 Handling VS800gl 1992 front wheel size change?
Moggie
Moggie
PostSubject: Handling VS800gl 1992 front wheel size change?   Wed Oct 24, 2018 8:56 pm
OK so I'm told that the 80/90 -21 front wheel could be changed to a smaller size to get better handling.
Is this correct I'm not sure how this works, Its it the width or the diameter that makes the difference or will the difference be negligible?
And surely changing the wheel diameter will affect the speedo reading?
Must say I'd quite like to have a slightly wider wheel, it's too skinny for my liking. And it looks like there is space for it. the standard wheel seems to have spacers either side.
Thanks in advance!
PostSubject: Re: Handling VS800gl 1992 front wheel size change?   Sun Oct 28, 2018 8:16 pm
I think they did that bike with both a 19inch and a 21inch front wheel depending on the year I had one with a 21inch I think my memory is shite though lol as far as I remember mine handled great you could probably make it feel more stable by changing the bars and tyres will make huge difference if I remember I had avon tyres on mine front wheel is skinny but that's the style of the bike you might be able to fit a wider wheel though mate
» wheel size question
» WTB front wheel for rzr s
» Front hub wheel bearing removal problem
» Front wheel bearings
» Suzuki Eiger
» Greetings from Scandinavia
» CLUTCH SLIPPING STILL
» Engine swap
» Hello from Hong Kong
» Re: My first project bike
» Miss ing
» new new new
» Newby from Norfolk
» con rod problem
» Whats goin on everybody
» Hi fellow riders
» Need some technical help with cam timing....
by Jimblud Mon Dec 17, 2018 2:32 am
» Speedometer problem
by peardrop3 Sat Dec 15, 2018 12:13 pm
