 Vz800 35kW restriction removal
Runar
Vz800 35kW restriction removal Empty
PostSubject: Vz800 35kW restriction removal   Vz800 35kW restriction removal Icon_minitimeSat Jun 02, 2018 12:22 am
Im looking at removing the restriction kit. Instructions in the TÜV paper says you have to remove the tank. But it looks doable without doing so. Or im I wrong? I noticed the tab in the middle, I think thats the original throttle stopper. But there is also a third tab, the one most left and down. Can I cut the second tab off get more throttle twist? I dont really know. Anyone here who knows this better than me? I know the one at the top is the restriction.Vz800 35kW restriction removal Img_2014
Vz800 35kW restriction removal Img_2013
Bugera
PostSubject: Re: Vz800 35kW restriction removal   Vz800 35kW restriction removal Icon_minitimeMon Jun 04, 2018 12:28 pm
To get to the throttle valve, you have to remove the tank, it is not a big problem to do that. Yes you can get to the throttle without removing tank, but you have to lifted up it pretty high and secured, but for best visibility to work with throttle it is good idea to remove  fuel tank. For me it is very interesting about this restrictor, I heard about 35kw modification. If your bike is made in 2005, so may be this job was done long time before? what is your max speed, I mean how you know that you have power limited version. I can take picture of mine, to compare what tabs is original, and what is restriction stopper, it is hard to cleared what tab the most left and down you talking about
Runar
PostSubject: Re: Vz800 35kW restriction removal   Vz800 35kW restriction removal Icon_minitimeMon Jun 04, 2018 2:11 pm
I have TÜV papers with information, but dont have them on me. The blue line os the original stopper, the red one is the restriction. Havent tested the top speed, but I haad it up to 140kmh, and it had somd more to go. cant post a picture right now but around the "metall" wheel there are three plates sticking out. The restrictor is the top one, the original one is the one to the left of that.
Bugera
PostSubject: Re: Vz800 35kW restriction removal   Vz800 35kW restriction removal Icon_minitimeMon Jun 04, 2018 10:27 pm
I will check tomorrow on mine, how it is looks like, how many stoppers is there. My VZ800, have to be full power without any limitation, and the max speed is 165km/h, I checked it many times, but anyway I will check tomorrow those stoppers. if it is so easy realized those limitation, it means the bike don't get its maximum possible rpm, and just don't get its maximum possible power and speed. The responsibility and engine thrust on lower rpm should be the same as in normal bike VZ800, so it might be hard to check success of this operation, as there is no tachometer on bike, and not possible to check max rpm before and after. Just checking max speed before and after might get some indicators. Your power limit version is 35kW?  Full power version is 39kw, and it is pretty close. May be 35hp instead of 35kw. What was the point of those limitation 4kw?
Runar
PostSubject: Re: Vz800 35kW restriction removal   Vz800 35kW restriction removal Icon_minitimeTue Jun 05, 2018 6:44 am
I only have the A2 lisence. Which limits the amount of power a bike can have. I can only leagally drive bikes with max 48bhp/35kW, max 0,2kW/kg. Thats why
Bugera
PostSubject: Re: Vz800 35kW restriction removal   Vz800 35kW restriction removal Icon_minitimeTue Jun 05, 2018 6:07 pm
I took a picture of mine. You can see there are stoppers for closed drossel and open. If there is something on the way, between them, you can remove it.Vz800 35kW restriction removal Dsc00212
Vz800 35kW restriction removal Dsc00210
Vz800 35kW restriction removal Dsc00211
Bugera
PostSubject: Re: Vz800 35kW restriction removal   Vz800 35kW restriction removal Icon_minitimeTue Jun 05, 2018 6:14 pm
Vz800 35kW restriction removal Dsc00214
Runar
PostSubject: Re: Vz800 35kW restriction removal   Vz800 35kW restriction removal Icon_minitimeTue Jun 05, 2018 8:01 pm
Hhm, you have a different setup. Looks kinda like I have two idle srews. And you have only one throttle stopper. What model do you have?
Bugera
PostSubject: Re: Vz800 35kW restriction removal   Vz800 35kW restriction removal Icon_minitimeTue Jun 05, 2018 8:26 pm
Suzuki Intruder VZ800, 2014
Runar
PostSubject: Re: Vz800 35kW restriction removal   Vz800 35kW restriction removal Icon_minitimeWed Jun 06, 2018 6:08 am
Ah, okay. Cool
» Shifter knob removal
» Rhino rear sway bar removal
» King Quad 450 Diff Lock Limiter Removal
» axle shaft removal
» murray widebody steering wheel removal.
Vz800 35kW restriction removal Icon_minitimeby stingray Mon Feb 17, 2020 8:38 am
» Crash Bars
Vz800 35kW restriction removal Icon_minitimeby Ish992019 Sun Feb 16, 2020 9:26 pm
Vz800 35kW restriction removal Icon_minitimeby pledge Sun Feb 16, 2020 3:29 pm
Vz800 35kW restriction removal Icon_minitimeby RonB58 Fri Feb 14, 2020 5:59 pm
Vz800 35kW restriction removal Icon_minitimeby ardie Fri Feb 14, 2020 11:42 am
» New member in Florida
Vz800 35kW restriction removal Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 6:08 pm
Vz800 35kW restriction removal Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:51 am
» VS1400 rear end on a VS750
Vz800 35kW restriction removal Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:42 am
» Led turn signals!
Vz800 35kW restriction removal Icon_minitimeby mhicks2517 Tue Feb 11, 2020 5:38 pm
Vz800 35kW restriction removal Icon_minitimeby DickB Tue Feb 11, 2020 12:05 pm
Vz800 35kW restriction removal Icon_minitimeby steve co Fri Feb 07, 2020 2:03 pm
Vz800 35kW restriction removal Icon_minitimeby steve co Fri Feb 07, 2020 1:40 pm
Vz800 35kW restriction removal Icon_minitimeby steve co Fri Feb 07, 2020 1:28 pm
» Newby
Vz800 35kW restriction removal Icon_minitimeby malone55 Mon Feb 03, 2020 1:58 pm
» Hello from Stockholm
Vz800 35kW restriction removal Icon_minitimeby stingray Mon Feb 03, 2020 9:49 am
» Glad to be here!
Vz800 35kW restriction removal Icon_minitimeby stingray Mon Feb 03, 2020 9:48 am
» Hey Guys
Vz800 35kW restriction removal Icon_minitimeby oldtom Sun Feb 02, 2020 12:49 pm
» White walls
Vz800 35kW restriction removal Icon_minitimeby ardie Mon Jan 27, 2020 7:52 pm
Vz800 35kW restriction removal Icon_minitimeby creol Sat Jan 25, 2020 8:24 am
» Back in the saddle.
Vz800 35kW restriction removal Icon_minitimeby ardie Fri Jan 24, 2020 8:13 pm
