 vs800 pre 96 jetting experience
arcticmods
vs800 pre 96 jetting experience Empty
PostSubject: vs800 pre 96 jetting experience   vs800 pre 96 jetting experience Icon_minitimeThu Jul 19, 2018 8:04 pm
Hello guys
Happy to be a member of this awesome forum for us suzuki drivers.
I have been testing on my own for some months now, trying to get the bike dialed in after rebuilding it.
It seems to run ok now, but am lacking the lower rpm pull i used to have. It is much stronger higher up in the revs though.
Org setup:
Front carb - pilot 40, main 100, dynojet needle at third notch
Rear carb - pilot 45, main 107,5, needle same as front
Slashcut straight piped exhaust with some muffling in the end.
Org airfilter and box
New setup:
Front carb - pilot 47,5, main 112,5, dynojet third notch
Rear carb - pilot 52,5, main 120, dynojet same
KN filters in standard box
Same exhaust
Both spark plugs are reading black around the edge, grey on the top.
As written, the bike is running ok, but I feel its maybe a bit too rich on the pilots. Tried with 45 in front and 48 in the back, but was getting a higher/harder exhaust note from the pipes and an uneven throttle respons while cruising and just of idle (seems lean then).
What are your thoughts on this one? Are the mains maybe contributing to the lower rpm pull. Should they be larger? I have jet sizes all the way to 140 laying around.
The bike as it sits now below.
vs800 pre 96 jetting experience Facebook-2621-2_zpsoxawu5qb
PostSubject: Re: vs800 pre 96 jetting experience   vs800 pre 96 jetting experience Icon_minitimeFri Jul 20, 2018 1:50 pm
Unfortunateely I cannot help you but am sure someone will try to help you later.
PostSubject: Re: vs800 pre 96 jetting experience   vs800 pre 96 jetting experience Icon_minitimeFri Jul 20, 2018 6:42 pm
wow bike looks really nice love that headlamp
crabs can be a very tricky things to get set up really well the exhaust being straight through might be playing a part in the set up as well have you taken your bike for a dyno run (rolling road) they should be able to set your bike up not sure how much that will cost you though
» Beartracker Jetting Question
» ATV Jetting basics...
» What modifications have you done to your ride? List here
» 686 kit for rhino??
» yamaha ttr 125e
vs800 pre 96 jetting experience Icon_minitimeby stingray Mon Feb 17, 2020 8:38 am
» Crash Bars
vs800 pre 96 jetting experience Icon_minitimeby Ish992019 Sun Feb 16, 2020 9:26 pm
vs800 pre 96 jetting experience Icon_minitimeby pledge Sun Feb 16, 2020 3:29 pm
vs800 pre 96 jetting experience Icon_minitimeby RonB58 Fri Feb 14, 2020 5:59 pm
vs800 pre 96 jetting experience Icon_minitimeby ardie Fri Feb 14, 2020 11:42 am
» New member in Florida
vs800 pre 96 jetting experience Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 6:08 pm
vs800 pre 96 jetting experience Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:51 am
» VS1400 rear end on a VS750
vs800 pre 96 jetting experience Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:42 am
» Led turn signals!
vs800 pre 96 jetting experience Icon_minitimeby mhicks2517 Tue Feb 11, 2020 5:38 pm
vs800 pre 96 jetting experience Icon_minitimeby DickB Tue Feb 11, 2020 12:05 pm
vs800 pre 96 jetting experience Icon_minitimeby steve co Fri Feb 07, 2020 2:03 pm
vs800 pre 96 jetting experience Icon_minitimeby steve co Fri Feb 07, 2020 1:40 pm
vs800 pre 96 jetting experience Icon_minitimeby steve co Fri Feb 07, 2020 1:28 pm
» Newby
vs800 pre 96 jetting experience Icon_minitimeby malone55 Mon Feb 03, 2020 1:58 pm
» Hello from Stockholm
vs800 pre 96 jetting experience Icon_minitimeby stingray Mon Feb 03, 2020 9:49 am
» Glad to be here!
vs800 pre 96 jetting experience Icon_minitimeby stingray Mon Feb 03, 2020 9:48 am
» Hey Guys
vs800 pre 96 jetting experience Icon_minitimeby oldtom Sun Feb 02, 2020 12:49 pm
» White walls
vs800 pre 96 jetting experience Icon_minitimeby ardie Mon Jan 27, 2020 7:52 pm
vs800 pre 96 jetting experience Icon_minitimeby creol Sat Jan 25, 2020 8:24 am
» Back in the saddle.
vs800 pre 96 jetting experience Icon_minitimeby ardie Fri Jan 24, 2020 8:13 pm
