix with just OEM tools in bag.  vs750 fuel pump 586905
grumpy grandad
PostSubject: Re: vs750 fuel pump   vs750 fuel pump Icon_minitimeFri Nov 03, 2017 8:28 pm
Hi thanks for your input,the pump was toast?the chap i got it from was a bit of a "IV GOT 2
AND THERE BETTER THAN YOURS"  plonker !!! i can fix anything   LOL
he had wired straight to the battery with a switch under the seat antitheft device ? NO FUSE !
guess he forgot to turn it off ?burnt the insde under the cap,FOOOOOOOOKED ! sized solid so
got a chinese one £10 free ship (best offer) Evilbay,brilliant got it running after 5 minutes + new fuel
wondered why it had full tank of putrid fuel ?? it had not run since 2010,now totally striped and getting ready for full rebuild,7 years sat outside NO COVER ! Mr rust has taken hold in places front mudgard the worst but nothing shot blaster wont sort out,now just what colour to paint it ?????     ANY IDEAS ???????????????????
PostSubject: Re: vs750 fuel pump   vs750 fuel pump Icon_minitimeFri Nov 03, 2017 9:52 pm
Black? Just as Mr Ford said "You can have any colour you want? as long as it's Black". Glad you got the pump sorted  vs750 fuel pump 3498837457
grumpy grandad
PostSubject: Re: vs750 fuel pump   vs750 fuel pump Icon_minitimeSat Nov 04, 2017 8:44 pm
Cheers Simbo,its already black well sort of ? black and rust !
iv looked on google at hundreds of vs 600/700/750/800 and they are all basic colours ?
because this is a total rebuild thought i might do something different ??????
metallic green/white stripe ? yellow ? cadbury purple ? hydro dip ? old school flames on tank ?
or HEAVY SAND 80 grit and lacquer ? metal flake ? candy ?
with it being a cruiser with that slower speed it needs a different look ? something that pops
? ill come up with something ?
vs750 fuel pump
» Fuel Pump on 660
» Afermarket Fuel Pump Replacement for the KQ 700 & 750
» 06 660 rhino fuel pump
» fuel pump problems
» Teryx Fuel Pump
vs750 fuel pump Icon_minitimeby stingray Mon Feb 17, 2020 8:38 am
» Crash Bars
vs750 fuel pump Icon_minitimeby Ish992019 Sun Feb 16, 2020 9:26 pm
vs750 fuel pump Icon_minitimeby pledge Sun Feb 16, 2020 3:29 pm
vs750 fuel pump Icon_minitimeby RonB58 Fri Feb 14, 2020 5:59 pm
vs750 fuel pump Icon_minitimeby ardie Fri Feb 14, 2020 11:42 am
» New member in Florida
vs750 fuel pump Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 6:08 pm
vs750 fuel pump Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:51 am
» VS1400 rear end on a VS750
vs750 fuel pump Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:42 am
» Led turn signals!
vs750 fuel pump Icon_minitimeby mhicks2517 Tue Feb 11, 2020 5:38 pm
vs750 fuel pump Icon_minitimeby DickB Tue Feb 11, 2020 12:05 pm
vs750 fuel pump Icon_minitimeby steve co Fri Feb 07, 2020 2:03 pm
vs750 fuel pump Icon_minitimeby steve co Fri Feb 07, 2020 1:40 pm
vs750 fuel pump Icon_minitimeby steve co Fri Feb 07, 2020 1:28 pm
» Newby
vs750 fuel pump Icon_minitimeby malone55 Mon Feb 03, 2020 1:58 pm
» Hello from Stockholm
vs750 fuel pump Icon_minitimeby stingray Mon Feb 03, 2020 9:49 am
» Glad to be here!
vs750 fuel pump Icon_minitimeby stingray Mon Feb 03, 2020 9:48 am
» Hey Guys
vs750 fuel pump Icon_minitimeby oldtom Sun Feb 02, 2020 12:49 pm
» White walls
vs750 fuel pump Icon_minitimeby ardie Mon Jan 27, 2020 7:52 pm
vs750 fuel pump Icon_minitimeby creol Sat Jan 25, 2020 8:24 am
» Back in the saddle.
vs750 fuel pump Icon_minitimeby ardie Fri Jan 24, 2020 8:13 pm
