 con rod problem
mo800
mo800
con rod problem Empty
PostSubject: con rod problem   con rod problem Icon_minitimeSat Dec 22, 2018 7:55 pm
Hi
Just bought vz800 (1997) to turn it into a bobber style,after taking the engine out and finding out what a mess the instant gasket glue has done. I have found that both con rods have the same number 2s on them? is this a problem and the main bearing shell tabs are on the right side and not on the left side and been grind off to fit.
mo800
mo800
PostSubject: Re: con rod problem   con rod problem Icon_minitimeSun Dec 23, 2018 9:49 am
mo800 wrote:
Hi
looks like i got a bit wrong in the description saying main bearings when should of been conrod big end shells tab.
mo800
mo800
PostSubject: Re: con rod problem   con rod problem Icon_minitimeMon Dec 24, 2018 10:22 pm
Help please does it matter if the con rods have the same number on both,as both have number 2 on. Thank you.
PostSubject: Re: con rod problem   con rod problem Icon_minitimeTue Dec 25, 2018 10:24 am
Should be the same.
mo800
mo800
PostSubject: Re: con rod problem   con rod problem Icon_minitimeTue Dec 25, 2018 8:38 pm
Do you mean 1 and 2 being the same,or 2 and 2 are the same,
 Cheers merry christmas.
con rod problem
» Problem with Power Cord
» How can i fix a priming problem?
» Snapper Transaxle Problem?
» PS3 Master account problem
» SD 2100 switches off by itself... battery problem?
» First post from Arnold in Idaho
con rod problem Icon_minitimeby stingray Today at 7:06 pm
» register logon - C'mon in and say hello - I think
con rod problem Icon_minitimeby stingray Today at 7:03 pm
» SAYING HELLO FROM WINNIPEG, MANITOBA
con rod problem Icon_minitimeby Takkyu Fri Jun 21, 2019 5:33 pm
» Hello! This is Ed from Wash.,DC
con rod problem Icon_minitimeby Takkyu Fri Jun 21, 2019 5:32 pm
» Hiyas
con rod problem Icon_minitimeby Takkyu Fri Jun 21, 2019 5:31 pm
» Newbie
con rod problem Icon_minitimeby peardrop3 Fri Jun 21, 2019 5:30 pm
con rod problem Icon_minitimeby Takkyu Fri Jun 21, 2019 5:29 pm
» Ratchet noise from under tank.
con rod problem Icon_minitimeby goshhub Fri Jun 14, 2019 11:39 pm
» First Time Ever Saw Mr Green
con rod problem Icon_minitimeby ArnoldinIdaho Fri Jun 14, 2019 9:51 pm
» Hi new here...
con rod problem Icon_minitimeby OldManYam Tue Jun 04, 2019 10:10 pm
» Hello from Bulgaria
con rod problem Icon_minitimeby OldManYam Tue Jun 04, 2019 10:08 pm
» Hello from Ipswich
con rod problem Icon_minitimeby OldManYam Tue Jun 04, 2019 10:07 pm
» VZ800 Charging issue
con rod problem Icon_minitimeby peardrop3 Mon Jun 03, 2019 2:03 pm
» Hello from Calgary Alberta CANADA
con rod problem Icon_minitimeby peardrop3 Sun Jun 02, 2019 4:55 pm
» Hi from South Wales
con rod problem Icon_minitimeby Takkyu Mon May 27, 2019 3:35 pm
con rod problem Icon_minitimeby ardie Sun May 26, 2019 6:54 pm
» My 2013 M50
con rod problem Icon_minitimeby ardie Sun May 26, 2019 6:50 pm
» Brake lever!
con rod problem Icon_minitimeby Shrek Sun May 26, 2019 1:45 pm
» Brake lever!
con rod problem Icon_minitimeby Shrek Sun May 26, 2019 1:29 pm
» Hi from Calgary, Alberta, Canada! (2000 Maurader VZ800)
con rod problem Icon_minitimeby Takkyu Sat May 25, 2019 8:36 pm
